Results 1 to 7 of 7
Thread: Contact microphone pinMode problem
    Nov 2017
    4
    I'm trying to use the "knock" example code on a Teensy 3.2. It works as expected unless I include "pinMode(knockSensor, INPUT);" in the setup in which case the pin hangs on a higher value (different every time) and does not return to 0. Ultimately I'd like to use this in a situation where a single pin will sometimes be used as a button and sometimes as a contact mic input which means I will need to switch the pin mode between INPUT and INPUT_PULLUP otherwise I guess I don't even need to set the pinMode initially.
    What am I doing wrong?
    Feb 2014
    Colmar, France
    2,114
    As the forum rules say: give enough information (code, schematics, etc.) so that others may easily reproduce your problem. IMHO, it is basically not a good idea using one pin with different peripherals and changing the pin configuration “on the fly”. PinMode(x, INPUT) will put the pin into a high Z CMOS logic input which expects defined signals (LOW <=0.3V or HIGH >= 2.7V) fed from outside. If these conditions aren’t satisfied, undefined behavior is the logical consequence.
    18,965
    Quote Originally Posted by bryan5555 View Post
    Maybe you're using analogRead()? That's just a blind guess, but if so, use INPUT_DISABLE to put the pin back to a mode where the digital circuitry (with slight leakage current) is turned off.
    Otherwise, as Theremingenieur explained, the way we work here involves questions that give a complete & clear picture of what you're really doing. Don't "tell" us, actually "show" what you're really doing. We can help much more when we can see what's really going on.
    1,783
    I have used this knock example, https://www.arduino.cc/en/Tutorial/Knock, with piezo vibration sensor to an analog pin with 1 Mohm resitor in parallel to ground. the example works on UNO and T3.2. you have to tap the piezo or place some mass on sensor (e.g., stapler) to detect taps on the table. You don't want to use any pinMode() for the analog pin. (for debugging you could print out the analog value each time through loop() to see how sensitive sensor/mic is)
    vibration sensor: https://www.sparkfun.com/products/10293
    what "mic" are you using?
    Nov 2017
    4
    You're absolutely right - I'll try to provide better information.
    The circuit is as manitou described it- the piezo is between PIN17 and GRD with a 1Mohm resistor between GRD and PIN17. Here's the slightly modified Knock code I'm using which works great
    const int ledPin = 13;      // led connected to digital pin 13
    const int knockSensor = 17; // the piezo is connected to analog pin 0
    const int threshold = 100;  // threshold value to decide when the detected sound is a knock or not
    // these variables will change:
    int sensorReading = 0;      // variable to store the value read from the sensor pin
    int ledState = LOW;         // variable used to store the last LED status, to toggle the light
      pinMode(ledPin, OUTPUT);
    //  pinMode(knockSensor, INPUT);// declare the ledPin as as OUTPUT
      Serial.begin(9600);       // use the serial port
      sensorReading = analogRead(knockSensor);
      Serial.println(sensorReading);
      if (sensorReading >= threshold) {
        ledState = !ledState;
        digitalWrite(ledPin, ledState);
        Serial.println("Knock!");
      delay(100);  // delay to avoid overloading the serial port buffer
    Here's the code that's not working. The only change is that I added in the commented out line " pinMode(knockSensor, INPUT);"
    This time analogRead does not return to 0- it stays at 893 but it's a slightly different number each time.
    --serial window
    1
    1
    2
    3
    2
    1
    7
    1
    1
    1
    888
    Knock!
    893
    Knock!
    893
    Knock!
    893
    Knock!
    893
    Knock!
    893
    Knock!
    893
    Knock!
    --end serial window
    This is not a real world example. I'll make a simple circuit and some code that better illustrates what I'm trying to do and post it here soon. This INPUT_DISABLE business Paul mentioned might be just what I'm looking for.
    as mentioned you don't need to use <<pinMode(knockSensor, INPUT)>> if you use just analogread().
    pinMode(knockSensor, INPUT_DISABLE) is the right way to put pin back to high state before using it for an other purpose.
    Maybe you can also change <<const int knockSensor = 17; // the piezo is connected to analog pin 0>>
    into <<const int knockSensor = A3; // the piezo is connected to analog pin A3 on teensy 3.2>>
    Nov 2017
    4
    Thanks for everyone's help! Here's some test code I came up with using (or trying to use since I don't really understand it) INPUT_DISABLE instead of INPUT. In the end, I may not use this method but I thought I'd put it here for others.
    // testing switching pinMode when using a contact microphone
    // if I indicate pinMode INPUT the values from analogRead stay high.
    // actually if I only tap the mic slightly things are okay but if I
    // give it a good tap it stays around 893 or something high
    int incoming = 0;   // for incoming serial data
    int previousIncoming;
    int reading;
    int ledPin = 13;
    int knockSensor = A1;
    int n0;
    int var = 0;
            Serial.begin(9600);     // opens serial port, sets data rate to 9600 bps
    // This code uses serial input from the serial window
    // 1 switched pinMode to INPUT_PULLUP
    // 2 switches pinMode to INPUT
            if (Serial.available() > 0) {
                    reading = Serial.read();
                    if (reading > 20){
                      incoming = reading;
    // default position -- no pinMode specified
    if (incoming == 0){
      digitalWrite(ledPin, LOW);
      n0 = analogRead(knockSensor);
      Serial.println(n0);
    // Serial input 1 -- pinMode INPUT_DISABLE
    if (incoming == 49){
      if (incoming != previousIncoming){
    //    pinMode(knockSensor, INPUT); // this didn't work
        pinMode(knockSensor, INPUT_DISABLE); // this works!
        previousIncoming = incoming;
        var = 0;
      var++;
      if (var > 1){ // filter out the first reading when the pinMode is changed because I was still getting a high number
    // Serial input 2 -- pinMode INPUT_PULLUP as though I want to use this pin with a button instead of a contact mic now
    if (incoming == 50){
        digitalWrite(ledPin, HIGH);
      pinMode(knockSensor, INPUT_PULLUP);
      n0 = digitalRead(knockSensor);
    Serial.println(n0);
