GremlinWrangler
That should certainly work if I'm understanding your plan right. Do watch memory usage since you store all your pixels twice+dead space which may complicate things as you expand this to full size.
You will need to do a fair bit of test pattern work since if I'm understanding your LED mapping right you will most likely have some errors creep into your lookup tables.
