Teensy 3.2 and 74HC595 Problems
cfredisded
Hi all, its my first time ever using 74hc595s with the teensy, and I'm going to be working on a bar graph type project. So I have four 595s hooked up to the teensy and wanted to try the library 'Shifty' to make things a bit easier for me. But I cant get any leds to turn on or off. Ive tried a sketch just to test the shift registers but haven't had any luck. Here's my schematic https://imgur.com/gmv0wg7 and here's the program I've tried. I have it all hooked up like this on a circuit board I made.
#include <Shifty.h>
// Declare the shift register
Shifty shift;
  // Set the number of bits you have (multiples of 8)
  shift.setBitCount(32);
  // Set the clock, data, and latch pins you are using
  // This also sets the pinMode for these pins
  shift.setPins(13, 11, 8);
  pinMode(21, OUTPUT);
  // writeBit works just like digitalWrite
  shift.writeBit(1, HIGH);
  digitalWrite(21, HIGH);
  shift.writeBit(3, HIGH);
  shift.writeBit(1, LOW);
  digitalWrite(21, LOW);
  shift.writeBit(3, LOW);
In this code I added the digitalWrite(21, HIGH); and digitalWrite(21, LOW); just to make sure the teensy was working in this setup and that led does blink but nothing on the bar graph blinks.
I'm also curious as to which pins need to be used for clock latch and data. Do I have to use 13, 11 and 8? im going off of this site. https://www.pjrc.com/teensy/td_libs_ShiftPWM.html
Any help tips would be appreciated, Thanks.
Playing around with this code i can send a number through the serial port and get leds to light so i know the shift registers are working.
const int latchPin = 8;
const int clockPin = 13;
const int dataPin = 11;
pinMode(latchPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
Serial.println("reset");
if (Serial.available() > 0) {
int bitToSet = Serial.read() - 48;
char buf[100];
sprintf(buf,"%d\n",bitToSet);
Serial.write(buf);
registerWrite(bitToSet, HIGH);
void registerWrite(int whichPin, int whichState) {
byte bitsToSend = 0;
digitalWrite(latchPin, LOW);
bitWrite(bitsToSend, whichPin, whichState);
shiftOut(dataPin, clockPin, MSBFIRST, bitsToSend);
digitalWrite(latchPin, HIGH);
Strangely when I go back to the previous code, what ever leds I left on start scrolling to the right until no leds are left on and then nothing happens.
I never heard of that shifty library before. Could it be that it was written with specific hardware register access for AVR CPUs, common in the Arduino world? That would explain why it doesn‘t work on the more modern ARM CPUs on which the Teensys are based. Perhaps you could provide a link?
Here's a link to the library. https://github.com/johnnyb/Shifty
I just found it searching '595' in the arduino libraries. I'm trying to eventually do something like this but with 32 led bar graph.
  LED bar graph
  Turns on a series of LEDs based on the value of an analog sensor.
  This is a simple way to make a bar graph display. Though this graph uses 10
  LEDs, you can use any number by changing the LED count and the pins in the
  array.
  This method can be used to control any series of digital outputs that depends
  on an analog input.
  The circuit:
  - LEDs from pins 2 through 11 to ground
  created 4 Sep 2010
  by Tom Igoe
  http://www.arduino.cc/en/Tutorial/BarGraph
// these constants won't change:
const int analogPin = A0;   // the pin that the potentiometer is attached to
const int ledCount = 10;    // the number of LEDs in the bar graph
int ledPins[] = {
  2, 3, 4, 5, 6, 7, 8, 9, 10, 11
};   // an array of pin numbers to which LEDs are attached
  // loop over the pin array and set them all to output:
  for (int thisLed = 0; thisLed < ledCount; thisLed++) {
    pinMode(ledPins[thisLed], OUTPUT);
  // read the potentiometer:
  int sensorReading = analogRead(analogPin);
  // map the result to a range from 0 to the number of LEDs:
  int ledLevel = map(sensorReading, 0, 1023, 0, ledCount);
  // loop over the LED array:
    // if the array element's index is less than ledLevel,
    // turn the pin for this element on:
    if (thisLed < ledLevel) {
      digitalWrite(ledPins[thisLed], HIGH);
    // turn off all pins higher than the ledLevel:
    else {
      digitalWrite(ledPins[thisLed], LOW);
From https://www.arduino.cc/en/Tutorial/BarGraph
I had a look at the library’s source code. It uses specific internal Arduino 8bit functions like bitSet(), bitRead(), etc. I’m not sure if these are intended to work correctly in 32bit Teensyduino. You’d have to write test code and checking the result, or better write your own library with optimized Teensy code.
On a T3.2, I hooked up a 74hc595 powered with 3.3v with a few LEDs. For data,clock,latch I used 2,3,4. Using shiftOut() everything behaved as expected. And everything still worked using the Shifty library. I didn't daisy-chain, but setting to 32 bits in Shifty, and turning on 24 and 25, it would toggle LED 0 and 1, as expected. Maybe you could do some simple breadboard tests. I didn't examine your schematic carefully.
I would just use shiftOut(). arduino has some daisy-chaining examples https://www.arduino.cc/en/Tutorial/ShiftOut
EDIT: Note, the comments in your Shifty sketch in post #1 suggest the wrong pin ordering, here is what Shifty.h says
void setPins(int dataPin, int clockPin, int latchPin);
Thank you very much! Yes indeed in the shifty example code the comment says..
When it should say...
 // Set the data, clock, and latch pins you are using
I switched those and now it seems to be working more like it should. Thanks again that would have taken me ages
