Results 1 to 13 of 13
Thread: Problem FreqCount Lib No read after 12MHz
    Junior Member KE4EST's Avatar
    Nov 2017
    Far Western NC, USA
    8
    Hello All first time poster.
    I have searched and search so I apologize if this has been asked or explained before.
    I am using the FreqCount library that Paul wrote on a teensy 3.5.
    It works really great until after about 10 MHz. Then it starts losing accuracy and then after 12 MHz it starts showing a drop in frequency.
    Hit somewhere around 16-17 MHz and it just shows 0. I am using the library and example just just as Paul has it.
    I am also using the buffer circuit on the same page, only thing different is I am using a 2N2222, but am using a 74HC14.
    Has anyone ran into this? Is my transistor too slow? Wanted to ask before I start changing out parts.
    According to the description the teensy 3.0 and 3.1 show be able to go to 65MHz. Is there something different with the 3.5?
    I need to at least be able to go to 40MHz for the time being, I could use a divider, but wanted to know what is going on?
    Mar 2017
    Colorado Springs, CO
    8
    About a year ago I was experimenting with counting frequency using an Arduino and a Teensy LC. I did not keep great notes but I do recall that I was having problems counting as the frequency was increased. I was also using the buffer circuit similar to what you described. When I quit using the buffer, I was able to reliably count up to 16 MHz with the Teensy LC. The Arduino was only able to get 5 or 6 MHz.
    Nov 2017
    Far Western NC, USA
    8
    Thanks for the reply! Funny how you just posted this and not only 10 minutes ago I bypassed the 74HC14 buffer. Still have the transistor circuit in place but now it is worse, it starts cutting out at around 5 MHz just like an Arduino uno.
    I looked at the data sheet for a 2N2222 and it says it can switch up to 100MHz so I am still at a loss here as to what is going on.
    Nov 2017
    Far Western NC, USA
    8
    OK, getting somewhere here! Using an Si5351 circuit and rotary in encoder on another board as a test I got it to read up to 65MHz.
    I bypassed the circuit all together and fed the signal out of my test setup straight into the pin on the teensy, watching that voltage didn't go over 3.3V.
    Trying other signal sources though it would not read. So an pre-amp still needs to be used, I just have to do some more experimenting.
    17,595
    I just did a test here too, got up to about 65 MHz. I made a video, it's uploading now....
    Edit: here's the test I did.
    Nov 2017
    Far Western NC, USA
    8
    Thank you very much Paul, for making the video and thoroughly checking this out!
    The whole goal here is to make a full homebrew Frequency counter.
    Now if I could just come up with a divider circuit that can handle at least 150MHz.
    I tried the 74HC4017 and after around 50MHz I got erroneous readings, quick look at the data sheet and it said if I recall 49MHz max. Heck the teensy 3.5 can count higher.
    I would like a counter that would be able to got up to at least the 2 meter ham band, but 440 would be nicer.
    17,595
    Maybe something like Digikey 220-1007-ND, if you bypass the PLL and only use its divider & buffers?
    https://www.digikey.com/product-deta...8I/220-1007-ND
    Or perhaps 576-1537-5-ND
    https://www.digikey.com/product-deta.../576-1537-5-ND
    Nov 2017
    Far Western NC, USA
    8
    Thanks Paul. Looking at the data sheets, I really like the first one. I may just give that a try.
    Was hoping for a DIP chip but I can make that work.
    Nov 2017
    Far Western NC, USA
    8
    Paul I have another question. Could the library be optimized for the teensy 3.x boards that are a real 32-bit.
    Or perhaps have a library just for 3.x boards. Just thinking out loud here.
    The accuracy of the counter gets worse the higher in frequency you go, still pretty good for a home-brew counter mind you.
    If I feed it a stable 60MHz signal for example it is reading about 66-68 Hz too low.
    Is this a hardware limitation causing this, or could accuracy be improved using say double instead of float or uint64_t instead of uint32_t in the library ... or am I way off.
    17,595
    Quote Originally Posted by KE4EST View Post
    It already is. 32 bit numbers are used, even on the 8 bit AVR chips.
    Good question. Honestly, Freescale's documentation on the LPTRM timer leaves quite a lot to be desired.
    There's reason to believe it might be doing some sort of clock sync that loses accuracy above F_BUS/2 (which would be 30 MHz).
    The library uses uint32_t, which could count up to 4.29 GHz over a 1 second gate interval, so numerical precision just isn't an issue here.
    Nov 2017
    Far Western NC, USA
    8
    That makes sense. I will just compensate in software.
    Of course, I was just using that as an example, probably not the best. Yes, uint32_t is plenty.
    17,595
    If it really is hardware sampling metastability, there probably isn't any reliable software compensation. The only solution would be keeping the input below 30 MHz (or half of whatever F_BUS speed you use).
    Of course, that's based on a big "if". Freescale's documentation has conflicting and confusing info in this particular case.
    Nov 2017
    Far Western NC, USA
    8
    Thanks for your thoughts. If this is the case that is most likely true.
