I thought I would share this with the group. It's possible someone else already invented the idea, in which case "Never Mind", . Someone might take a look at the code, and see if I have made any glaring mistakes. I'm using Teensy 3.1 and Windows IDE 1.6.13 here.
I've of course been using print() statements for years for debug. However, this is obviously not the best method, and also generally difficult to get historical tracking data. Recently, I ran across an old article that mentioned storing variable values to a debug queue over time, so I implemented it last night.
Basically, I am using a holding buffer with 1000-cells, and modified the millis() ISR to capture and store variable values for a period of time. Then I can display the history of the variable. I trigger sampling off the first change in value of the variable. In the ISR, I use a divider on the msec count to control how often the variable is sampled. It's kind of like a logic-analyzer in software, and works for variables that don't change super-fast.
Amazingly, it actually worked right off!
Eg, the following printout shows variable NumIRdet, which indicates the #of times a pulse from a 56-KHz IR led was detected (part of an alarm system I am building). The tracker stores a value every 10-msec in this case (for 10-sec total history), and triggers (starts storing) on the first change. The 1st cell in the array shows the variable starting value, and the next cell the 1st change.
So, it gets up to 13 pulse detects after about 240-msec. Then the values after the 1st 3-rows show the variable value decaying back to 0 over time, because I have implemented a "leaky integrator" (elsewhere), which automatically decays the value back to zero (at -20% every second), so I needn't explicitly reset it.
The code is shown below. In the final data dump, I built the IR detect count up over several seconds with 3 different activations of the IR Led spaced a couoe of seconds apart.
I've needed something like this for YEARS. Comments or suggestions???
...Show vHold Array...(10-msec sampling)
0,1,1,1,2,2,2,3,3,4,4,4,5,5,6,6,6,7,7,8,
8,8,9,9,10,10,10,11,11,12,12,12,13,13,12,12,12,12,12,12,
12,12,12,12,12,12,12,12,12,12,12,12,12,12,12,12,12,12,12,9,
9,9,9,9,9,9,9,9,9,9,9,9,9,9,9,9,9,9,9,9,
7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,
5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,
4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,
3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,
2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,
2,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,
1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,
1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,1,1,1,2,2,3,3,3,4,4,4,5,5,6,6,6,7,7,8,
8,8,9,9,9,9,9,9,9,9,9,9,9,9,9,9,9,9,9,9,
9,9,9,9,9,9,9,9,9,9,9,7,7,7,7,7,7,7,7,7,
7,7,7,7,7,7,7,7,7,7,7,5,5,5,5,5,5,5,5,5,
5,5,5,6,6,6,7,7,8,8,8,9,9,9,9,9,9,9,9,9,
7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,8,8,8,9,9,
10,10,10,11,11,12,12,12,13,13,12,12,12,12,12,12,12,12,12,12,
12,12,12,12,12,12,12,12,12,12,12,12,12,12,12,12,12,12,12,12,
12,12,12,12,12,12,12,12,12,12,12,12,12,12,12,9,9,9,9,9,
9,9,9,9,9,9,9,9,9,9,9,9,9,9,9,7,7,7,7,7,
7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,5,5,5,5,5,
5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,4,4,4,4,4,
4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,0,0,0,0,0,
- setup tracking in main program:
// following is done in main menu routine:
case 'S': // setup to track variable during sensor run.
setup_tracker(&NumIRdet,10);
...(other setup code)...
case 'H': show_vHold(); break;
// earlier declaration.
#define dbg Serial1
static int vRate=0; //holds msec divider.
/* Initialize variable tracking.
* inputs: var=address of variable to track.
* div=msec_divider.
void setup_tracker( unsigned int *var, int div )
set_vPtr(var,div);
vRate=div;
void show_vHold( void )
dbg.printf("\n...Show vHold Array...(%d-msec sampling)", vRate);
int num=get_vHoldSize();
for( int i=0; i<num; i++) {
if( (i%20) == 0) nl();
dbg.print( get_vHold(i) ); dbg.write(',');
- following code is located in mk20dx128.c, with modified millis() ISR:
(Note: I saved a backup of the .c file before mucking it up).
///// Historical Variable Msec Tracker /////
// added (12/10/17).
#define NUM_VHLD 1000
static volatile unsigned int vHold[NUM_VHLD]; //holds variable history.
static volatile unsigned int *vPtr=NULL; //ptr to variable to store.
static volatile int vNdx=0; //index into history.
static volatile int vCntr=0; //msec divider counter.
static volatile unsigned int vDivide=0; //msec divider.
static volatile unsigned int vStart=0; //start value to match.
static volatile unsigned int vFlag=0; //enable flag.
#if false //relocated to end of kinetis.h (Teensy 3.1).
// (12/10/17) Function Prototypes.
extern void set_vPtr(unsigned int *var,unsigned int vdiv);
extern unsigned int get_vHold(int ndx);
extern int get_vHoldSize(void);
int get_vHoldSize( void )
return( NUM_VHLD );
unsigned int get_vHold( int ndx )
return( vHold[ndx] );
void set_vPtr( unsigned int *var, unsigned int vdiv )
vPtr=var; //point to variable for store.
vStart=*var; //starting value of variable.
vDivide=vdiv; //set msec divider.
vNdx=1; //set index to array start+1.
vCntr=0; //clear msec divide counter.
vFlag=1; //set to start tracking.
// clear holding array.
// NOTE: for() will not compile here ???
//for( int i=0; i<NUM_VHLD; i++) vHold[i]=0;
int i=0;
while( i < NUM_VHLD) vHold[i++]=0;
vHold[0]=vStart;
extern volatile uint32_t systick_millis_count;
/* (12/10/17) modified millis() ISR code.
void systick_default_isr(void)
systick_millis_count++;
// historical variable tracker.
if( vFlag == 1) {
if( *vPtr != vStart) { //trigger tracker.
vFlag=2; //start tracking on first change.
vHold[vNdx++] = *vPtr; //store new variable value.
else if( vFlag == 2) {
if( (++vCntr) >= vDivide) {
vCntr=0; //restart divider.
vHold[vNdx++] = *vPtr; //store variable in buffer.
if( vNdx >= NUM_VHLD) vFlag=0; //stop counting if buffer full.
else { } //do nothing.
#if false //original ISR code.
