Results 1 to 2 of 2
Thread: Insect in AudioSynthWaveform when WAVEFORM_PULSE selected -> wrong frequency.
    Nov 2017
    Belgium
    187
    When selecting WAVEFORM_PULSE in an AudioSynthWaveform object, output frequency is half of what it should be.
    error in line 144 of /Audio/synth_waveform.cpp
            tone_phase += tone_incr;
    fix:
            tone_phase += 2*tone_incr;
    The next piece of code demonstrates the bug and that the fix is working when applied.
    It cycles rapildy trough 5 waveforms playing at a fixed frequency.
    You can clearly hear the WAVEFORM_PULSE drop an octave.
    AudioSynthWaveform       waveform1;      //xy=270,263
    AudioOutputI2S           i2s1;           //xy=455,257
    AudioOutputAnalogStereo  dacs1;          //xy=456,298
    AudioConnection          patchCord1(waveform1, 0, i2s1, 0);
    AudioConnection          patchCord2(waveform1, 0, i2s1, 1);
    AudioConnection          patchCord3(waveform1, 0, dacs1, 0);
    AudioConnection          patchCord4(waveform1, 0, dacs1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=104,305
    int ms = 200;
      AudioMemory(20);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.5);
      waveform1.begin(1.0, 440.0, WAVEFORM_SINE);
      waveform1.pulseWidth(1.0);
      delay(ms);
      waveform1.begin(1.0, 440.0, WAVEFORM_SAWTOOTH);
      delay(ms);
      waveform1.begin(1.0, 440.0, WAVEFORM_SQUARE);
      delay(ms);
      waveform1.begin(1.0, 440.0, WAVEFORM_TRIANGLE);
      delay(ms);
      waveform1.begin(1.0, 440.0, WAVEFORM_PULSE);
      delay(ms);
    There is also an initialisation error in the constructor of AudioSynthWaveform pertaining WAVEFORM_PULSE.
    "tone_width" of type uint_32t is initialised with 0.25, a float which sets it to zero = 100% duty cycle = DC = no sound.
    comment last line of setup() in test program to see or hear the effect.
    I propose to initialise the pulsewidth at 50% duty cycle, which give use a square wave.
    error in line 44 of /Audio/synth_waveform.h
      tone_phase(0), tone_width(0.25), tone_incr(0), tone_type(0),
    fix:
      tone_phase(0), tone_width(0x7fffffffLL), tone_incr(0), tone_type(0),
    Nov 2017
    Belgium
    187
    Please ignore and close this thread, working on a fix with a different approach to resolve frequency and phase inconsistencies.
