Hi folks,
I tried to use the Teensy 3.2 together with the OctoWS2811 Adaptor board for some Xmas lights projects using the fastLED library, but I got some nasty flickering. I loaded the code onto the Mega2560, no issues. Any idea folks?
I am using just a little over 1000 12V LEDs WS2811, I applied 12V to three different points using a 2200 uf cap on each point: beginning, in between and at the end, using the same power supply. This is a 600 watts power supply(50A, 12V), this should be enough to power another 1000 LEDs.
Of course, Teensy was powered up by 5 volts. Using 100 LEDs I see no issues.
I played a little bit changing the freq, that did not help.
Thanks a lot.
Thanks a lot.
