Teensy 3.6 USB Host MIDI
Nantonos
(earlier posted but in the wrong thread, sorry).
I'm interested in Teensy 3.6 USB Host MIDI read support for a current project, so I extended the 'Test' example to check for reading all of the MIDI messages which seem to be supported. Comments note where there are unsupported messages. Tests run on Arduino 1.8.4 with Teensyduino 1.39 on Windows 10, Teensy 3.6.
Oddly, there was no syntax highlighting for setHandleSysEx() or setHandleRealTimeSystem() although I see those in keywords.txt. Maybe they were later additions than the library I have.
// Test of USB Host receiving MIDI
// This example is in the public domain
#include "USBHost_t36.h"
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHub hub3(myusb);
MIDIDevice midi1(myusb);
	Serial.println("USB Host MIDI Testing");
	myusb.begin();
  // Channel Voice Messages, complete
	midi1.setHandleNoteOff(OnNoteOff);
	midi1.setHandleNoteOn(OnNoteOn);
  midi1.setHandleVelocityChange(OnPolyPressure); // Polyphonic Aftertouch
  midi1.setHandleControlChange(OnControlChange);
  midi1.setHandleProgramChange(OnProgramChange);
  midi1.setHandleAfterTouch(OnAfterTouch);    // Channel Aftertouch
  midi1.setHandlePitchChange(OnPitchChange);
  // Channel Mode Messages, not handled
  // System Common Messages, partial
  midi1.setHandleSysEx(OnSysex);
  midi1.setHandleTimeCodeQuarterFrame(OnTimeCodeQuarterFrame);
  // Song Position Pointer, Song Select, Tune Request unhandled
  // System Real-Time Messages
  midi1.setHandleRealTimeSystem(OnRealTimeSystem);
	myusb.Task(); // I have no idea what that does actually
	midi1.read();
void OnNoteOn(uint8_t channel, uint8_t note, uint8_t velocity)
  if (velocity==0) {
    // Looks like this will never get called, as USBHost_t36 midi.cpp
    // already checks for zero velocity Note On and dispatches Note Off
    Serial.print("Running Status Note Off, ch=");
    Serial.print(channel);
    Serial.print(", note=");
    Serial.print(note);
  else {
	  Serial.print("Note On, ch=");
	  Serial.print(note);
	  Serial.print(", velocity=");
	  Serial.print(velocity);
void OnNoteOff(uint8_t channel, uint8_t note, uint8_t velocity)
	Serial.print("Note Off, ch=");
	Serial.print(note);
	Serial.print(", release velocity=");
void OnPolyPressure(uint8_t channel, uint8_t note, uint8_t pressure)
  Serial.print("Poly Aftertouch, ch=");
  Serial.print(note);
  Serial.print(", pressure=");
  Serial.print(pressure);
void OnControlChange(uint8_t channel, uint8_t control, uint8_t value)
	Serial.print("Control Change, ch=");
	Serial.print(", control=");
	Serial.print(control);
	Serial.print(", value=");
	Serial.print(value);
void OnProgramChange(uint8_t channel, uint8_t patchno)
  Serial.print("Program Change, ch=");
  Serial.print(", patch number=");
  Serial.print(patchno);
void OnAfterTouch(uint8_t channel, uint8_t pressure)
  Serial.print("Channel Aftertouch, ch=");
void OnPitchChange(uint8_t channel, int pitchbend) // int, sigh
  Serial.print("Pitchbend, ch=");
  Serial.print(", pitchbend=");
  Serial.print(pitchbend - 0x2000); // positive and negative bends
void OnSysex(const uint8_t *data, uint16_t length, bool complete)
  Serial.print("Sysex, of length=");
  Serial.print(length);
  (complete)? (Serial.print(" now complete")) : (Serial.print(" still going"));
void OnTimeCodeQuarterFrame(uint16_t data)
  // Should split into first three bits (type) and last 4 (values)
  Serial.print("Time Code, data=");
  Serial.print(data);
void OnRealTimeSystem(uint8_t rtb)
  // See also https://www.midi.org/specifications/item/table-4-universal-system-exclusive-messages
  Serial.print("Realtime, data=");
  Serial.print(rtb);
// MIDI Specification at
// https://www.midi.org/specifications/item/table-1-summary-of-midi-message
// https://www.midi.org/specifications/item/table-2-expanded-messages-list-status-bytes
// See https://github.com/PaulStoffregen/USBHost_t36/blob/master/midi.cpp
// and https://github.com/PaulStoffregen/USBHost_t36/blob/master/USBHost_t36.h
I tested it with a Novation Circuit, which is a pretty simple controller. Here is a dump of the terminal output - fixed velocity NoteOn, mostly, although it also uses some NRPN (cc99, 98 and 6).
