Hi!
I'm trying to use Teensy 3.6 + 2 Audio Shields(for quad output) + ILI9341 Color TouchScreen + Ethernet module on W5500 chip via Wiz820io adaptor kit.
Everything in this chain was connected and worked fine until I've connected an Ethernet module and initialized with Ethernet.begin(). The sound from audio adaptor became distorted.
Looking through forum threads I've found an advice changing wiring of pins 11 and 13 of the WIZ820io to pins 7 and 14 on the audio + Teensy board and changing W5100.cpp file. But it doesn't work for me.
Is it possible to connect all these modules to one Teensy 3.6 and use it without conflicts? Hoping somebody can help!
