Results 1 to 5 of 5
Thread: Cycles to LDVAL in PIT explanation (IntervalTimer)
    Hi everyone, I was trying to analyze the IntervalTimer function to understand the implementation and its correspondence on the data sheet.
    I cannot understand why the cycles to set on LDVALn (Timer Load VALue register) are dependent on F_BUS in IntervalTimer.h
    Here is the line 53 taken by the file at the path Programs(x86)\Arduino\hardware\teensy\avr\cores\te ensy3\IntervalTimer.h :
    uint32_t cycles = (F_BUS / 1000000) * microseconds - 1;
    By reading at the data sheet (pag 909) it says that the period should be 20 ns = 1/50MHz:
Name:	Schermata 2017-12-16 alle 20.10.22.jpg
    Thus the number of cycles should NOT depend on the bus frequency, but I'm sure I missed something.
    Which relation exists between the formula on the data sheet and the line of code? What am I missing?
    Thanks in advance for any reply, Leo
    Feb 2014
    Colmar, France
    1,461
    There is written "In the example configuration" (which seems to use a F_BUS of 50MHz).
    The PITs are definitively clocked by F_BUS (when not daisy-chained) which is 48MHz when your Teensy 3.2 runs at 96MHz and is only 36MHz when your Teensy 3.2 runs at 72MHz.
    Thank you @Theremingenieur... now I see! (sorry for being such a blind)
Name:	Schermata 2017-12-16 alle 21.53.56.png
    Pag. 902 - PIT Block Diagram
    Feb 2014
    Colmar, France
    1,461
    Devo mandarti i miei occhiali?
    Shall I send you my glasses?
    Oui, merci beaucoup!
    (vive la France)
