Results 1 to 7 of 7
Thread: Force Sensitive Resistor Momentary switch.
    Dec 2017
    4
    Hi, a question for you all. If I take this https://www.sparkfun.com/products/9673
    and attach the 2 wires from a 3.5mm jack will it work as a switch for this http://stealthswitch3.com/stealthswitch-3/?
    Feb 2014
    Colmar, France
    1,592
    No need for a cpu, just a few resistors, a comparator IC with open collector output, a diode and a small relay...
    Dec 2017
    4
    I already own The stealth switch 3, I just want a new button and was wondering if the Force Sensitive Resistor can be used as I described.
    Feb 2014
    Colmar, France
    1,592
    Without knowing about the internals of the existing stealth switch, I guess that its internal circuitry expects a real switch which has infinite resistance when open and less than 1Ohm when closed. Thus, it is highly improbable that it works with this kind of pressure sensitive variable resistors.
    Dec 2017
    4
    lol I figured it wouldn't be that simple. Ok, then would you know of a momentary switch that has a .4 Oz actuation force or something similar?
    Feb 2014
    Colmar, France
    1,592
    Why not ask the manufacturer for an original spare part?
    Dec 2017
    4
    I will try that. Thank you
