Results 1 to 5 of 5
Thread: Cannot flash/upload code to Teensy 2.00
    Nov 2017
    3
    I'm trying to upload code (Even Blink) to Teensy 2.00 (or any other.. I tried) and I cannot find what wrong.
    1. I'm running Ubuntu 16.04 LTS
    2. When I "lsusb" I can see the Teensy
    Bus 002 Device 004: ID 138a:0011 Validity Sensors, Inc. VFS5011 Fingerprint Reader
    Bus 002 Device 050: ID 16c0:0486 Van Ooijen Technische Informatica Teensyduino RawHID
    Bus 002 Device 049: ID 2109:0811 VIA Labs, Inc. Hub
    Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 003 Device 002: ID 046d:c534 Logitech, Inc. Unifying Receiver
    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 001 Device 004: ID 0c45:6486 Microdia
    Bus 001 Device 003: ID 8086:0189 Intel Corp.
    Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    3. It had Blink on it (Never managed to get beyond that point and when I click the Program button it stops blinking
    4. I'm using Teensyduino64bit 1.4 & Arduino 1.8.5 - the installation / integration worked ok - I can see the Teensy boards in the Arduino menu.
    5. If I don't press the program button this is the error that I'm getting: Notice the error sendind reboot command to /dev/bus/usb/002/050
    6. If I'm pressing the button I'm getting the following error:
    7. I'm using high quality USB cable - how do I know that? I'm using it for my DAQ (data acquisition system) at very high sample rates 100MBS/s. I tried other cables as well
    8. I went through the forums and troubleshooting and tried every trick that is written... plug it when holding the programming button and then release, press just when uploading, pouring on it holy water etc.. nothing. I'm open to any other suggestions ideas.
    9. I tried it via a USB hub, native USB port, USB.. same result.
    10. I have Teensy 3.2 and I'm getting the same results.
    11. I have the rules file in place
    12. I tried to run the teensy & the Arduio with root permissions
    Help.
    Maayan
    18,987
    Did you install the udev rule file? That is always required on Linux.
    Is this a genuine Teensy? (purchased from PJRC or any of the official distributors)
    Nov 2017
    3
    Hi mate,
    Thanks for trying to help
    Yep - I wrote in 11 that I have the rules files in place - actually in both locations.
    I have no idea from where it was purchased. I'm trying to help a friend, how do I know if it is a genuine one?
    Cheers
    Maayan
    Apr 2013
    1,837
    Re checking if this is a counterfeit with matched hardware but some hombrew bootloader, first step is check the photo here
    https://www.pjrc.com/store/teensy.html
    The mystery ones vary but check for gold plated through holes, the button and the silkscreen, especially the ones on angles (where knock offs often have right angles only).
    And possibly post a photo of what you have
    Nov 2017
    3
    I see. Thanks. By the looks of things it is a counterfeit.
    I went and got an original one and it works.
    Cheers mates.
    Thanks for all the help. I burned on it couple of hours..
    Maayan
