Results 1 to 3 of 3
Thread: port manipulation - What am I doing wrong?
    Sep 2016
    3
    Here is a simple program, I just want to count on PORTD.
    - Windows 1.8.2, Teeny 1.37
    - the attached image shows D0..D7, 2,14,7,8,6,x,x,5, (Note: D5&6 are NOT connected)
    Problems:
    - bits are shuffled
    - D1 & D3 aren't being driven
    - those w/ keen eyes will notice the period is also wrong ...
    I've tried this on a 3.2 and 3.6 with the same result.
    Thank you
    Dave
    const uint8_t LED_PIN = 13;
    // we are using all PORTD pins, direct access
    elapsedMicros usec = 0;
    uint8_t tblNdx;
    pinMode(LED_PIN, OUTPUT);
    DDRD = 0xFF;
    PORTD = 0x00;
    tblNdx = 0;
    digitalWrite(LED_PIN, digitalRead(LED_PIN) ^ 0x01);
    PORTD = tblNdx++;
    while (usec < 500) ; // wait
    usec = usec - 500;
    Sep 2016
    3
    Thanks manitou!
    A few comments
    - as stated GPIOD_PDOR works correctly
    - I was unable to get GPIOD_PDDR to work and resorted to pinMode() as in the example
    Those two changes to my code and it now behaves as expected.
    Perhaps the following link could be updated ... since PORTD doesn't really work as stated.
    - https://www.pjrc.com/teensy/pins.html
