Results 1 to 6 of 6
Thread: Record what you Play (Recording the output)
    Dec 2017
    3
    Hi To all, I want to record the output of the audio board, what i am actually hearing through the headphones.
    For exemple, with the synth guitar tutorial, how can i record what i play without any qualiy loss ?
    For now i made a metal jumper beetween line out and line in , by connecting the R and L (As attached). But i was thinking if there was a "Digital" way to record in a most efficient way, whitout any quality loss.
    Thanks.
    Eric
    Senior Member Blackaddr's Avatar
    Mar 2017
    Canada
    176
    You can probably record to the microSD card as a wav file.
    Nov 2017
    16
    I would sort of assume that you could make a patchcord from an output to a recording input in the audio library?
    Dec 2017
    3
    Hi, i try to add a Patchcord but it didnt work
    This is a bit of my code,:
    AudioInputI2S i2s2;
    AudioRecordQueue queue1;
    AudioPlaySdWav playWav1;
    AudioPlaySdWav playWav2;
    AudioPlaySdWav playWav3;
    AudioPlaySdWav playWav4;
    AudioMixer4 mix1;
    AudioOutputI2S headphones;
    AudioOutputAnalog dac;
    AudioConnection c1(playWav1, 0, mix1, 0);
    AudioConnection c2(playWav2, 0, mix1, 1);
    AudioConnection c3(playWav3, 0, mix1, 2);
    AudioConnection c4(playWav4, 0, mix1, 3);
    AudioConnection c11(mix1, 0, headphones, 0);
    AudioConnection c12(mix1, 0, headphones, 1);
    AudioConnection c13(mix1, 0, dac, 0);
    AudioConnection c14(i2s2, 0, queue1, 0);
    And i added this line :
    AudioConnection c15(headphones, 0, i2s2, 0);
    Thanks,
    Eric
    Nov 2017
    16
    The headphones don't have an output. I was more thinking something like
    AudioConnection c11(mix1, 0, i2s2, 0);
    which would run a copy of mix1's output 0 to i2s2's input 0. I think.
    Dec 2017
    3
    Quote Originally Posted by seebs View Post
    I try to add this connection but it doesn't seems to work, i think the i2s2 doesn't have an Audio connection patchcord imput.
