Results 1 to 3 of 3
Thread: Class object array
    Class object array
    Hi Guys,
    Using the 'RotaryEncoder' library, by default the example shows instantiating one encoder which has two constructor parameters (pin A, pin B).
    How would I use an array to instantiate 8 encoders and setup arrays so I don't have to copy all the code in the loop for each encoder I use. Please see attached code for reference. I've commented out the attempt of using an array, but that doesn't seem to work.
    Also, here is the class on GitHub for further reference: https://github.com/mathertel/RotaryEncoder.
    Any help would be great.
    #include <RotaryEncoder.h>
    #define ROTARYSTEPS 3
    #define ROTARYMIN 0
    #define ROTARYMAX 127
    //RotaryEncoder encoder[8] = { {7,8} , {9, 10} };
    RotaryEncoder encoder1(7, 8);
    int newPosition = 0;
    int lastPosition = 0;
      //  encoder.setPosition(0 / ROTARYSTEPS); Start Position
      encoder1.tick();
      newPosition = encoder1.getPosition() * ROTARYSTEPS;
      if (newPosition < ROTARYMIN) {
        encoder1.setPosition(ROTARYMIN / ROTARYSTEPS);
        newPosition = ROTARYMIN;
      } else if (newPosition > ROTARYMAX) {
        encoder1.setPosition(ROTARYMAX / ROTARYSTEPS);
        newPosition = ROTARYMAX;
      } // if
      if (lastPosition != newPosition) {
        Serial.print(newPosition);
        lastPosition = newPosition;
    Senior Member brtaylor's Avatar
    Mar 2016
    Portland, OR
    277
    You were close...this works:
    #include "RotaryEncoder.h"
    RotaryEncoder encoder[8] = {RotaryEncoder(7, 8),
                                RotaryEncoder(9, 10),
                                RotaryEncoder(11, 12),
                                RotaryEncoder(13, 14),
                                RotaryEncoder(15, 16),
                                RotaryEncoder(17, 18),
                                RotaryEncoder(19, 20),
                                RotaryEncoder(21, 22)};
    There are also methods using new and pointers or using std::vector, but this approach is straightforward.
    Ahh thank you. I knew I was close, always missing the linking piece. Appreciate it.
