Results 1 to 6 of 6
Thread: Debugging with Serial.print not working
    I am using this code for toggeling debugging on/off:
    #define DEB_ON
    #ifdef DEB_ON
      #define DEBUG_PRINT(str)  Serial.print(str)
      #define DEBUG_PRINTLN(str)  Serial.println(str)
    #else
    Unfortunately I get a compiling error:
    no matching function for call to 'usb_serial_class::print()'
    for the DEBUG_PRINT line. If I change Serial.print to Serial.println - it works!
    Can somebody explain this to me?
    Thanks, lab
    18,967
    It depends on the code using these macros. That's why we generally expect you to post a complete program (the "Forum Rule").
    Sorry.
    (c) 2014 - Markus Backes - https://backes-markus.de/blog/
    This program is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    //Library includes
    #include <FastLED.h>            // library for ws2812 led arry
    #include <Wire.h>               // library for serial communication
    #include <TimeLib.h>            // library for time handling / needed for RTC and DCF77
    #include <Timezone.h>
    #include <DS3232RTC.h>          // library for DS3231/2 RTC
    #include <IRremote.h>           // library for infrared remote
    //#include "default_layout.h"
    //#include "alt_layout1.h"
    #include "alt_layout2.h"       // alt. layout horizontal alternating row
    // IR defines
    #define ONOFF 0xFF02FD
    #define AUTO 0xFFF00F
    #define BLUE_DOWN 0xFF48B7
    #define BLUE_UP 0xFF6897
    #define BRIGHTER 0xFF3AC5
    #define DIM 0xFFBA45
    #define DIY1 0xFF30CF
    #define DIY2 0xFFB04F
    #define DIY3 0xFF708F
    #define DIY4 0xFF10EF
    #define DIY5 0xFF906F
    #define DIY6 0xFF50AF
    #define FLASH 0xFFD02F
    #define QUICK 0xFFE817
    #define SLOW 0xFFC837
    // Sync timeout
    #define SYNCTIMEOUT 1*1000 // 1min
    // LED defines
    #define NUM_LEDS 114
    // PIN defines
    #define STRIP_DATA_PIN 17 // LED strip
    #define IR_RECV_PIN 11   // IR Receiver
    #define ARDUINO_LED 13   //Default Arduino LED
    #define LDR_PIN 15        // LDR for light level sensing
    // RTC PINs (müssen nicht definiert werden, nur zur Info)
    // SCL 19
    // SDA 18
    // timeout for time sync
    int timestart = millis();
    int timenow = 0;
    boolean timeout = 0;
    boolean forcedcf = 0; // 1 = kein Timeout
    // led array
    uint8_t strip[NUM_LEDS];
    uint8_t stackptr = 0;
    CRGB leds[NUM_LEDS];
    // ir receiver
    IRrecv irrecv = IRrecv(IR_RECV_PIN);
    decode_results irDecodeResults;
    // touch control
    #define TTS 40   // touch threshold
    #define TOUCH_PIN 22  // touch sensor input
    int touchNull = 0;
    int touchDown = 0; // sensor touched
    int touchDuration = 1000;
    int dark = 0;
    long touchTime, touchTimeOff = 0;
    uint8_t selectedLanguageMode = 0;
    const uint8_t RHEIN_RUHR_MODE = 0; //Define?
