Results 1 to 5 of 5
Thread: Sender trigger signal from USB (in pySerial) to start program
    Oct 2017
    6
    I want to send a trigger signal from my computer to the Teensy. I'm using pyserial on the computer. Somehow the Teensy code doesn't respect waiting for the trigger signal.
    Code on computer:
    import serial
    ser = serial.Serial("/dev/tty.usbmodem3071981",9600)
    ser.write(1);
    Code on Teensy:
       if (Serial.available()) {
        incomingByte = Serial.read();  // will not be -1
        // do something
    The teensy just launches into what's at
    // do something.
    This should be an easy problem but something I can't sort it out... any suggestions?
    1,542
    in order to synchronize correctly
    you have to start teensy first
    in teensy setup I would try something like this
       while(!Serial); // wait for serial connection
       while(!Seral.available() || (incomingByte=Serial.read())!=1); wait for trigger byte to arrive
        // do something
    this assumes PC sends single bytes in ser.write(1)
    16,227
    Those code fragments look correct.
    Quote Originally Posted by mqlo View Post
    The problem is almost certainly in some part of the code you didn't show. Details matter. That's why we have the "Forum Rule" to post complete code. We can help you much more if you show us everything you're doing, rather than only tell us the parts you believe matter.
    Dec 2016
    Canada
    827
    you could also put do something in the same if block as incomming byte
    Oct 2017
    6
    Full code:
    #include <Messenger.h>
    // According to https://www.pjrc.com/teensy/td_pulse.html, the following pins share the same timer:
    // FTM0 5, 6, 9, 10, 20, 21, 22, 23
    // FTM1 3, 4
    // FTM2 29, 30
    // FTM3 2, 7, 8, 14, 35, 36, 37, 38
    // TPM1 16, 17
    // Here, we'll use FTM0 for centre and FTM3 for surround.
    // Define the centre
    int C01 = 5;
    int C02 = 6;
    int C03 = 9;
    int C04 = 10;
    int C05 = 20;
    int C06 = 21;
    int C07 = 22;
    // Define the surround
    int S01 = 2;
    int S02 = 7;
    int S03 = 8;
    int S04 = 14;
    int S05 = 35;
    int S06 = 36;
    int S07 = 37;
    // Status LED
    int X00 = 13;
    int incomingByte;
      // Set up the serial port
      Serial.begin(9600); // USB is always 12 Mbit/sec
      analogWriteResolution(12);// analogWrite value 0 to 4095, or 4096 for high
      // Set all pins to output
      pinMode(C01, OUTPUT);
      pinMode(C02, OUTPUT);
      pinMode(C03, OUTPUT);
      pinMode(C04, OUTPUT);
      pinMode(C05, OUTPUT);
      pinMode(C06, OUTPUT);
      pinMode(C07, OUTPUT);
      pinMode(S01, OUTPUT);
      pinMode(S02, OUTPUT);
      pinMode(S03, OUTPUT);
      pinMode(S04, OUTPUT);
      pinMode(S05, OUTPUT);
      pinMode(S06, OUTPUT);
      pinMode(S07, OUTPUT);
        // actually do something with incomingByte
        Serial.println(incomingByte);
        Serial.println("Hello World...");
        while(1) {
        setIntensity(4095, 4095, 4095, 4095, 4095, 4095, 4095, 4095, 4095, 4095, 4095, 4095, 4095, 4095, 4095);
        delay(200);
        setIntensity(0, 4095, 4095, 4095, 4095, 4095, 4095, 4095, 4095, 4095, 4095, 4095, 4095, 4095, 4095);
        delay(200);
    void setIntensity(int X00_s, int C01_s, int C02_s, int C03_s, int C04_s, int C05_s, int C06_s, int C07_s, int S01_s, int S02_s, int S03_s, int S04_s, int S05_s, int S06_s, int S07_s) {
        analogWrite(X00, X00_s);
        analogWrite(C01, C01_s);
        analogWrite(C02, C02_s);
        analogWrite(C03, C03_s);
        analogWrite(C04, C04_s);
        analogWrite(C05, C05_s);
        analogWrite(C06, C06_s);
        analogWrite(C07, C07_s);
        analogWrite(S01, S01_s);
        analogWrite(S02, S02_s);
        analogWrite(S03, S03_s);
        analogWrite(S04, S04_s);
        analogWrite(S05, S05_s);
        analogWrite(S06, S06_s);
        analogWrite(S07, S07_s);
    Pyserial code:
    import serial
    ser.write(1);
    while True:
        print("Waiting for messages from arduino..");
        read_ser=ser.readline()
        print(read_ser)
