DJ Namaste
Hi, I am trying to repeat images down the row of Leds using the Supernova poi code from Adafruit using Teensy 3.2. The code below will display a 32 pixel image multiple times down the row. The problem is there is a flash between frames after the 32nd pixel. It is also displaying slower than the original sketch. Id like to speed up the display rate and get rid of the flash that happens after each display. Any help?
POV IR Supernova Poi sketch. Uses the following Adafruit parts
(X2 for two poi):
- Teensy 3.2 (required - NOT compatible w/AVR-based boards)
- 2200 mAh Lithium Ion Battery https://www.adafruit.com/product/1781
- LiPoly Backpack https://www.adafruit.com/product/2124
- 144 LED/m DotStar strip (#2328 or #2329)
(ONE METER is enough for TWO poi)
- Infrared Sensor: https://www.adafruit.com/product/157
- Mini Remote Control: https://www.adafruit.com/product/389
(only one remote is required for multiple poi)
Needs Adafruit_DotStar library: github.com/adafruit/Adafruit_DotStar
Also, uses version of IRremote library from the Teensyduino installer,
the stock IRremote lib will NOT work here!
This is based on the LED poi code (also included in the repository),
but AVR-specific code has been stripped out for brevity, since these
mega-poi pretty much require a Teensy 3.X.
products from Adafruit!
Written by Phil Burgess / Paint Your Dragon for Adafruit Industries.
MIT license, all text above must be included in any redistribution.
See 'COPYING' file for additional notes.
#include <Arduino.h>
#include <Adafruit_DotStar.h>
#//include <avr/power.h>
#//include <avr/sleep.h>
#include <IRremote.h>
typedef uint16_t line_t;
// CONFIGURABLE STUFF ------------------------------------------------------
#include "graphics.h" // Graphics data is contained in this header file.
// It's generated using the 'convert.py' Python script. Various image
// formats are supported, trading off color fidelity for PROGMEM space.
// Handles 1-, 4- and 8-bit-per-pixel palette-based images, plus 24-bit
// truecolor. 1- and 4-bit palettes can be altered in RAM while running
// to provide additional colors, but be mindful of peak & average current
// draw if you do that! Power limiting is normally done in convert.py
// (keeps this code relatively small & fast).
// Ideally you use hardware SPI as it's much faster, though limited to
// specific pins. If you really need to bitbang DotStar data & clock on
// different pins, optionally define those here:
#define LED_DATA_PIN 0
#define LED_CLOCK_PIN 2
#define pixelHeight 32
// Empty and full thresholds (millivolts) used for battery level display:
#define BATT_MIN_MV 3350 // Some headroom over battery cutoff near 2.9V
#define BATT_MAX_MV 4000 // And little below fresh-charged battery near 4.1V
boolean autoCycle = true; // Set to true to cycle images by default
uint32_t CYCLE_TIME = 4; // Time, in seconds, between auto-cycle images
int RECV_PIN = 4;
IRrecv irrecv(RECV_PIN);
decode_results results;
// Adafruit IR Remote Codes:
// Button Code Button Code
// VOL-: 0xFD00FF 0/10+: 0xFD30CF
// Play/Pause: 0xFD807F 1: 0xFD08F7
// VOL+: 0xFD40BF 2: 0xFD8877
// SETUP: 0xFD20DF 3: 0xFD48B7
// STOP/MODE: 0xFD609F 4: 0xFD28D7
// UP: 0xFDA05F 5: 0xFDA857
// DOWN: 0xFDB04F 6: 0xFD6897
// LEFT: 0xFD10EF 7: 0xFD18E7
// RIGHT: 0xFD50AF 8: 0xFD9867
// ENTER/SAVE: 0xFD906F 9: 0xFD58A7
// Back: 0xFD708F
#define BTN_BRIGHT_UP 0xFD40BF
#define BTN_BRIGHT_DOWN 0xFD00FF
#define BTN_RESTART 0xFD807F
#define BTN_BATTERY 0xFD20DF
#define BTN_FASTER 0xFD805F
#define BTN_SLOWER 0xFDB04F
#define BTN_OFF 0xFD609F
#define BTN_PATTERN_PREV 0xFD10EF
#define BTN_PATTERN_NEXT 0xFD50AF
#define BTN_AUTOPLAY 0XFD906F
#define BTN_NONE -1
#if defined(LED_DATA_PIN) && defined(LED_CLOCK_PIN)
// Older DotStar LEDs use GBR order. If colors are wrong, edit here.