Control Change, ch=9, control=98, value=2
Control Change, ch=9, control=6, value=4
Control Change, ch=16, control=111, value=13
Note On, ch=1, note=80, velocity=96
Control Change, ch=16, control=111, value=0
Note On, ch=1, note=77, velocity=96
Note Off, ch=1, note=77, release velocity=0
Note Off, ch=1, note=80, release velocity=0
Note On, ch=1, note=80, velocity=49
Here is a test with the Roli Seaboard controller (in monophonic mode, not tested with MPE mode yet).
And a dump of the terminal output. The Roli sends a constant stream of pitchbend, CC74, and channel aftertouch because each of the rubbery keys is a multidimensional controller. The XY pad and the three slides also seem to send SysEx. The program change buttons send, well, program changes and the octave up/down buttons seem to use NRPN..
Control Change, ch=9, control=74, value=64
Pitchbend, ch=9, pitchbend=0
Note On, ch=9, note=43, velocity=18
Channel Aftertouch, ch=9, pressure=127
Channel Aftertouch, ch=9, pressure=125
Pitchbend, ch=9, pitchbend=-17
Channel Aftertouch, ch=9, pressure=123
Pitchbend, ch=9, pitchbend=2
Channel Aftertouch, ch=9, pressure=121
Channel Aftertouch, ch=9, pressure=119
Channel Aftertouch, ch=9, pressure=117
Channel Aftertouch, ch=9, pressure=115
Channel Aftertouch, ch=9, pressure=113
Note Off, ch=9, note=43, release velocity=30
Note On, ch=9, note=48, velocity=20
Control Change, ch=9, control=74, value=75
Pitchbend, ch=9, pitchbend=-11
Control Change, ch=9, control=74, value=127
Pitchbend, ch=9, pitchbend=-18
Pitchbend, ch=9, pitchbend=41
Pitchbend, ch=9, pitchbend=46
Pitchbend, ch=9, pitchbend=12
Pitchbend, ch=9, pitchbend=-35
Pitchbend, ch=9, pitchbend=24
Pitchbend, ch=9, pitchbend=-13
Channel Aftertouch, ch=9, pressure=111
Note Off, ch=9, note=48, release velocity=49
Note On, ch=9, note=64, velocity=18
Control Change, ch=9, control=74, value=29
Pitchbend, ch=9, pitchbend=16
Control Change, ch=9, control=74, value=34
Control Change, ch=9, control=74, value=35
Control Change, ch=9, control=74, value=13
Control Change, ch=9, control=74, value=9
Control Change, ch=9, control=74, value=47
Control Change, ch=9, control=74, value=114
Pitchbend, ch=9, pitchbend=17
Pitchbend, ch=9, pitchbend=-15
Pitchbend, ch=9, pitchbend=14
Pitchbend, ch=9, pitchbend=-14
Pitchbend, ch=9, pitchbend=13
Pitchbend, ch=9, pitchbend=8
Pitchbend, ch=9, pitchbend=-9
Control Change, ch=9, control=74, value=67
Control Change, ch=9, control=74, value=52
Control Change, ch=9, control=74, value=0
Pitchbend, ch=9, pitchbend=9
Pitchbend, ch=9, pitchbend=-10
Note Off, ch=9, note=64, release velocity=49
Control Change, ch=9, control=113, value=51
Control Change, ch=9, control=114, value=50
Control Change, ch=9, control=113, value=42
Control Change, ch=9, control=114, value=58
Control Change, ch=9, control=113, value=36
Control Change, ch=9, control=114, value=63
Control Change, ch=9, control=113, value=31
Control Change, ch=9, control=114, value=65
Control Change, ch=9, control=113, value=26
Control Change, ch=9, control=114, value=67
Control Change, ch=9, control=113, value=24
Control Change, ch=9, control=114, value=66
Control Change, ch=9, control=113, value=22
Control Change, ch=9, control=113, value=21
Control Change, ch=9, control=113, value=20
Control Change, ch=9, control=114, value=60
Control Change, ch=9, control=113, value=19
Control Change, ch=9, control=114, value=57
Control Change, ch=9, control=114, value=53
Control Change, ch=9, control=113, value=18
Control Change, ch=9, control=114, value=49
Control Change, ch=9, control=114, value=46
Control Change, ch=9, control=114, value=42
