The strange SD card behavior
Yannick
Hello all,
Trying to do a data logger, I used Greiman's "TeensySdioDemo.ino" to test File writing with a teensy 3.6 on a 8GB SanDisk Ultra and a 8GB low cost one (I do not remember where it comes from).
I dont need high average speed but continuous writing speed, and therefor I whished to estimate the duration of the busy wait state / write time of the SD, which can induce data lost...
So I modified a litle bit "TeensySdioDemo.ino" to plot the write time for each 32kB block along the file write.
"run test" writes N files of N blocks of N Bytes , each "N" being choosen by the user.
In summary :
- the type of SD card is very very important... (not new)
On the SanDisk busy periods where more frequent but shorter than on the "low cost" card.
- A 10 milli-second pause between block write, improves the write speed of the blocks (not of the file) or decrease busy states occurence/duration.
- I do not find any improvement using pre-allocating/erasing. This said I am not sure to have correctly used the code of "tni" to pre-allocate, pre-erase the file space. "my" durty code is there under attached. If lines 62..78 are wrong, please help me...
View attachment K66-TeensySdioDemo.ino
A few fig of my trials : ( Milli-Seconds in ordinate / 32kBytes Block Number in abscissa. )
I am interested in any Ref of good SD cards...
Thank's in advance. y.
SanDisk not preallocated
SanDisk preallocated : a little bit cleaner at the beginning?
SanDisk not preallocated but a 10mS pause between 32kB block write : Small busy states disappeared...
LowCost not preallocated
LowCost preallocated : I could not allocate more than 4096 blocks on this card, anyway no clear improvment... ( X scale changed )
LowCost not preallocated but a 10mS pause between 32kB block write : the big spike disappeared ( Y scale changed )
You never specify what data rate you require.
As a data point, I record at 256KB/sec with no trouble. But I skipped a file system and libraries.
Thank's UhClem,
32kHz * 8 channels * 2Bytes -> 512kB/S data rate would be perfect...
A 192kB circular buffer would be full after 192/512= 0.375 Secondes acquisition time, or less if I add a time stamp...
Some cards freezes more, so I look for the best way to use these SD cards...
Else I will resign to lost some data...
What do you mean by : " But I skipped a file system and libraries. " ?
Y.
Thank's UhClem,
Shouldn't be a problem unless the file system causes trouble. Imagine what would happen if when allocating a new cluster it had to skip over a large group of clusters already in use.
Write performance improves with larger buffers. If you used six 32KB buffers that would mean while writing one you had five more for data. So there is a tradeoff here. Smaller buffers means you have more usable buffer space in the worst case but lower write speeds. I can think of two ways to work around this but the marginal gain probably isn't worth the effort.
Forth
Thank's again UhClem,
Forth is another story...
In fact I wanted to have a clear idea on the characteristics of the SD cards, best refs..., and of the efficiency of the library.
The best test to answer my concerns is the code of TNI : https://github.com/tni/teensy-samples/blob/master/SdFatSDIO_low_latency_logger.ino
I played with it and when I run it with a total of 192kB buffers and capture data = 16 Bytes at 100kHz, that is 3 times faster than what I really need, everything is OK, no overflow... (Only with my SanDisk card, the other one refuses to be erased!!!)
Thus I do not worry too much.
Y.