Adafruit_DotStar strip = Adafruit_DotStar(NUM_LEDS,
LED_DATA_PIN, LED_CLOCK_PIN, DOTSTAR_BGR);
#else
Adafruit_DotStar strip = Adafruit_DotStar(NUM_LEDS, DOTSTAR_BGR);
void imageInit(void),
IRinterrupt(void);
uint16_t readVoltage(void);
strip.begin(); // Allocate DotStar buffer, init SPI
strip.clear(); // Make sure strip is clear
strip.show(); // before measuring battery
imageInit(); // Initialize pointers for default image
irrecv.enableIRIn(); // Start the receiver
// GLOBAL STATE STUFF ------------------------------------------------------
uint32_t lastImageTime = 0L, // Time of last image change
lastLineTime = 0L;
uint8_t imageNumber = 0, // Current image being displayed
imageType, // Image type: PALETTE[1,4,8] or TRUECOLOR
*imagePalette, // -> palette data in PROGMEM
*imagePixels, // -> pixel data in PROGMEM
palette[16][3]; // RAM-based color table for 1- or 4-bit images
line_t imageLines, // Number of lines in active image
imageLine; // Current line number in image
volatile uint16_t irCode = BTN_NONE; // Last valid IR code received
const uint8_t PROGMEM brightness[] = { 15, 31, 63, 127, 255 };
uint8_t bLevel = sizeof(brightness) - 1;
// Microseconds per line for various speed settings
const uint16_t PROGMEM lineTable[] = { // 375 * 2^(n/3)
1000000L / 375, // 375 lines/sec = slowest
1000000L / 472,
1000000L / 595,
1000000L / 750, // 750 lines/sec = mid
1000000L / 945,
1000000L / 1191,
1000000L / 1500 // 1500 lines/sec = fastest
uint8_t lineIntervalIndex = 3;
uint16_t lineInterval = 1000000L / 1500;
void imageInit() { // Initialize global image state for current imageNumber
imageType = images[imageNumber].type;
imageLines = images[imageNumber].lines;
imageLine = 0;
imagePalette = (uint8_t *)images[imageNumber].palette;
imagePixels = (uint8_t *)images[imageNumber].pixels;
// 1- and 4-bit images have their color palette loaded into RAM both for
// faster access and to allow dynamic color changing. Not done w/8-bit
// because that would require inordinate RAM (328P could handle it, but
// I'd rather keep the RAM free for other features in the future).
if(imageType == PALETTE1) memcpy_P(palette, imagePalette, 2 * 3);
else if(imageType == PALETTE4) memcpy_P(palette, imagePalette, 16 * 3);
lastImageTime = millis(); // Save time of image init for next auto-cycle
void nextImage(void) {
if(++imageNumber >= NUM_IMAGES) imageNumber = 0;
imageInit();
void prevImage(void) {
imageNumber = imageNumber ? imageNumber - 1 : NUM_IMAGES - 1;
imageInit();
// MAIN LOOP ---------------------------------------------------------------
uint32_t t = millis(); // Current time, milliseconds
if(autoCycle) {
if((t - lastImageTime) >= (CYCLE_TIME * 1000L)) nextImage();
// CPU clocks vary slightly; multiple poi won't stay in perfect sync.
// Keep this in mind when using auto-cycle mode, you may want to cull
// the image selection to avoid unintentional regrettable combinations.
