Results 1 to 4 of 4
Thread: CAN Project Weird Issue
    Jul 2017
    5
    This could be something daft, it likely is.. I'm fairly new to this stuff.
    I have a car ECU powered by my bench PSU, this provides a CAN stream at 1mbd which I am successfully receiving via a Waveshare SN65HVD230 (Chinese copy, I have an original Waveshare product en-route from Amazon).
    My project is wired as follows
    SN65 on the left, Teensy 3.2 on the right
    TX-> Pin 3 (Purple Wire)
    RX-> Pin 4 (Blue Wire)
    GND-> GND (Black to Brown Wire)
    3.3v-> 3.3v (Green to Red Wire)
    The teensy powered from USB.
    The CAN stream I'm receiving sends a total of 8 data blocks with ID's: 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007. I'm mostly receiving the first 2000 block, and every now and again, the second 2001 block. Until I physically touch the RX and TX wires from the Transveiver to the Teensy, and then I get a proper data stream including all of the above data blocks.
    I'm puzzled as to why me taking a hold of the wires makes this work, but when I'm not touching the wires it seems to repeat?
    Hopefully someone has a suggestion.
    Here's a photo of my project
    Here's the sketch I'm using
    #include <FlexCAN.h>
    #include <kinetis_flexcan.h>
    int led = 13;
    FlexCAN CANbus(1000000);
    static CAN_message_t rxmsg;
    static uint8_t hex[17] = "0123456789abcdef";
      Serial.println(F("Teensy 3.2 CAN Test"));
      CANbus.begin();
      pinMode(led, OUTPUT);
      digitalWrite(led, 1);
      while (CANbus.read(rxmsg)) {
        // Light off to indicate FIFO is not being polled
        digitalWrite(led, 0);
        // Construct String
        String text = "ID: 0x";
        text = String(text + String(rxmsg.id, HEX));
        text = String(text + " DLC: ");
        text = String(text + String(rxmsg.len, HEX));
        // check if DLC is > 0
        if (rxmsg.len >= 1) {
          text = String(text + " DATA: ");
        // construct string for available bytes
        for (int idx = 0; idx < rxmsg.len; ++idx) {
          text = String(text + String(rxmsg.buf[idx], HEX));
          text = String(text + " ");
        // print result
        Serial.println(text);
        // LED Back on to indicate watching FIFO
    Jul 2017
    5
    I have a 5v step down board which I've used to power the entire project meaning everything is ground to a single source now.
    I am still only receiving the first Data block (2000) but now, me touching the TX and RX wires doesn't cause more data blocks to be received.
    Colour me confused!
    Jan 2015
    UK
    179
    Is there a 120R terminator resistor on board? Is it closed ? If not closed try and close it.
    Jul 2017
    5
    Thanks for the reply.
    My Waveshare CAN Transceiver arrived in the post today, and I can confirm that this has fixed my problem.
