Results 1 to 11 of 11
Thread: Upload firmware via CANbus
    I am looking at CANbus for a project I am working on and it has been suggested that some MCU's would allow me to distribute firmware updates via CANbus packets (I realise the the protocol is limited to 8 bytes per frame).
    I am thinking I could transfer the code in 8 byte blocks to attached FRAM (via SPI) / EEPROM and then have the Teensy load the new code on reboot. CANbus has pretty solid CRC checking so I would know that each 8 bytes of the firmware has been successfully delivered and stored in FRAM.
    Can I update firmware on the Teensy 3.5/3.6 via CANbus ? If not are there other remote ways to update the runnign firmware on a Teensy ?
    5,187
    PJRC only supports Teensy sketch update over the USB port.
    Others have managed to do code flash updates on T_3.2 - but not seen any notes pass by on T_3.5/3.6 yet?
    Ok thanks. Iíll have to look at ESP32 and STM32 to see if this is possible on them. Itís a shame because I really wanted to be able to support Paulís product.
    Germany
    159
    I managed to use a Teensy as programmer. https://forum.pjrc.com/threads/47783...369#post159369 So, in principle you could connect the programming Teensy to the CAN Bus, transmit the hex file to it and program your Teensy via this programmer. It should also be possible to program more than one Teensy with this setup.
    This is of course by no way an elegant solution but it should work.
    Iíll take a look. Thanks.
    Senior Member Epyon's Avatar
    Apr 2013
    Belgium
    439
    I don't think any of the popular MCU's support uploading code through CAN out of the box. You will need to write you own bootloader for this, just like Paul has done to support uploading code through USB.
    OK - I understand however it is pretty limiting. Anyone who wants to remote deploy one of these then can't manage firmware updates to their code remotely. I have to send someone to site with a laptop and USB cable.
    Apr 2013
    Belgium
    439
    Quote Originally Posted by ilium007 View Post
    And now you have an CAN bus between your desk and all your remote devices?
    Dec 2016
    Canada
    840
    i hope you dont reprogram a motor vehicle while its on the road :P
    Jul 2016
    Denmark
    25
    i have gotten firmware updating to work on t_3.1 t_3.5 and t_3.6 but only with very limited testing, and very few instructions, but you are welcome to have a look
    https://github.com/alex-Arc/Firmware...flash_from_udp
    and the thread about it https://forum.pjrc.com/threads/29607...-updates/page2
    Aug 2017
    2
    Hi
    I had a play with firmware flashing on the teensy 3.6, I found I got quite a few lock ups during the moving of the flash from top halve to bottom halve.
    This only happened when I was compiling the code for cpu speeds higher than 120MHz (like the default 180MHz).
    I was able to fix that by making a local copy of the functions (they are in mk20dx128.c):
    kinetis_hsrun_disable()
    kinetis_hsrun_enable()
    and adding the
    RAMFUNC
    to the front of them. Like this:
    #if defined(HAS_KINETIS_HSRUN) && defined(__MK66FX1M0__) && F_CPU > 120000000
    // This reduce the cpu frequency to 120MHz and disable the HSRUN mode (high speed).
    // This is copied from mk20dx128.c and added the RAMFUNC attrib to make sure its run from RAM.
    RAMFUNC int kinetis_hsrun_disable_RAM(void)
    	if (SMC_PMSTAT == SMC_PMSTAT_HSRUN) {
    		// First, reduce the CPU clock speed, but do not change
    		// the peripheral speed (F_BUS).  Serial1 & Serial2 baud
    		// rates will be impacted, but most other peripherals
    		// will continue functioning at the same speed.
    #if F_CPU == 240000000 && F_BUS == 60000000
    		SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(1, 3, 1, 7); // ok
    #elif F_CPU == 240000000 && F_BUS == 80000000
    		SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(2, 2, 2, 8); // ok
    #elif F_CPU == 240000000 && F_BUS == 120000000
    		SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(1, 1, 1, 7); // ok
    #elif F_CPU == 216000000 && F_BUS == 54000000
    #elif F_CPU == 216000000 && F_BUS == 72000000
    #elif F_CPU == 216000000 && F_BUS == 108000000
    #elif F_CPU == 192000000 && F_BUS == 48000000
    #elif F_CPU == 192000000 && F_BUS == 64000000
    #elif F_CPU == 192000000 && F_BUS == 96000000
    #elif F_CPU == 180000000 && F_BUS == 60000000
    #elif F_CPU == 180000000 && F_BUS == 90000000
    #elif F_CPU == 168000000 && F_BUS == 56000000
    		SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(2, 2, 2, 5); // ok
    #elif F_CPU == 144000000 && F_BUS == 48000000
    #elif F_CPU == 144000000 && F_BUS == 72000000
    		SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(1, 1, 1, 5); // ok
    #else
    		return 0;
    		// Then turn off HSRUN mode
    		SMC_PMCTRL = SMC_PMCTRL_RUNM(0);
    		while (SMC_PMSTAT == SMC_PMSTAT_HSRUN); // wait
    		return 1;
    	return 0;
    RAMFUNC int kinetis_hsrun_enable_RAM(void)
    	if (SMC_PMSTAT == SMC_PMSTAT_RUN) {
    		// Turn HSRUN mode on
    		SMC_PMCTRL = SMC_PMCTRL_RUNM(3);
    		while (SMC_PMSTAT != SMC_PMSTAT_HSRUN) { ; } // wait
    													 // Then configure clock for full speed
    		SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 3, 0, 7);
    		SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 2, 0, 7);
    		SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 1, 0, 7);
    		SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 3, 0, 6);
    		SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 2, 0, 6);
    		SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 1, 0, 6);
    		SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 2, 0, 5);
    		SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 2, 0, 4);
    		SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 1, 0, 4);
    #else
    		return 0;
    		return 1;
    	return 0;
    #else // HAS_KINETIS_HSRUN && F_CPU > 120000000
    __attribute__((always_inline)) static inline int kinetis_hsrun_disable_RAM(void) { return 0; }
    __attribute__((always_inline)) static inline int kinetis_hsrun_enable_RAM(void) { return 0; }
    The problem seemed to have been that those functions (which are only used at cpu speeds > 120MHz) were running from flash memory (which is getting overwritten).
    Does anybody know how to push a function into ram and then run it from there without having to make a copy?