    const uint8_t WESSI_MODE = 1;
    boolean autoBrightnessEnabled = true;
    // automatic brightness control via ldr
    int newBrightness = 128;
    int oldBrightness = 128;
    int darkBrightness = 0;
    int displayMode = DIY1;
    CRGB defaultColor = CRGB::White;
    uint8_t colorIndex = 0;
    int testHours = 0;
    int testMinutes = 0;
    const unsigned long DEFAULT_TIME = 1506816000; // Oct 1 2017
    // multitasking helper
    const long oneSecondDelay = 1000;
    const long halfSecondDelay = 500;
    long waitUntilRtc = 0;
    long waitUntilParty = 0;
    long waitUntilOff = 0;
    long waitUntilFastTest = 0;
    long waitUntilHeart = 0;
    long waitUntilTree = 0;
    long waitUntilTime = 0;
    long waitUntilLDR = 0;
    // switch
    int modeSwitch = 1;
    // forward declaration
    void fastTest();
    void doTouchLogic();
    void clockLogic();
    void doIRLogic();
    void doLDRLogic();
    void makeParty();
    void off();
    void showHeart();
    void pushToStrip(int ledId);
    void resetAndBlack();
    void resetStrip();
    void displayStripRandomColor();
    void displayStrip();
    void displayStrip(CRGB colorCode);
    void timeToStrip(uint8_t hours,uint8_t minutes);
    void doDCFLogic();
    int baudRate = 115200;
    char unixString[11];
    long unixTime;
    boolean dataSync = false;
    time_t loctime, serialtime, utc;
    #define TIME_HEADER  "T"   // Header tag for serial time sync message
    #define DEB_ON
    #ifdef DEB_ON
    #else
      #ifdef DEB_ON
      pinMode(ARDUINO_LED, OUTPUT);
      pinMode(LDR_PIN, INPUT);
      Serial1.begin(baudRate);
      //setup leds incl. fastled
      for(int i = 0; i<NUM_LEDS; i++) {
        strip[i] = 0;
      FastLED.addLeds<WS2812B, STRIP_DATA_PIN, GRB>(leds, NUM_LEDS);
      resetAndBlack();
      displayStrip();
      // calibrate touch sensor (read value when not touched)
      touchNull = touchRead(TOUCH_PIN);
      // get time from RTC
      setSyncInterval(3600); //every hour
      setSyncProvider(RTC.get);   // the function to get the time from the RTC
      // ende RTC
      //setup ir
      irrecv.enableIRIn();
      readSerial();
      readNTP();
      doLDRLogic();
      doTouchLogic();
      //doIRLogic();
      switch(displayMode) {
        case ONOFF:
          off();
        case DIY1:
          clockLogic();
        case DIY2:
          makeParty();
        case DIY3:
          showHeart();
        case DIY4:
          showTree();
        case DIY5:
          fastTest();
        default:
          clockLogic();
    void readSerial() {
    // read time manually from Terminal (via USB-Serial)
      if (Serial.available()) {
        time_t serialtime = processSyncMessage();
        if (serialtime != 0) {
          // convert unixtime to local time with timeZone lib
          TimeChangeRule mesz = {"MESZ", Last, Mon, Mar, 2, +120};
          TimeChangeRule mez = {"MEZ", Last, Mon, Oct, 3, +60};
          Timezone ger(mesz, mez);
          loctime = ger.toLocal(serialtime);
          RTC.set(loctime);   // set the RTC and the system time to the received value
          setTime(loctime);
    /*  code to process time sync messages from the serial port   */
    unsigned long processSyncMessage() {
      unsigned long pctime = 0L;
      unsigned long loctime;
      TimeChangeRule mesz = {"MESZ", Last, Mon, Mar, 2, +2};
      TimeChangeRule mez = {"MEZ", Last, Mon, Oct, 3, +1};
      if(Serial.find(TIME_HEADER)) {
         pctime = Serial.parseInt();
            RTC.set(pctime);
            Serial.print("Set time to ");
            Serial.println(pctime);
            loctime = ger.toLocal(pctime);
            Serial.print("Set loctime to ");
            Serial.println(loctime);
            return loctime;
             if( pctime < DEFAULT_TIME) { // check the value is a valid time (greater than Jan 1 2013)
               pctime = 0L; // return 0 to indicate that the time is not valid
      return pctime;
    // end serial time setting
    void readNTP() {
      // read time from ESP8266 (via Serial1)
      char buffer[40];
      int i = 0;
      // while the ESP output available, push it
      // into the buffer and set the flag true
      while (Serial1.available()) {
        buffer[i++] = Serial1.read();
