I'm trying to record audio using a Teensy 3.6, powered by a 1s Lipo (fully charged, 4.2V to Vin). I record mono, 10KHz, using double buffering and writing to the sd card after 16000 samples have been obtained. During write operations a prominent "queek" is recorded. I already went through some threads here discussing this topic, suggesting to implement some hardware hacks on the mic breakout.
So I eliminated the mic board by just feeding ~1.65V (absolute silence) to pin 14 by using a voltage divider between AREF and Analog Ground. Still the "queek" is there. I guess there is nothing I can do about it?
As my knowledge about electronics is very limited (setting up a voltage divider is probably the most I can do) I'm now stuck. What I will try next is to do the recording on another Tennsy (let's assume on a 3.2), sending the samples from the 3.2 to the 3.6, hoping that the serial communication will not produce any "queek"s.
#include <TimerOne.h>
#define IN 14
#define OUT A21
#define BSTART 16 // Start button
#define BSTOP 17 // Stop Button
#define AMP 5 // Prop shield amplifier
const uint16_t SAMPLE_RATE = 10000;
const uint8_t SAMPLE_FORMAT = 16;
const uint16_t SAMPLE_COUNT = 32000U;
const uint32_t SAMPLE_INTERVAL = 1000000UL / SAMPLE_RATE;
volatile uint16_t samples[SAMPLE_COUNT]; // recording goes here
// after recording 16000 samples the first half of
// this array is written to the sd card
// this is hearable as a "queek" when recording goes on then
volatile uint32_t which;
volatile uint8_t finished;
uint8_t written;
uint32_t startMicros;
File dataFile;
auto initSamples = [&] { for(volatile uint16_t &s : samples) s = 32768; };
auto waitForever = [] { while(1) ; };
pinMode(13, OUTPUT);
pinMode(AMP, OUTPUT);
pinMode(BSTART, INPUT_PULLUP);
pinMode(BSTOP, INPUT_PULLUP);
analogReadResolution(SAMPLE_FORMAT);
analogWriteResolution(SAMPLE_FORMAT);
Timer1.initialize(SAMPLE_INTERVAL);
delay(2000);
initSamples();
if (!SD.begin(BUILTIN_SDCARD))
Serial.println("SD error!!!");
waitForever();
Serial.println("Press Start Button for recording");
while(digitalRead(BSTART) == HIGH)
if (SD.exists("samples.txt"))
SD.remove("samples.txt");
if (dataFile = SD.open("samples.txt", FILE_WRITE))
which = -1;
finished = 0;
written = 0;
delay(300);
digitalWrite(13, HIGH);
Timer1.attachInterrupt(record);
Serial.println("SD card open failed...");
waitForever();
while(digitalRead(BSTOP) == HIGH)
if (finished != written)
Serial.println(finished);
if (finished == 2)
Timer1.detachInterrupt(); // Stop recording after 32000 samples (2 junks) for test purposes
dataFile.write((uint8_t *)samples+sizeof(samples)/2, sizeof(samples)/2);
break; // Leave loop after 2 chunks
dataFile.write((uint8_t *)samples, sizeof(samples)/2);
written = finished;
Serial.println(".");
//Timer1.detachInterrupt();
dataFile.close();
digitalWrite(13, LOW);
delay(200);
Serial.println("Press Button to read samples from sd card");
Serial.println("Open File for read....");
initSamples();
if (!(dataFile = SD.open("samples.txt", FILE_READ)))
Serial.println("SD file open failed!!!");
waitForever();
} else
uint32_t cnt = dataFile.read((uint8_t *)samples, sizeof(samples));
dataFile.close();
if (cnt != sizeof(samples))
Serial.print("Read failed!!!!");
waitForever();
for(uint16_t i=0; i<10; i++)
Serial.println(samples[i]);
delay(200);
while(1)
Serial.println("Press Button for replay");
digitalWrite(AMP, HIGH);
delay(20);
for (which=0;which<SAMPLE_COUNT;which++) // Replay just for test purposes
analogWrite(OUT, samples[which]);
startMicros = micros();
while (micros() - startMicros < SAMPLE_INTERVAL)
digitalWrite(AMP, LOW);
void record(void)
if (++which == SAMPLE_COUNT)
finished = 2;
which = 0;
if (which == SAMPLE_COUNT/2)
finished = 1;
*(samples+which) = analogRead(IN);