// Transfer one scanline from pixel data to LED strip:
switch(imageType) {
case PALETTE1: { // 1-bit (2 color) palette-based image
uint8_t pixelNum = 0, byteNum, bitNum, pixels, idx,
*ptr = (uint8_t *)&imagePixels[imageLine * pixelHeight / 8];
for(byteNum = pixelHeight/8; byteNum--; ) { // Always padded to next byte
pixels = *ptr++; // 8 pixels of data (pixel 0 = LSB)
for(bitNum = 8; bitNum--; pixels >>= 1) {
idx = pixels & 1; // Color table index for pixel (0 or 1)
strip.setPixelColor(pixelNum++,
palette[idx][0], palette[idx][1], palette[idx][2]);
strip.setPixelaColor(pixelNum++,
case PALETTE4: { // 4-bit (16 color) palette-based image
uint8_t pixelNum, p1, p2, *ptr = (uint8_t *)&imagePixels[imageLine * pixelHeight / 2];
for(pixelNum = 0; pixelNum < 32; ) {
p2 = *ptr++; // Data for two pixels...
p1 = p2 >> 4; // Shift down 4 bits for first pixel
p2 &= 0x0F; // Mask out low 4 bits for second pixel
palette[p1][0], palette[p1][1], palette[p1][2]);
palette[p2][0], palette[p2][1], palette[p2][2]);
for(pixelNum = 32; pixelNum < 64; ) {
for(pixelNum = 64; pixelNum < 98; ) {
for(pixelNum = 96; pixelNum < 128; ) {
for(pixelNum = 128; pixelNum < 160; ) {
case PALETTE8: { // 8-bit (256 color) PROGMEM-palette-based image
uint16_t o;
uint8_t pixelNum,
*ptr = (uint8_t *)&imagePixels[imageLine * pixelHeight];
for(pixelNum = 0; pixelNum < 32; pixelNum++) {
o = *ptr++ * 3; // Offset into imagePalette
strip.setPixelColor(pixelNum,
imagePalette[o],
imagePalette[o + 1],
imagePalette[o + 2]);
for(pixelNum = 32; pixelNum < 64; pixelNum++) {
imagePalette[o],
for(pixelNum = 64; pixelNum < 96; pixelNum++) {
imagePalette[o],
for(pixelNum = 96; pixelNum < 128; pixelNum++) {
imagePalette[o],
for(pixelNum = 128; pixelNum < 160; pixelNum++) {
imagePalette[o],
case TRUECOLOR: { // 24-bit ('truecolor') image (no palette)
uint8_t pixelNum, r, g, b,
*ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS * 3];
for(pixelNum = 0; pixelNum < NUM_LEDS; pixelNum++) {
r = *ptr++;
g = *ptr++;
b = *ptr++;
strip.setPixelColor(pixelNum, r, g, b);
if(++imageLine >= imageLines) imageLine = 0; // Next scanline, wrap around
IRinterrupt();
while(((t = micros()) - lastLineTime) < lineInterval) {
if(results.value != BTN_NONE) {
if(!strip.getBrightness()) { // If strip is off...
// Set brightness to last level
strip.setBrightness(brightness[bLevel]);
// and ignore button press (don't fall through)
// effectively, first press is 'wake'
switch(results.value) {
case BTN_BRIGHT_UP:
if(bLevel < (sizeof(brightness) - 1))
strip.setBrightness(brightness[++bLevel]);
case BTN_BRIGHT_DOWN:
if(bLevel)
strip.setBrightness(brightness[--bLevel]);
case BTN_FASTER:
CYCLE_TIME++;
if(lineIntervalIndex < (sizeof(lineTable) / sizeof(lineTable[0]) - 1))
lineInterval = lineTable[++lineIntervalIndex];
case BTN_SLOWER:
if(CYCLE_TIME > 0) CYCLE_TIME--;
if(lineIntervalIndex)
lineInterval = lineTable[--lineIntervalIndex];
case BTN_RESTART:
imageNumber = 0;
imageInit();
case BTN_OFF:
strip.setBrightness(0);
case BTN_PATTERN_PREV:
prevImage();
case BTN_PATTERN_NEXT:
nextImage();
case BTN_AUTOPLAY:
autoCycle = !autoCycle;
results.value = BTN_NONE;
strip.show(); // Refresh LEDs
lastLineTime = t;
void IRinterrupt() {
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
