Results 1 to 2 of 2
Thread: Proposition to change pulseWidth() behaviour in AudioSynthWaveform object.
    Nov 2017
    Belgium
    31
    current behaviour of pulseWidth(float n):
    n = 0.0 ... 1.0 -> duty cycle = 100% ... 50%
    proposed behaviour of pulseWidth(float n):
    n = 0.0 ... 1.0 -> duty cycle = 0% ... 100%
    I find the current behaviour counter intuitive and limiting. One might argue that you don't hear the difference between 25% an 75% duty cycle and that is true if the AudioSynthWaveform object is used as an audio rate oscillator(generating sounds).
    But other applications need 0% -> 100% duty cycle range.
    For example if used as a function generator.
    Another example would be where WAVEFORM_PULSE is used as a clock generator and is fed into an object that does falling edge detection, modulating the pulseWith would amount to modulating the phase of the clock signal.
    If I understand your explanation from another thread, changing the behaviour of pulseWidth(float n) would be an API change, which is not desirable.
    So I propose to add an new member, void dutyCycle(float n);
    current pulseWidth(float n) code in /Audio/synth_waveform.h:
      void pulseWidth(float n) {          // 0.0 to 1.0
        if (n < 0) n = 0;
        else if (n > 1.0) n = 1.0;
        tone_width = n * 0x7fffffffLL;
        // pulse width is stored as the equivalent phase
    new proposed dutyCycle(float n) code
      void dutyCycle(float n) {          // 0.0 to 1.0
        if (n < 0) n = 0;
        tone_width = (1 - n) * 0xffffffffLL;  //dutycycle 0% -> 100% instead of 100% -> 50%
    below is some code to test the functionality of pulseWitdth().
    this is just a pulseWidth sweep from 0.0 to 1.0 over a period of 2 sec, repeated ad infinitum.
    AudioSynthWaveform       waveform1;      //xy=270,263
    AudioOutputI2S           i2s1;           //xy=455,257
    AudioOutputAnalogStereo  dacs1;          //xy=456,298
    AudioConnection          patchCord1(waveform1, 0, i2s1, 0);
    AudioConnection          patchCord2(waveform1, 0, i2s1, 1);
    AudioConnection          patchCord3(waveform1, 0, dacs1, 0);
    AudioConnection          patchCord4(waveform1, 0, dacs1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=104,305
    int ms = 2;
      AudioMemory(20);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.5);
      waveform1.begin(1.0, 440.0, WAVEFORM_PULSE);
      for(float i=0; i<1.0; i += 0.001){
        waveform1.pulseWidth(i);
        // waveform1.dutyCycle(i);
        delay(ms);
    Nov 2017
    Belgium
    31
    Please ignore and close this thread, I think the above assessment of pulseWidth() behaviour is wrong.
    At the time I did the measurements, I was not aware the line outputs of the audio adapter board are inverted compared to the dac outputs :(
