Results 1 to 5 of 5
Thread: Maping sensor data for deeper audio processing resolution
    Dec 2016
    Berlin
    11
    Hallo...;
    I`m trying to map 0 to 1024 sensor values in to a range of 0.001 to 1.0 using the modified map()
    within the Audio Library because a lot of their function parameters expect floating points between 0 and 1.0
    float level = map(float(AnalogValues),0.0 , 1024.0, 0.001, 1.0);
    Serial.println(level);
    //mixer.gain(0, level);
    The Problem I only get values between 0.01 to 0.99 when I try to evaluate it with the Serial Monitor using:
    So loosing 90% of my resoltuion.
    Expected was 0.001 to 1.0 to have 1000 steps for smoother rise of the level-gain.
    Any ideas?
    ThX
    17,596
    I tried just now to test, with this code.
      while (!Serial);
      float x = map(float(1023), 0.0, 1024.0, 0.001, 1.0);
      Serial.println(x);
    When I run this on a Teensy 3.6, it prints "1.00" in the serial monitor.
    Hopefully you can see in this message how we work here. The main thing we do is post complete test programs, which demonstrate the problem. Without a complete program which can be copied into Arduino and run on a real board, we're left with only guesswork about the rest of your code and why it's not working.
    But at least I can confirm that giving integer 1023 as input to that map function produces an output which the normal Serial.print with 2 significant digits does round up to 1.00.
    17,596
    As one more quick test, I tried printing 5 significant digits.
    When I run this program:
      while (!Serial);
      float x = map(float(0), 0.0, 1024.0, 0.001, 1.0);
      Serial.println(x, 5);
    It prints this:
    0.99902
    Dec 2016
    Berlin
    11
    OK....
    THX Paul for the Info with the 5 significant digits:
    17,596
    For this application, assuming your pot has normal linear taper, what you probably want is a logarithmic map function.
    This might be a good start for mapping from 0 - 1023 to 0 - 1.0 in a way that makes sense for audio levels.
    log10f((float)(analogValue) / 113.667 + 1.0)