        dataSync = true;
      // if data is available, parse it
      if (dataSync == true) {
        if ((buffer[0] == 'U') && (buffer[1] == 'N') && (buffer[2] == 'X')) {
          // if data sent is the UNX token, take it
          unixString[0] = buffer[3];
          unixString[1] = buffer[4];
          unixString[2] = buffer[5];
          unixString[3] = buffer[6];
          unixString[4] = buffer[7];
          unixString[5] = buffer[8];
          unixString[6] = buffer[9];
          unixString[7] = buffer[10];
          unixString[8] = buffer[11];
          unixString[9] = buffer[12];
          unixString[10] = '\0';
          // print the UNX time on the UNO serial
          DEBUG_PRINT();
          DEBUG_PRINTLN("NNTP Time message received form ESP: ");
          DEBUG_PRINT(unixString[0]);
          DEBUG_PRINT(unixString[1]);
          DEBUG_PRINT(unixString[2]);
          DEBUG_PRINT(unixString[3]);
          DEBUG_PRINT(unixString[4]);
          DEBUG_PRINT(unixString[5]);
          DEBUG_PRINT(unixString[6]);
          DEBUG_PRINT(unixString[7]);
          DEBUG_PRINT(unixString[8]);
          DEBUG_PRINT(unixString[9]);
          DEBUG_PRINTLN(unixString[10]);
          unixTime = atol(unixString);
          // Synchronize the time with the internal clock and RTC external clock module
          if (unixTime > DEFAULT_TIME) { // simple check if received time is valid (bigger than default time)
            loctime = ger.toLocal(unixTime);
            DEBUG_PRINT("Unix time: ");
            DEBUG_PRINT (unixTime);
            DEBUG_PRINT(" | Local time: ");
            DEBUG_PRINTLN(loctime);
            setTime(loctime);
            RTC.set(loctime);
            DEBUG_PRINT("NTP time set");
            dataSync = false;
    void digitalClockDisplay(){
      // digital clock display of the time on serial port
      Serial.print(hour());
      printDigits(minute());
      printDigits(second());
      Serial.print(" ");
      Serial.print(day());
      Serial.print(" ");
      Serial.print(month());
      Serial.print(" ");
      Serial.print(year());
    void printDigits(int digits){
      // utility function for digital clock display: prints preceding colon and leading 0
      Serial.print(":");
      if(digits < 10)
        Serial.print('0');
        Serial.print(digits);
    void doTouchLogic() {
        // read touch sensor
        // cycles through display modes
        //DEBUG_PRINT("doing Touch logic");
        //DEBUG_PRINT(touchRead(TOUCH_PIN));
         if (touchRead(TOUCH_PIN) > (touchNull + TTS) && (touchDown==0)) {
          touchTime = millis();
          DEBUG_PRINT(touchTime);
          touchDown = 1;
        if (touchRead(TOUCH_PIN) < (touchNull + TTS) && (touchDown==1)) {
          touchTimeOff = millis();
          DEBUG_PRINT(touchTimeOff);
          if (touchTime + touchDuration < touchTimeOff){
            DEBUG_PRINT("LONG");
            if (dark == 0) {
              //darkBrightness = FastLED.getBrightness();
              //FastLED.setBrightness(0);
              displayMode = 6;
              dark = 1;
              DEBUG_PRINT("Darkness");
            else {
              //FastLED.setBrightness(darkBrightness);
              displayMode = 1;
              dark = 0;
              DEBUG_PRINT("Light");
          else {
            DEBUG_PRINT("SHORT");
            modeSwitch --;
            DEBUG_PRINT("-");
            DEBUG_PRINT(modeSwitch);
          touchDown = 0;
        if (modeSwitch > 5) {
          modeSwitch = 1;
        if (modeSwitch < 1) {
          modeSwitch = 5;
        switch(modeSwitch) {
            case 1:
          // Clock
          displayMode = DIY1;
            case 2:
          // Party
          displayMode = DIY2;
            case 3:
          // Heart
          displayMode = DIY3;
            case 4:
          // Tree
          displayMode = DIY4;
            case 5:
          // Test
          displayMode = DIY5;
          case 6:
          // Test
          displayMode = ONOFF;
            default:
          displayMode = DIY1;
    void doLDRLogic() {
      // reads ambient light value and adjusts display brightness
      if(millis() >= waitUntilLDR && autoBrightnessEnabled) {
        DEBUG_PRINT("doing LDR logic");
