Results 1 to 25 of 25
Thread: Use Teensy with USB Hub and USB flash drive
    I recently asked a question on a project, where I would need the following setup:
    A teensy, a USB Hub and a USB flash drive. The teensy and the flash drive would go into the hub and the hub is plugged in into the pc.
    Then, the teensy should be able to open a file on the flash drive, and with open I mean using keypresses, so something like:
    Windows + R
    cmd
    j:/testfile.bat
    This generally works, I'm able to program the Teensy to open the file, but the problem is: The flash drive (ofcourse) not always has the same drive letter.
    One approach I already got:
    Quote Originally Posted by Loraty View Post
    Just keep trying D:\myexefile.exe ; E:\myexefile.exe ; F:\myexefile.exe ; etc. Once your executable is running it can easily determine its location if needed.
    But: How can I actually notice, that the exe (or in my first try the testfile.bat) is running, before I keep trying and trying?
    Are there any other ideas, how I could figure out the drive letter of the flash drive? Is there maybe something like a "last plugged in devices-log" where I can ust use the last drive letter?
    Another approach would be to enumerate the drives by bus type. This can narrow the search down to whatever USB drives are connected, then further reduce this by drive/volume name, size and/or contents.
    Quote Originally Posted by MichaelMC View Post
    How could I do this? Infact, I could exclude devices like CD-ROM, the harddrives, etc, and it also would be always the same usb flash drive.
    But how can I determine if it is a usb flash drive and not a harddrive? Or is there a way to to do something like:
    if(file_exists(A:/testfile.bat){
    do something;
    }else if(file_exists(B:/testfile.bat){
    do something
    etc..?
    Also, it would be no problem (talking about drive name) to give the flash drive a specific name which would always be the same and access it with that name, but how would this work?
    Retrieve drive bus type via: (Works for me on Windows7)
    static int getDriveBusType (const int drive)
    	wchar_t buffer[128];
    	__mingw_snwprintf(buffer, 127, L"\\\\.\\%lc:", (wchar_t)(drive&0xFF));
    	HANDLE deviceHandle = CreateFileW(
        	buffer,
    		0,                // no access to the drive
    		FILE_SHARE_READ | FILE_SHARE_WRITE,  // share mode
    		NULL,             // default security attributes
    		OPEN_EXISTING,    // disposition
    		0,                // file attributes
    		NULL);            // do not copy file attributes
    	if (deviceHandle == INVALID_HANDLE_VALUE) return BusTypeUnknown;
    	// setup query
    	STORAGE_PROPERTY_QUERY query;
    	memset(&query, 0, sizeof(query));
    	query.PropertyId = StorageDeviceProperty;
    	query.QueryType = PropertyStandardQuery;
    	// issue query
    	STORAGE_DEVICE_DESCRIPTOR devd;
    	DWORD bytes;
    	STORAGE_BUS_TYPE busType = BusTypeUnknown;
    	if (DeviceIoControl(deviceHandle, IOCTL_STORAGE_QUERY_PROPERTY, &query, sizeof(query), &devd, sizeof(devd), &bytes, NULL))
    		busType = devd.BusType;
    	CloseHandle(deviceHandle);
    	//printf("bustype: %c: %i %X\n", drive&0xFF, devd.RemovableMedia, devd.BusType);
    	return busType;
    int isUsbDrive (const char drive)
    	return getDriveBusType(drive) == BusTypeUsb;
    And to retrieve drive name or other details:
    char *getVolumeLabel (const int drive)
    	size_t blen = MAX_PATH;
    	wchar_t buffer[blen+1];
    	wchar_t driveW[] = {drive&0xFF, ':', '\\', 0};
    	if (GetVolumeInformationW(driveW, buffer, blen, 0, 0, 0, 0, 0))
    		return convertto8(buffer);
    		return NULL;
    What did you pass as drive then?
    Use GetLogicalDriveStrings(). Parse this then take each drive letter, passing that to any of the above funcs.
    19,015
    Whatever you're doing, I really hope it's ethical, "white hat" activity.
    @Paul it is, its for my work, to automize some programs so there is no need to send "well educated people" that know, bho to start a batch file , but only the Hub/Teensy/Flash Drive combination which does everything on its own.
    Sep 2017
    10
    Quote Originally Posted by nameless__ View Post
    Do you have to notice? I know it's sloppy, but those extra commands aren't going to do any harm. Unless your program needs input, of course, but then you could add a little logic to ignore those specific lines.
    @MichaelMC: This is about feeding keyboard input to a PC. You cannot call the Windows API from the Windows command line.
    Exactly the second thing is the case, I need a little input, too. Need to once enter a password and then press "n" two times, so I would need to to this all the time as well, which wouldn't make too much sense I think, so what kind of logic do you mean?
    And yes, somehow the commands from MichaelMC were not working in command line.
    Sep 2017
    10
    I was assuming that you are building the program that's being run as well, and that you'd be able to change it.
    You could use redirection to feed the input to the program:
    myprogram.exe <input.txt
    input.txt contains:
    thepassword
    N
    N
    Not in that kind of way, no...
    And yes, but you mean that I would do like:
    A:/myprogram.exe < input.txt
    B:/myprogram.exe < input.txt
    C:/myprogram.exe < input.txt
    D:/myprogram.exe < input.txt
    and so on, and just don't care, if it would already be A (even if that is really unlikely)?
    Sep 2017
    10
    Pretty much. The input.txt would be on the same disk as the program, so you'd need to specify the drive letter there as well:
    D:\myprogram.exe <D:\input.txt
    I see, I'll give that a try tomorrow Thank you
    Even though I didn't try the input yet, the thing with using every letter in general seems to work (I used a for-loop, started at 97 and added the index of the iteration variable to get a-z).
    But: Is there maybe at least any way to cancel the process of trying after the program was succesfully executed?
    I'll try the input thing now.
    7,373
    It seems Teensy can set and monitor the NumLocks state. If the app when it runs toggles it at start that would say it started - and you could stop or go form there.
    Even though that this is a very interesting idea, it won't work I think.. As I can't change the code of the program executed, how can I toggle the NumLock when it successfully started?
    Germany
    343
    Write a second program and start both?
    In order to do what? You mean the program that I'm trying to start with the Teensy? impossible, I would have to use like half a year to program that.....
    Germany
    343
    In order to do this:
    Okay, I see, and yes, it would be no problem to toggle the NumLock state, but when should I turn it on? I mean how can I know that my program started?
    Germany
    343
    I'd just assume that if the second program (lets call it test.exe) runs that the first (myexefile.exe) runs as well.
    If you really want to check if myexefile.exe runs you can implement code in test.exe which uses the standard windows functions to verify if the process runs. Google for "windows check if process is running". If text.exe finds that myexefile.exe runs it reports back to the Teensy by setting NumLock or sending a serial string or whatever...
    Okay, yes thats an idea, so in the second program, I check if the process with PID whatever (from the first program) is existing/if the first program is running, and if its running, it would somehow report it to the teensy? So far so good, but how could the program then communicate with the Teensy? Or is it possible to read the PID's directly from Teensy?
    Germany
    343
    Just send a string via the com port to the Teensy. And, before you ask: google for "language send string via com port, replace "language" with your favorite programming language
    I'll give it a try, thank you.
