Ein
I am a miserable beginner, so please be patient with me, but I would very much appreciate help. I have a complex and growing program that displays information on a TFT display using an Arduino (Teensy 3.2, more specifically). I've been trying to tame the situation with some structs, but I'm not sure I'm doing this correctly in order to keep as much as possible in PROGMEM and out of RAM.
Some pseudo-code below to explain what I'm doing:
I have a file I have split all of my graphical data off into called "graphics.h" which I am #including where necessary to utilize its contents. This file has a number of data sets:
These palettes don't correlate 1:1 to the bitmaps, meaning I use one palette for multiple images, rather than one palette per image.
Now, I have been using the data in this file without issue. I am using a variant of the ILI9341_t3 library, which has a 4-bit-per-pixel bitmap writing function that works with the above data types. I have an object from this library that I have named 'tft' and if I want to draw something, I just have to call the writeRect4BPP() function, EX:
The writeRect4BPP function is itself looking for pointers to the bitmap and colorSet:
I set up a struct to organize all of the data sets necessary in my graphics.h file.
I have a function that picks one of these bitmaps from the set based on other logic in the code (the value of an int, basically) and draws that image accordingly:
The thing I'm noticing is that as I increase this in complexity, my program is starting to hang, freeze, lock up, or otherwise show garbage data in other unrelated areas (text output, for example). If I get rid of the conditional statements above and just always write one bitmap from the set (i.e. set1.bitmap1), there are no issues, but once I start adding the conditionals in things get weird.
I'm almost positive this weirdness is resulting from my RAM getting used up. This suggests to me that I may be doing the PROGMEM thing wrong, and that it may be inadvertently grabbing all of the separate bitmap data arrays for each image and trying to hold them in RAM. The actual flash memory is only seeing about 23% usage when I compile.
Can anyone tell me if/how I'm approaching this wrong?
- Multiple sets of 4-bit-per-pixel bitmap data. These are stored in PROGMEM in uint8_t arrays. EX:
const uint8_t bitmap1[] PROGMEM = { 0x00, 0x00... etc ... };
const uint8_t bitmap2[] PROGMEM = { 0xFF, 0XFF... etc ... };
... and so on, and so on. A bunch of these.
- Sets of color palettes, stored in uint32_t arrays, which correlate with the bitmap sets. EX:
const uint32_t colorSet1[] PROGMEM = { 0xFF5A737E, 0XFF64808C... etc ... };
tft.writeRect4BPP(x, y, width, height, bitmap2, colorSet1);
void ILI9341_t3::writeRect4BPP(int16_t x, int16_t y, int16_t w, int16_t h, const uint8_t *pixels, const uint32_t * palette ){}
struct imageSet{
uint8_t *bitmap1;
uint8_t *bitmap2;
uint8_t *bitmap3;
uint8_t *bitmap4;
uint8_t *colorSet};
const imageSet set1 PROGMEM = {bitmap1, bitmap2, bitmap3, bitmap4, colorSet};
if(int == 0){
tft.writeRect4BPP(x, y, width, height, set1.bitmap1, set1.colorSet);
} else if(int == 1){
tft.writeRect4BPP(x, y, width, height, set1.bitmap2, set1.colorSet);
} else if(int == 2){
tft.writeRect4BPP(x, y, width, height, set1.bitmap3, set1.colorSet);
tft.writeRect4BPP(x, y, width, height, set1.bitmap4, set1.colorSet);