        waitUntilLDR = millis();
        int ldrVal = map(analogRead(LDR_PIN), 0, 1000, 150, 0);
        //int ldrVal = analogRead(LDR_PIN);
        const int threshold = 20;
        DEBUG_PRINT("Read:");
        DEBUG_PRINT(analogRead(LDR_PIN));
        int newBrightness = (255-(ldrVal));
        if ((newBrightness > (oldBrightness+threshold)) xor (newBrightness < (oldBrightness-threshold))) {
          FastLED.setBrightness(newBrightness);
          FastLED.show();
          oldBrightness = newBrightness;
        DEBUG_PRINT("Value: ");
        DEBUG_PRINT(ldrVal);
        DEBUG_PRINT(" | Brightness: ");
        DEBUG_PRINTLN(newBrightness);
        waitUntilLDR += oneSecondDelay;
    void doIRLogic() {
      // redas IR remote to change modes and other functions
      uint8_t brightness = 0;
      if (irrecv.decode(&irDecodeResults)) {
        DEBUG_PRINT("Received IR code");
        delay(50);
        switch(irDecodeResults.value) {
          case ONOFF:
          case AUTO:
            autoBrightnessEnabled = !autoBrightnessEnabled;
          case BLUE_DOWN:
            //TODO
          case BLUE_UP:
            //TODO
          case BRIGHTER:
            autoBrightnessEnabled = false;
            brightness = FastLED.getBrightness();
            if(brightness <= 255 - 50) {
              FastLED.setBrightness(brightness + 50);
              FastLED.setBrightness(255);
            FastLED.show();
          case DIM:
            if(brightness >= 50) {
              FastLED.setBrightness(brightness - 50);
            FastLED.show();
          case DIY1:
            displayMode = DIY1;
            //to force display update
            testMinutes = -1;
            testHours = -1;
          case DIY2:
            displayMode = DIY2;
          case DIY3:
            displayMode = DIY3;
          case DIY4:
            displayMode = DIY4;
          case DIY5:
            displayMode = DIY5;
          case DIY6:
            displayMode = DIY6;
          case FLASH:
            displayMode = FLASH;
          case QUICK:
            defaultColor = nextColor();
            displayStrip();
          case SLOW:
            defaultColor = prevColor();
            displayStrip();
          default:
            DEBUG_PRINT("IR DEFAULT");
        irrecv.resume();
    //DISPLAY MODES
    void clockLogic() {
      if(millis() >= waitUntilRtc) {
        DEBUG_PRINT("doing clock logic");
        digitalClockDisplay();
        waitUntilRtc = millis();
        if(testMinutes != minute() || testHours != hour()) {
          testMinutes = minute();
          testHours = hour();
          resetAndBlack();
          timeToStrip(testHours, testMinutes);
          displayStrip(defaultColor);
        waitUntilRtc += oneSecondDelay;
    void off() {
      if(millis() >= waitUntilOff) {
        DEBUG_PRINT("switching off");
        waitUntilOff = millis();
        resetAndBlack();
        displayStrip(CRGB::Black);
        waitUntilOff += halfSecondDelay;
    void makeParty() {
      if(millis() >= waitUntilParty) {
        DEBUG_PRINT("YEAH party party");
        waitUntilParty = millis();
        resetAndBlack();
        for(int i = 0; i<NUM_LEDS;i++) {
          leds[i] = CHSV(random(0, 255), 255, 255);
        FastLED.show();
        waitUntilParty += halfSecondDelay;
    void showHeart() {
      if(millis() >= waitUntilHeart) {
        DEBUG_PRINT("showing heart");
        waitUntilHeart = millis();
        resetAndBlack();
        pushToStrip(L29); pushToStrip(L30); pushToStrip(L70); pushToStrip(L89);
        pushToStrip(L11); pushToStrip(L48); pushToStrip(L68); pushToStrip(L91);
        pushToStrip(L7); pushToStrip(L52); pushToStrip(L107);
        pushToStrip(L6); pushToStrip(L106);
        pushToStrip(L5); pushToStrip(L105);
        pushToStrip(L15); pushToStrip(L95);
        pushToStrip(L23); pushToStrip(L83);
        pushToStrip(L37); pushToStrip(L77);
        pushToStrip(L41); pushToStrip(L61);
        pushToStrip(L59);
        displayStrip(CRGB::Red);
        waitUntilHeart += oneSecondDelay;
    void showTree() {
      if(millis() >= waitUntilTree) {
        DEBUG_PRINT("showing x-mas tree");
        waitUntilTree = millis();
        resetAndBlack();
        pushToStrip(L50); pushToStrip(L48); pushToStrip(L68);
