I'm using an Arduino Mega and 20,4 Lcd, using the built-in Lcd Library and Paul's PJRC Encoder Library and would like to ask for some advice.
I'm a novice at C++.
I'm tring to use a Rotary Encoder to scroll through a menu. Although there are currently only 2 items in the menu, I may wish to increase this.
The idea is on start-up, the Lcd displays "Temperature and Humidity". With a click of the encoder switch, this then takes me to the menu, where I would like to have displayed a cursor ">" in column 0, and also displayed are the menu choices "Set Temp" & "Set Humid", where I can scroll the cursor and select one to then take me to other menu's.
As a novice, I think I've made a reasonable effort" although bias", but at the limit of my knowledge.
I'd be greatful for some advice.
Dizzwold.
Dizzwold.
/* Encoder Library - Basic Example
* http://www.pjrc.com/teensy/td_libs_Encoder.html
* This example code is in the public domain.
#include <LiquidCrystal.h>
#include <Encoder.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
Encoder myEnc(20, 21);
int button = 53;
int sw_val = 0;
char* menu[] =
"Set Temp",
"Set Humid",
const int numMenuItems = sizeof menu / sizeof *menu;
const int numLcdRows = 2;
int newPosition = 0;
byte menuCursor[8] = {
B01000, // *
B00100, // *
B00010, // *
B00001, // *
B00010, // *
B00100, // *
B01000, // *
B00000 //
lcd.begin(20, 4);
lcd.createChar(0, menuCursor);
lcd.clear();
pinMode(button, INPUT);
digitalWrite(button, HIGH);
lcd.setCursor(4, 0);
lcd.print("Temperature");
lcd.setCursor(8, 1);
lcd.print("and");
lcd.setCursor(6, 2);
lcd.print("Humidity");
long oldPosition = -999;
sw_val = digitalRead(button);
Serial.println(sw_val);
if (sw_val == LOW)
mainMenu();
void mainMenu()
long newPosition = myEnc.read();
if (newPosition /4 != oldPosition)
oldPosition = newPosition;
lcd.clear();
lcd.setCursor(0, newPosition);
lcd.write(byte(0));
lcd.setCursor(1, 0);
lcd.print(menu[newPosition]);
