Results 1 to 2 of 2
Thread: Insect in object AudioSynthWaveformSineModulated when no modulation input present.
    Nov 2017
    Belgium
    33
    When no modulation input is present on an AudioSynthWaveformSineModulated object, variable "magnitude" is not taken into account, in other words amplitude has no effect, output is at maximum.
    error in line 195 of /Audio/synth_sine.cpp
    			block->data[i] = (val1 + val2) >> 16;
    fix:
    			block->data[i] = multiply_32x32_rshift32(val1 + val2, magnitude);
    If you prefer bigger chunks of code or the full zipped file, please tell.
    The next piece of code demonstrates the bug and that the fix is working when applied.
    sine_fm1, frequency modulated by sine1, goes to left.
    sine_fm2, with no modulation input, goes to right.
    Every second, amplitude of sine_fm1 & sine_fm2 is toggled between 0 & 1.
    So we should have 1sec of sound and 1sec of silence alternately, which clearly doesn't happen on the second channel.
Name:	Screen Shot 2017-12-10 at 02.57.15.png
    AudioSynthWaveformSine   sine1;          //xy=94,251
    AudioSynthWaveformSineModulated sine_fm1;       //xy=248,251
    AudioSynthWaveformSineModulated sine_fm2;       //xy=248,304
    AudioOutputI2S           i2s1;           //xy=455,257
    AudioOutputAnalogStereo  dacs1;          //xy=456,298
    AudioConnection          patchCord1(sine1, sine_fm1);
    AudioConnection          patchCord2(sine_fm1, 0, i2s1, 0);
    AudioConnection          patchCord3(sine_fm1, 0, dacs1, 0);
    AudioConnection          patchCord4(sine_fm2, 0, i2s1, 1);
    AudioConnection          patchCord5(sine_fm2, 0, dacs1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=104,305
      AudioMemory(20);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.5);
      sine1.frequency(9);
      sine1.amplitude(1.0);
      sine_fm1.frequency(440.0);
      sine_fm1.amplitude(1.0);
      sine_fm2.frequency(440.0);
      sine_fm2.amplitude(1.0);
      sine_fm1.amplitude(0.0);
      sine_fm2.amplitude(0.0);