        pushToStrip(L32); pushToStrip(L72); pushToStrip(L33); pushToStrip(L73);
        pushToStrip(L25); pushToStrip(L85);
        pushToStrip(L24); pushToStrip(L84);
        pushToStrip(L16); pushToStrip(L96);
        pushToStrip(L17); pushToStrip(L97);
        pushToStrip(L1); pushToStrip(L18); pushToStrip(L98); pushToStrip(L101);
        pushToStrip(L21); pushToStrip(L38); pushToStrip(L41); pushToStrip(L58); pushToStrip(L61); pushToStrip(L78); pushToStrip(L81);
        pushToStrip(L59);
        displayStrip(CRGB::Green);
        waitUntilTree += oneSecondDelay;
    void fastTest() {
      if(millis() >= waitUntilFastTest) {
        DEBUG_PRINT("running display test");
        waitUntilFastTest = millis();
        if(testMinutes >= 60) {
          testMinutes = 0;
          testHours++;
        if(testHours >= 24) {
          testHours = 0;
        //Array leeren
        resetAndBlack();
        testMinutes++;
        waitUntilFastTest += oneSecondDelay;
    CRGB prevColor() {
      if(colorIndex > 0) {
        colorIndex--;
      return getColorForIndex();
    CRGB nextColor() {
      if(colorIndex < 9) {
        colorIndex++;
    CRGB getColorForIndex() {
      switch(colorIndex) {
        case 0:
          return CRGB::White;
        case 1:
          return CRGB::Blue;
        case 2:
          return CRGB::Aqua;
        case 3:
          return CRGB::Green;
        case 4:
          return CRGB::Lime;
        case 5:
          return CRGB::Red;
        case 6:
          return CRGB::Magenta;
        case 7:
          return CRGB::Olive;
        case 8:
          return CRGB::Yellow;
        case 9:
          return CRGB::Silver;
        default:
          colorIndex = 0;
          return CRGB::White;
    void pushToStrip(int ledId) {
      strip[stackptr] = ledId;
      stackptr++;
    void resetAndBlack() {
      resetStrip();
        leds[i] = CRGB::Black;
    void resetStrip() {
      stackptr = 0;
        strip[i] = 0;
    void displayStripRandomColor() {
      for(int i = 0; i<stackptr; i++) {
        leds[strip[i]] = CHSV(random(0, 255), 255, 255);
      FastLED.show();
    void displayStrip() {
    void displayStrip(CRGB colorCode) {
        leds[strip[i]] = colorCode;
      FastLED.show();
      pushES_IST();
      //show minutes
      if(minutes >= 5 && minutes < 10) {
        pushFUENF1();
        pushNACH();
      } else if(minutes >= 10 && minutes < 15) {
        pushZEHN1();
        pushNACH();
      } else if(minutes >= 15 && minutes < 20) {
        pushVIERTEL();
        pushNACH();
      } else if(minutes >= 20 && minutes < 25) {
        if(selectedLanguageMode == RHEIN_RUHR_MODE) {
          pushZWANZIG();
          pushNACH();
        } else if(selectedLanguageMode == WESSI_MODE) {
          pushZEHN1();
          pushVOR();
          pushHALB();
      } else if(minutes >= 25 && minutes < 30) {
        pushFUENF1();
        pushVOR();
        pushHALB();
      } else if(minutes >= 30 && minutes < 35) {
        pushHALB();
      } else if(minutes >= 35 && minutes < 40) {
        pushFUENF1();
        pushNACH();
        pushHALB();
      } else if(minutes >= 40 && minutes < 45) {
          pushZWANZIG();
          pushVOR();
          pushZEHN1();
          pushNACH();
          pushHALB();
      } else if(minutes >= 45 && minutes < 50) {
        pushVIERTEL();
        pushVOR();
      } else if(minutes >= 50 && minutes < 55) {
        pushZEHN1();
        pushVOR();
      } else if(minutes >= 55 && minutes < 60) {
        pushFUENF1();
        pushVOR();
      int singleMinutes = minutes % 5;
      switch(singleMinutes) {
        case 1:
          pushONE();
        case 2:
          pushONE();
          pushTWO();
        case 3:
          pushONE();
          pushTWO();
          pushTHREE();
        case 4:
          pushONE();
          pushTWO();
          pushTHREE();
          pushFOUR();
      if(hours >= 12) {
        hours -= 12;
        if(minutes >= 25) {
          hours++;
        if(minutes >= 20) {
          hours++;
      if(hours == 12) {
        hours = 0;
      //show hours
      switch(hours) {
        case 0:
          pushZWOELF();
        case 1:
          if(minutes > 4) {
            pushEINS(true);
