mjs513
Senior Member+
Not sure if you are going to see the same problem with the T3.6. I ran the i2c at 400Khz and it the IMU just hung no data after a few seconds. Same thing at 1000000 but it worked for a little then hung again. Onehorse mentioned that its a timer issue with i2c_t3 library. Next time I load the sketch up I will give 3.4M a try and see what happens.