Control Change, ch=9, control=114, value=38
Control Change, ch=9, control=114, value=35
Control Change, ch=9, control=113, value=27
Control Change, ch=9, control=114, value=32
Control Change, ch=9, control=113, value=74
Control Change, ch=9, control=114, value=0
Control Change, ch=9, control=113, value=80
Control Change, ch=9, control=113, value=85
Control Change, ch=9, control=114, value=13
Control Change, ch=9, control=113, value=90
Control Change, ch=9, control=114, value=20
Control Change, ch=9, control=113, value=94
Control Change, ch=9, control=114, value=27
Control Change, ch=9, control=113, value=98
Control Change, ch=9, control=114, value=33
Control Change, ch=9, control=113, value=101
Control Change, ch=9, control=114, value=39
Control Change, ch=9, control=113, value=103
Control Change, ch=9, control=114, value=43
Control Change, ch=9, control=113, value=105
Control Change, ch=9, control=114, value=48
Control Change, ch=9, control=113, value=106
Control Change, ch=9, control=114, value=52
Control Change, ch=9, control=114, value=56
Control Change, ch=9, control=114, value=61
Control Change, ch=9, control=113, value=104
Control Change, ch=9, control=114, value=70
Control Change, ch=9, control=113, value=102
Control Change, ch=9, control=114, value=75
Control Change, ch=9, control=113, value=100
Control Change, ch=9, control=114, value=80
Control Change, ch=9, control=113, value=97
Control Change, ch=9, control=114, value=85
Control Change, ch=9, control=114, value=89
Control Change, ch=9, control=114, value=93
Control Change, ch=9, control=114, value=96
Control Change, ch=9, control=114, value=99
Control Change, ch=9, control=113, value=76
Control Change, ch=9, control=114, value=101
Control Change, ch=9, control=113, value=70
Control Change, ch=9, control=114, value=104
Control Change, ch=9, control=113, value=64
Control Change, ch=9, control=114, value=106
Control Change, ch=9, control=113, value=58
Control Change, ch=9, control=114, value=109
Control Change, ch=9, control=113, value=53
Control Change, ch=9, control=114, value=110
Control Change, ch=9, control=113, value=46
Control Change, ch=9, control=114, value=112
Control Change, ch=9, control=113, value=41
Control Change, ch=9, control=114, value=114
Control Change, ch=9, control=113, value=35
Control Change, ch=9, control=114, value=116
Control Change, ch=9, control=113, value=30
Control Change, ch=9, control=114, value=118
Control Change, ch=9, control=113, value=25
Control Change, ch=9, control=114, value=119
Control Change, ch=9, control=113, value=17
Control Change, ch=9, control=113, value=13
Control Change, ch=9, control=114, value=117
Control Change, ch=9, control=114, value=115
Control Change, ch=9, control=114, value=113
Control Change, ch=9, control=113, value=0
Control Change, ch=9, control=113, value=54
Control Change, ch=9, control=114, value=127
Control Change, ch=9, control=113, value=40
Control Change, ch=9, control=113, value=23
Control Change, ch=9, control=114, value=87
Control Change, ch=9, control=113, value=16
Control Change, ch=9, control=114, value=79
Control Change, ch=9, control=113, value=12
Control Change, ch=9, control=114, value=72
Control Change, ch=9, control=114, value=64
Control Change, ch=9, control=114, value=62
Control Change, ch=9, control=113, value=57
Control Change, ch=9, control=113, value=68
Control Change, ch=9, control=113, value=83
Control Change, ch=9, control=114, value=68
Control Change, ch=9, control=113, value=88
Control Change, ch=9, control=113, value=91
Control Change, ch=9, control=114, value=71
Control Change, ch=9, control=114, value=73
