Results 1 to 8 of 8
Thread: Teensy 2.0 as joystick not working
    Nov 2017
    Denmark
    4
    Hi!
    I just received a Teensy 2.0 today, and downloaded the Teensyduino installer, and succeeded to upload the fast/slow blink sketches from Arduino IDE 1.8.5.
    I then tried to follow this guide: https://www.pjrc.com/teensy/td_joystick.html
    The Arduino IDE does not have a Joystick option under Tools > USB Type. I only have a Keyboard + Mouse + Joystick option, so I selected that.
    The Board is set to Teensy 2.0. The CPU speed is set to 16 MHz
    I then tried this sketch:
    int led = 11;
      pinMode(led, OUTPUT);
      Joystick.X(512);            // "value" is from 0 to 1023
      Joystick.Y(512);            //   512 is resting position
      digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
      Joystick.button(1, 1);
      delay(1000);               // wait for a second
      digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
      Joystick.button(1, 0);
    When the sketch is uploaded I do get a Teensy Keyboard/Mouse/Joystick device on Win7 under Devices and Printers, but the Properties of the Game controller settings of the Teensy device indicates that it doesn't work:
    What am I doing wrong?
    /Mogens
    Senior Member manitou's Avatar
    1,265
    FWIW, your sketch worked for me on T2.0 hooking to Win 10. joystick properties shows button toggling. If i replace 512 with analogRead(A0) and analogRead(A1) (unattached, yields random), i can see that cross-hair randomly moving ...
    Using Arduino 1.8.4/1.40
    do you have genuine PJRC T2.0 or counterfeit? (have photo?)
    Nov 2017
    Denmark
    4
    It's most likely a counterfeit board then...
    /Mogens
    1,265
    yep, looks counterfeit. silkscreen doesn't match https://www.pjrc.com/teensy/pinout.html
    Nov 2017
    Denmark
    4
    Well.. I'm curious.
    What is the difference between a genuine and a counterfeit board?
    I mean provided that the counterfeiters got the PCB layout right, what's left to differ?
    Does the chip contain any code that only PJRC has access to?
    /Mogens
    1,265
    see https://www.pjrc.com/teensy/counterfeit.html
    and search forum for "counterfeit" and you can compile a list of the many sketches that won't work.
    Nov 2017
    Denmark
    4
    Well, thanks. I better get me a genuine one then.
    /Mogens
    16,282
    That board is definitely a counterfeit. But if the code uploads, I can't understand why it wouldn't work, unless there's something seriously wrong with the hardware.
