Results 1 to 7 of 7
Thread: I2c scanner doesn't find audio board
    Nov 2015
    123
    I have a custom protoboard, all works but the audio board is not recognized... I just ordered a new board, and nothing... The board is not on top of the teensy (see the pic) i have double checked the connections. All is correct.
    I have an LCD with 0x3c address and one ht16k33 with 0x70...
    Nov 2015
    123
    Solved uploading an audio sketch.. the board works fine!
    Senior Member manitou's Avatar
    1,258
    you need the codec on for I2C to be enabled, so to scanner add 2 lines
    AudioOutputI2S audioOutput;
    https://forum.pjrc.com/threads/42814...-shows-nothing
    Nov 2015
    123
    Thanks Manitou
    when i add these two line of code, i get error..
    complete code is
    // I2C Bus Scanner
    // This creates an I2C master device which will scan the address space and report all
    // devices which ACK.  It does not attempt to transfer data, it only reports which devices
    // ACK their address.
    // Pull the control pin low to initiate the scan.  Result will output to Serial.
    // This example code is in the public domain.
    #include <i2c_t3.h>
    // Function prototypes
    void print_scan_status(uint8_t target, uint8_t all);
    uint8_t found, target, all;
        pinMode(LED_BUILTIN,OUTPUT);    // LED
        pinMode(12,INPUT_PULLUP);       // pull pin 12 low to show ACK only results
        pinMode(11,INPUT_PULLUP);       // pull pin 11 low for a more verbose result (shows both ACK and NACK)
        // Setup for Master mode, pins 18/19, external pullups, 400kHz, 10ms default timeout
        Wire.begin(I2C_MASTER, 0x00, I2C_PINS_18_19, I2C_PULLUP_EXT, 400000);
        Wire.setDefaultTimeout(10000); // 10ms
        // Scan I2C addresses
        if(digitalRead(12) == LOW || digitalRead(11) == LOW)
            all = (digitalRead(11) == LOW);
            found = 0;
            Serial.print("---------------------------------------------------\n");
            Serial.print("Starting scan...\n");
            digitalWrite(LED_BUILTIN,HIGH); // LED on
            for(target = 1; target <= 0x7F; target++) // sweep addr, skip general call
                Wire.beginTransmission(target);       // slave addr
                Wire.endTransmission();               // no data, just addr
                print_scan_status(target, all);
            digitalWrite(LED_BUILTIN,LOW); // LED off
            if(!found) Serial.print("No devices found.\n");
            delay(100); // delay to space out tests
    // print scan status
        switch(Wire.status())
        case I2C_WAITING:
            Serial.printf("Addr: 0x%02X ACK\n", target);
            found = 1;
        case I2C_ADDR_NAK:
            if(all) Serial.printf("Addr: 0x%02X\n", target);
        default:
    and... when the audio board is plugged, the lcd remain black
    1,258
    Use the Scanner example from the Wire library. (audio stuff doesn't use i2c_t3)
    Nov 2015
    123
    Works well! 3 device found!
    maybe the black display is a similar problem?
    i use the U8g2 library
    Nov 2015
    123
    With the wire lib the display works fine.
    The U8g2 seems better for fonts/graphics
Tags for this Thread
