Arduino-Drum
Project's decription can be found here: http://arduinodrumkit.blogspot.com/
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
//analog Arduino's inputs
const int Pad1 = A0;
const int Pad2 = A1;
const int Pad3 = A2;
const int Pad4 = A3;
const int Pad5 = A4;
//volume threshold variable, being used to determine
//if user stikes the drum pad
const int volumeThreshold = 380;
//variables for volume magnitude of each drum pad
int Drum1_val = 0;
int Drum2_val = 0;
int Drum3_val = 0;
int Drum4_val = 0;
int Drum5_val = 0;
//variables used in program logic
//variables used in proces of separation of vibrtion from
//exact force impact
int signalTest2 = 0;
int signalTest1 = 0;
int signalTest3 = 0;
int signalTest4 = 0;
int signalTest5 = 0;
//midi mapping - addictive drums mapping
byte snareDrum = 38;
byte kick = 36;
byte hihatClosed = 53;
byte crash = 77;
byte hihatOpened = 56;
MIDI.begin(4);
//starts serial communication between arduino na serial USB port
/*1st pad*/
//checks if magnitude of analoginput is higher than volumeThreshold
if(analogRead(Pad1) >= volumeThreshold)
signalTest1 = 1;
//if magnitude of analoginput was higher than volumeThreshold
//program checks again if the signal is decreasing
//if so, it means that drum pad was hit
if(signalTest1 == 1 && analogRead(Pad1) <= (volumeThreshold-100))
//sets the velocity
Drum1_val= analogRead(Pad1);
int velocity = Drum1_val/3 + 78;
if(velocity >= 120)
velocity = 125;
else if(velocity < 0)
velocity = 0;
//sends midi signal over USB serial port
MIDI.sendNoteOn(hihatOpened, velocity, 1);
MIDI.sendNoteOff(hihatOpened, 0, 1);
//sets signalTest again to 0
signalTest1 = 0;
/*2nd pad*/
if(analogRead(Pad2) >= volumeThreshold)
signalTest2 = 1;
Drum2_val = analogRead(Pad2);
if(signalTest2 == 1 && analogRead(Pad2) <= (volumeThreshold-95))
Drum2_val= analogRead(Pad2);
int velocity = Drum2_val/3 + 35;
if(velocity >= 120)
velocity = 125;
velocity = 0;
MIDI.sendNoteOn(snareDrum, velocity, 1);
MIDI.sendNoteOff(snareDrum, 0, 1);
signalTest2 = 0;
/*3rd pad*/
if(analogRead(Pad3) >= volumeThreshold)
signalTest3 = 1;
Drum3_val = analogRead(Pad3);
if(signalTest3 == 1 && analogRead(Pad3) <= (volumeThreshold-95))
Drum3_val= analogRead(Pad3);
int velocity = Drum3_val/2 + 77;
if(velocity >= 120)
velocity = 125;
velocity = 0;
MIDI.sendNoteOn(hihatClosed, velocity, 1);
MIDI.sendNoteOff(hihatClosed, 0, 1);
signalTest3 = 0;
/*4th pad*/
if(analogRead(Pad4) >= volumeThreshold)
signalTest4 = 1;
if(signalTest4 == 1 && analogRead(Pad4) <= (volumeThreshold-95))
Drum4_val= analogRead(Pad4);
int velocity = Drum4_val/3 + 75;
if(velocity > 120)
velocity = 125;
velocity = 0;
MIDI.sendNoteOn(crash, velocity, 1);
MIDI.sendNoteOff(crash, 0, 1);
signalTest4 = 0;
/*5th pad*/
if(analogRead(Pad5) >= volumeThreshold)
signalTest5 = 1;
Drum5_val = analogRead(Pad5);
if(signalTest5 == 1 && analogRead(Pad5) <= (volumeThreshold-95))
int velocity = Drum5_val;
if(velocity >= 12)
velocity = 125;
velocity = 0;
MIDI.sendNoteOn(kick, velocity, 1);
MIDI.sendNoteOff(kick, 0, 1);
signalTest5 = 0;