Control Change, ch=9, control=113, value=96
Control Change, ch=9, control=114, value=77
Control Change, ch=9, control=113, value=99
Control Change, ch=9, control=114, value=81
Control Change, ch=9, control=114, value=84
Control Change, ch=9, control=114, value=90
Control Change, ch=9, control=114, value=98
Control Change, ch=9, control=113, value=92
Control Change, ch=9, control=114, value=100
Control Change, ch=9, control=113, value=87
Control Change, ch=9, control=113, value=82
Control Change, ch=9, control=114, value=102
Control Change, ch=9, control=113, value=78
Control Change, ch=9, control=114, value=103
Control Change, ch=9, control=113, value=65
Control Change, ch=9, control=113, value=61
Control Change, ch=9, control=113, value=56
Control Change, ch=9, control=113, value=52
Control Change, ch=9, control=113, value=48
Control Change, ch=9, control=113, value=44
Control Change, ch=9, control=113, value=37
Control Change, ch=9, control=114, value=97
Control Change, ch=9, control=114, value=94
Control Change, ch=9, control=113, value=33
Control Change, ch=9, control=114, value=92
Control Change, ch=9, control=114, value=88
Control Change, ch=9, control=113, value=28
Control Change, ch=9, control=114, value=82
Control Change, ch=9, control=114, value=76
Control Change, ch=9, control=113, value=29
Control Change, ch=9, control=113, value=32
Control Change, ch=9, control=114, value=59
Control Change, ch=9, control=113, value=34
Control Change, ch=9, control=114, value=55
Control Change, ch=9, control=114, value=51
Control Change, ch=9, control=114, value=47
Control Change, ch=9, control=113, value=43
Control Change, ch=9, control=113, value=47
Control Change, ch=9, control=114, value=40
Control Change, ch=9, control=114, value=37
Control Change, ch=9, control=113, value=55
Control Change, ch=9, control=113, value=59
Control Change, ch=9, control=113, value=63
Control Change, ch=9, control=113, value=67
Control Change, ch=9, control=113, value=71
Control Change, ch=9, control=113, value=75
Control Change, ch=9, control=114, value=34
Control Change, ch=9, control=114, value=36
Control Change, ch=9, control=113, value=95
Control Change, ch=9, control=114, value=41
Control Change, ch=9, control=113, value=107
Control Change, ch=9, control=113, value=109
Control Change, ch=9, control=113, value=110
Control Change, ch=9, control=114, value=44
Control Change, ch=9, control=113, value=111
Control Change, ch=9, control=114, value=45
Control Change, ch=9, control=113, value=113
Control Change, ch=9, control=113, value=112
Control Change, ch=9, control=114, value=54
Control Change, ch=9, control=113, value=108
Control Change, ch=9, control=113, value=84
Control Change, ch=9, control=114, value=83
Control Change, ch=9, control=114, value=86
Control Change, ch=9, control=113, value=72
Control Change, ch=9, control=113, value=69
Control Change, ch=9, control=114, value=91
Control Change, ch=9, control=113, value=66
Control Change, ch=9, control=113, value=62
Control Change, ch=9, control=114, value=95
Note On, ch=9, note=70, velocity=21
Pitchbend, ch=9, pitchbend=30
Control Change, ch=9, control=74, value=85
Control Change, ch=9, control=74, value=118
Control Change, ch=9, control=74, value=97
Pitchbend, ch=9, pitchbend=-23
Pitchbend, ch=9, pitchbend=21
Pitchbend, ch=9, pitchbend=-39
Pitchbend, ch=9, pitchbend=-5
Note Off, ch=9, note=70, release velocity=64
Sysex, of length=9 now complete
Sysex, of length=6 now complete
Control Change, ch=9, control=99, value=0
Control Change, ch=9, control=6, value=3
Program Change, ch=9, patch number=2
Program Change, ch=9, patch number=3
