Page 2 of 2 FirstFirst 1 2
Results 26 to 31 of 31
Thread: Error Compiling for Board Teensy 3.6 - McAfee Problem
  1. #26
    Rians in Provence, France
    47
    OK !
    Thanks a lot,
    Pascal Leray
  2. #27
    18,679
    I've updated the MIDI library page with details for the latest version.
    https://www.pjrc.com/teensy/td_libs_MIDI.html
  3. #28
    Feb 2014
    Colmar, France
    2,066
    @Paul: If you are already updating that page, you could fix a few other errors. The Midi.sendPitchBend() function does for example not take a note parameter. Probably copy and paste errors ?
    Here is how it should be : (IMHO)
Name:	Capture d’écran 2017-12-20 à 18.54.52.png
  4. #29
    18,679
    Ok, updated the page. How's it look?
  5. #30
    Feb 2014
    Colmar, France
    2,066
    Looks better. Thank you!
  6. #31
    3,700
    FYI - followup
    I removed McAfee and currently have Norton installed. I had Norton 360 installed on a different machine (my wife's) and had two subscriptions left...
    Now to see if I run into issues here and/or should I add the Arduino install directories to some exclude folder to speed things up...
