Results 1 to 7 of 7
Thread: PIN compatability Atmega328 -> Teensy++ -> Teensy 3.2
    Dec 2017
    4
    Hi all!
    Im trying to use the Arduino tvout library to output composite video from a Teensy,
    https://playground.arduino.cc/Main/TVout
    the problem is that it looks like the only "teensy" compatible board with the library is the teensy++ according to the tvout library documentation.
    The problem I have is that I need to connect the OC1A and AIN1 pins (from atmega328 and teens+++), but its getting very difficult to know which pins are compatible version on the teensy 3.2.
    So far I found in a webpage that the pin 3 of the teensy 3.2 is the OC1A... but I'm lost on the AIN1... maybe even the pin 3 on my teensy is wrong.
    Any suggestions for my experiments/investigations?
    Dec 2017
    4
    asking this in another way would be:
    what are the compatible PB5 and PF7 pins from teensy++ on the teensy3.2?
    5,173
    You can get some of that from teensy/schematic.html
    Both devices are shown there.
    Dec 2017
    4
    Checked that and pins PB5, PF7, OC1A and AIN1 appear for teensy++2.0 but not for 3.2... I think Im missing something here, its posible those pins are named different on 3.2?
    5,173
    Yeah - I saw that - the architecture is different so accessing the pins will be different.
    16,233
    Maybe this can help?
    https://github.com/qix67/uVGA
    Dec 2017
    4
    thats very nice! but for VGA not composite... anyway thanks for ref to the repo, since I didn't know it exists.