            pushEINS(false);
        case 2:
          pushZWEI();
        case 3:
          pushDREI();
        case 4:
          pushVIER();
        case 5:
          pushFUENF2();
        case 6:
          pushSECHS();
        case 7:
          pushSIEBEN();
        case 8:
          pushACHT();
        case 9:
          pushNEUN();
        case 10:
          pushZEHN();
        case 11:
          pushELF();
      //show uhr
      if(minutes < 5) {
        pushUHR();
    //PUSH WORD HELPER
    void pushES_IST()  {
      pushToStrip(L9);
      pushToStrip(L10);
      pushToStrip(L30);
      pushToStrip(L49);
      pushToStrip(L50);
    void pushFUENF1() {
      pushToStrip(L70);
      pushToStrip(L89);
      pushToStrip(L90);
      pushToStrip(L109);
    void pushFUENF2() {
      pushToStrip(L74);
      pushToStrip(L85);
      pushToStrip(L94);
      pushToStrip(L105);
    void pushNACH() {
      pushToStrip(L73);
      pushToStrip(L86);
      pushToStrip(L93);
      pushToStrip(L106);
    void pushZEHN1() {
      pushToStrip(L8);
      pushToStrip(L11);
      pushToStrip(L28);
      pushToStrip(L31);
    void pushVIERTEL() {
      pushToStrip(L47);
      pushToStrip(L52);
      pushToStrip(L67);
      pushToStrip(L72);
      pushToStrip(L87);
      pushToStrip(L92);
      pushToStrip(L107);
    void pushVOR() {
      pushToStrip(L6);
      pushToStrip(L13);
      pushToStrip(L26);
    void pushHALB() {
      pushToStrip(L5);
      pushToStrip(L14);
      pushToStrip(L25);
      pushToStrip(L34);
    void pushFUNK() {
      pushToStrip(L33);
      pushToStrip(L46);
      pushToStrip(L53);
      pushToStrip(L66);
    void pushONE() {
      pushToStrip(L113);
    void pushTWO() {
      pushToStrip(L110);
    void pushTHREE() {
      pushToStrip(L111);
    void pushFOUR() {
      pushToStrip(L112);
    void pushZWANZIG() {
      pushToStrip(L48);
      pushToStrip(L51);
      pushToStrip(L68);
      pushToStrip(L71);
      pushToStrip(L88);
      pushToStrip(L91);
      pushToStrip(L108);
    void pushZWOELF() {
      pushToStrip(L61);
      pushToStrip(L78);
      pushToStrip(L81);
      pushToStrip(L98);
      pushToStrip(L101);
    void pushEINS(bool s) {
      pushToStrip(L4);
      pushToStrip(L15);
      pushToStrip(L24);
      if(s) {
        pushToStrip(L35);
    void pushZWEI() {
      pushToStrip(L75);
      pushToStrip(L84);
      pushToStrip(L95);
      pushToStrip(L104);
    void pushDREI() {
      pushToStrip(L3);
      pushToStrip(L16);
      pushToStrip(L23);
      pushToStrip(L36);
    void pushVIER() {
      pushToStrip(L76);
      pushToStrip(L83);
      pushToStrip(L96);
      pushToStrip(L103);
    void pushSECHS() {
      pushToStrip(L2);
      pushToStrip(L17);
      pushToStrip(L22);
      pushToStrip(L37);
      pushToStrip(L42);
    void pushSIEBEN() {
      pushToStrip(L1);
      pushToStrip(L18);
      pushToStrip(L21);
      pushToStrip(L38);
      pushToStrip(L41);
      pushToStrip(L58);
    void pushACHT() {
      pushToStrip(L77);
      pushToStrip(L82);
      pushToStrip(L97);
      pushToStrip(L102);
    void pushNEUN() {
      pushToStrip(L39);
      pushToStrip(L40);
      pushToStrip(L59);
      pushToStrip(L60);
    void pushZEHN() {
      pushToStrip(L0);
      pushToStrip(L19);
      pushToStrip(L20);
      pushToStrip(L39);
    void pushELF() {
      pushToStrip(L54);
      pushToStrip(L65);
      pushToStrip(L74);
    void pushUHR() {
      pushToStrip(L80);
      pushToStrip(L99);
      pushToStrip(L100);
    Mar 2017
    Australia
    7
    The error is probably the empty DEBUG_PRINT(); at line 304.
    Quick compile test:
      Serial.print();
    //  Serial.println();
    This generates a error message like yours. Above that message it also indicates (for me) that the print function requires at least 1 argument. println() did not generate an error.
    18,967
    Yes, indeed Serial.print() requires at least 1 input. This requirement is the same for all Arduino compatible boards. It's not only Teensy.
    Serial.println() can be used without any input. It prints CR and LF (ascii 13 & 10) in that case.
    But Serial.print() without any input has no meaning.
    Lightbulb
    That's it! Forgot about this line.
    Thank's for the help!
    lab
