Results 1 to 3 of 3
Thread: Teensy 3.2 octows2811
    Dec 2017
    2
    I am trying to get vixen with teensy 3.2 on octows2811 for megatree.
    Couple of questions. When using Arduino I could select which data pin down which strip incase I am using mega tree + arches + others.
    However, when using octo2811
    How do I know which wire in the ethernet cable I should connect to for mega tree, which one for arches
    Mega tree runs 16 strands of ws2811 with 50 pixels each all chained as one long string
    Arch 2 numbers 50 pixels each 2 strings as one chained.
    Can you let me know, how do I wire them and which wire for which item
    Also any working sketch of vixen mega tree for octows2811.
    Jul 2016
    Denmark
    31
    all the info you need about Octo is here https://www.pjrc.com/store/octo28_adaptor.html and her https://www.pjrc.com/teensy/td_libs_OctoWS2811.html
    it looks like vixen can output using USB so check out the octo VideoDisplay example
    or it can output artnet, there are a couple of artnet to octo libarys around
    Dec 2017
    2
    Quote Originally Posted by alex-arc View Post
    I have successfully setup all the components and ran sample wsocto sketches and all works fine. But now I am trying to get the Vixen Serial Com Working. Issues is I send the header and still there is nothing happening.
    [CODE]
    ************************ Heinz Doessegger - www.technikfreak.ch ******************************
    vchristmas v1.0 - Januar 2015
    Dokumentation zum Projekt:
    http://www.technikfreak.ch/category/technik-elektronik/technik-elektronik-projekte/technik-elektronik-projekte-weihnachtsbeleuchtung/
    HARDWARE: TEENSY 3.1 / 3.2
    ARDUINO PLUGIN: TEENSYDUINO mit OctoWS2811 Bibliothek
    http://www.pjrc.com/teensy/td_download.html
    LED: WS2811
    SOFTWARE: Vixen Lights 3.x
    Programm zur Steuerung von WS2811 RGB LED durch Vixen Lights 3.x http://www.vixenlights.com/
    DISPLAY CONFIGURATION - COMx (x = COM Port von Arduino) 115200, None, 8 One
    SEND A TEXT HEADER: VIXStart
    Kanaele: Pro LED braucht es 3 Kanšle (Rot/Gruen/Blau)
    Color Handling: RGB
    TIPP: Fuer Einsteiger
    Zum Start nur mit einer 50er LED Reihe beginnen. ledsPerStrip und PixelCount jeweils auf 50 setzen.
    In Vixen Lights 50 LED Elemente anlegen und ueber das Color Handling RGB auf 150 Ausgaenge mappen.
    #include <OctoWS2811.h>
    const int ledsPerStrip = 800; // Maximale Anzahl Pixel pro Strang
    int PixelCount = 50; // Effektive Anzahl Pixel
    float hell = 0.50; // Dimmer 1.00=100% Helligkeit - 0.50=50% Helligkeit
    DMAMEM int displayMemory[ledsPerStrip*6];
    int drawingMemory[ledsPerStrip*6];
    const int config = WS2811_GRB | WS2811_800kHz;
    OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
    int pixelValue = 0;
    delay(300);
    Serial.begin(115200); // Geschwindigkeit der Datenuebertragung von Vixen Lights 3 zum Arduino
    leds.begin();
    for (int i=0;i<PixelCount;i++) // Initialisierung - Einmalig leuchten alle LED blau
    leds.setPixel(i, 0, 0, 200*hell);
    leds.show();
    delay (5000);
    leds.setPixel(i, 0, 0, 0);
    leds.show();
    if (Serial.available()>5) // Auf Datenuebertragung von Vixen Lights warten
    waitForVixenHeader(); // Funktion aufrufen: Warten auf Startstring
    for (int pixCount=0; pixCount<PixelCount;pixCount++) // Do this for as many Pixels defined in PixelCount
    int RGB[3]; // Array fuer die drei RGB Farbwerte
    for (int color = 0;color<3;color++) // Drei Werte bilden jeweils eine RGB LED
    while (Serial.available() < 1) // Auf die naechste Zahl warten
    delay(10);
    RGB[color] = int(Serial.read()*hell); // Farbwert dem Array zuweisen mit Helligkeitskorrektur
    } // Wiederholen bis alle drei Werte eingelesen sind
    leds.setPixel(pixCount, RGB[1], RGB[0], RGB[2]);
    } // Wiederholen bis alle LED eingelesen sind
    leds.show(); // Farbmuster aktivieren
    //pinMode(13, OUTPUT);
    //digitalWrite(13, HIGH);
    } // Naechstes Farbmuster holen
    } // Schlaufen Ende
    void waitForVixenHeader()
    char *header="VIXStart";
    char buffer[3];
    int index = 0;
    while (true)
    int inByte = Serial.read();
    if(inByte==-1)
    continue;
    buffer[index] = inByte;
    if(buffer[index]!=header[index])
    index=-1;
    buffer[index+1] = 0;
    index++;
    if(index==8)
    return;
Tags for this Thread
