Results 1 to 15 of 15
Thread: small bug in RHHardwareSP1I.cpp/h regarding Teensy LC
    13
    I've found a small bug in RHHardwareSP1I.cpp/h
    In order to make RadioHead work with the second SPI port on the Teensy LC I had to modify line 8 resp. 9 from
    #if defined(__arm__) && defined(TEENSYDUINO) && (defined(KINETISL) || defined(__MK64FX512__) || defined(__MK66FX1M0__) )
    to
    #if defined(__arm__) && defined(TEENSYDUINO) && (defined(KINETISL) || defined(__MK64FX512__) || defined(__MK66FX1M0__) || defined(__MKL26Z64__) )
    best,
    Sukandar
    3,534
    Quote Originally Posted by sukandar View Post
    to
    best,
    Sukandar
    Not sure why you would need to change this?
    The define for: KINETISL
    Is defined when a Teensy LC is used.
    13
    interesting
    well, I got this error message before I made the modification:
    /var/folders/5_/smbzv34x2ln1_tkxw_2qgzc80000gn/T/arduino_build_769466/sketch/BasicRX.ino.cpp.o: In function `_GLOBAL__sub_I_rf95':
    /Users/glui/Proj/musiClock/MKII/Arduino/BasicRX/BasicRX.ino:105: undefined reference to `hardware_spi1'
    collect2: error: ld returned 1 exit status
    Error compiling for board Teensy LC.
    13
    fwiw, if I put these lines in my sketch I get an error message
    #ifdef KINETISL
    not a valid statement
    However, if I put them in RHHardwareSP1I.cpp I don't
    2,718
    #ifdef KINETISL
    That is due to the fact that Arduino processes the .ino/.pde files to add forward references (and any other processing it does), and it doesn't understand #ifdef. Files in the library with .cpp suffix, are just passed straight to the compiler without doing pre-processing.
    13
    I don't get that.
    If I put these lines into my sketch it does not throw an error message
    #ifdef SCOOBYDOO
    Likewise there's a ton of files inside the Arduino package as well as my installed libraries that are full of #ifdefs
    1,746
    I don't get that.
    #ifdef SCOOBYDOO
    read careful Michael's statement
    he says ONLY the '*.ino' preprocessor does not understand the #ifdefs, The c/cpp compiled DOES understand #ifdefs
    13
    he wrote "Files in the library with .cpp suffix, are just passed straight to the compiler without doing pre-processing."
    So to me "without doing pre-processing" means that directives like #ifdef are ignored.
    Also, if my .ino sketch can't handle #ifdefs how come there's no error message for the example I've given?
    Again, this (in my .ino sketch) throws an error message
    #define SCOOBYDOO
    #ifdef SCOOBYDOO
    This doesn't
    #ifdef SCOOBYDOO
    How is that possible if #ifdefs are ignored?
    1,746
    because the #ifdefs in c/c++ files are are handled by the c/c++ compiler.
    (just passed straight to the compiler)
    The ino files are pre-processed by Arduino and converted to a c++ file.
    This process is useful for beginners but may generate problem with complicated files.
    For this reason my ino files are empty and my program is in a cpp file, obviously with proper #include statements and declaration sequence
    13
    Pre-processor fundamentals aside, the real issue to me seems to be why KINETISL is not defined when it comes to pre-processing RHHardwareSP1I.cpp
    1,746
    yes,
    I assume you have the latest libraries and only one installation, right?
    13
    yes,
    I just noticed that the filenames are kinda weird
    higgs:RadioHead glui$ ls -l RHH*
    -rw-r--r--@ 1 glui staff 4418 Nov 14 19:59 RHHardwareSP12.cpp
    -rw-r--r--@ 1 glui staff 4492 Nov 15 14:31 RHHardwareSP1I.cpp
    -rw-r--r-- 1 glui staff 10302 Nov 14 19:59 RHHardwareSPI.cpp
    -rw-r--r-- 1 glui staff 2819 Nov 14 19:59 RHHardwareSPI.h
    -rw-r--r--@ 1 glui staff 3050 Nov 14 20:15 RHHardwareSPI1.h
    -rw-r--r-- 1 glui staff 2997 Nov 14 19:59 RHHardwareSPI2.h
    shoudn't that be RHHardwareSPI1.cpp and RHHardwareSPI2.cpp ?
    That's from a fresh Arduino 1.8.5 patched with Teensyduino 1.40
    1,746
    OK,
    I have no radio available but I tried the following
    -open fresh empty sketch
    -set board to Teensy LC
    -include manager to include radiohead library
    -verify
    and got following error
     #error ("RadioHead SPI2 only supported on Teensy 3.5, 3.6")
    I understand this error and it makes sense in the first moment
    but it indicates also that the RadioRead library is simply written badly.
    it should not generate a compile error when file is present but CPU is not the right one.
    Consequently I would be not surprised that there are other issues with that library.
    so I gave up.
    IMO, the file naming should not make a difference, the include files and function names count
    3,534
    Hi WMXZ...
    Yep - The include library should not include those two header files. They were a HACK to allow other SPI ports.
    The HardwareSPI.h corresponds to using SPI, HardwareSPI1.h is a copy of it with SPI1... Likewise for SPI2
    Yes that part is not as clean as it could be, but did work... Again part of the testing of the 3.5/6 in beta... Probably could clean up some. Never tested using the include manager, which creates a semi nonsense. That is it includes the header files of ever RadioType it supports, which is very unlikely to work.
    13
    OK, well then I guess I'm glad that I got it working with my little "fix"
    Thanks for all your efforts
