Results 1 to 6 of 6
Thread: AudioSynthWaveform object, bug fix and improved phase behaviour
    Nov 2017
    Belgium
    33
    The main motivation for this post is using the Audiolib in a synthesizer application.
    The following modifications were done to the AudioSynthWaveform object in order to fix some errors and improve functionality and behaviour:
    • fix frequency and phase errors
      all waveforms have now the same period, and phase moves all the waveforms in the same direction.
      all waveforms now use 32 bit phase accumulators and count up.
    • invert WAVEFORM_PULSE and fix initialisation error for variable tone_width
    • add new member dutyCycle()
      allows to set the pulsewidth from 0% to 100% instead of 0% to 50% for pulseWidth()
    • enable phase modulation
      this was not possible before, since member phase() restarted the waveform at the absolute phase position
      Phase(), now shifts the waveform from the current phase to the desired phase
      for resetting or starting the waveform at specified phase use begin(), if phase() was set at 90deg before, begin() will restart the waveform at 90deg
    • add new member waveform() for selecting waveforms without affecting the current phase
    Here is the full code for AudioSynthWaveform with comments where I changed stuff, also attached a zip file with all comments removed.
    synth_waveform.zip
    synth_waveform.h
    /* Audio Library for Teensy 3.X
     * Copyright (c) 2014, Paul Stoffregen, paul@pjrc.com
     * Development of this audio library was funded by PJRC.COM, LLC by sales of
     * Teensy and Audio Adaptor boards.  Please support PJRC's efforts to develop
     * open source software by purchasing Teensy or other PJRC products.
     * THE SOFTWARE.
    #ifndef synth_waveform_h_
    #define synth_waveform_h_
    #include "Arduino.h"
    #include "AudioStream.h"
    #include "arm_math.h"
    // waveforms.c
    extern "C" {
    extern const int16_t AudioWaveformSine[257];
    #define AUDIO_SAMPLE_RATE_ROUNDED (44118)
    #define DELAY_PASSTHRU -1
    #define WAVEFORM_SINE      0
    #define WAVEFORM_SAWTOOTH  1
    #define WAVEFORM_SQUARE    2
    #define WAVEFORM_TRIANGLE  3
    #define WAVEFORM_ARBITRARY 4
    #define WAVEFORM_PULSE     5
    #define WAVEFORM_SAWTOOTH_REVERSE 6
    #define WAVEFORM_SAMPLE_HOLD 7
    // todo: remove these...
    #define TONE_TYPE_SINE     0
    #define TONE_TYPE_SAWTOOTH 1
    #define TONE_TYPE_SQUARE   2
    #define TONE_TYPE_TRIANGLE 3
    class AudioSynthWaveform :
    public AudioStream
    public:
      AudioSynthWaveform(void) :
      AudioStream(0,NULL), tone_amp(0), tone_freq(0),
      // tone_phase(0), tone_width(0.25), tone_incr(0), tone_type(0),
      tone_phase(0), tone_phase_offset(0), tone_width(0x7fffffffLL), tone_incr(0), tone_type(0),  //neurofun default pulseWidth 50%, add phase modulation
      tone_offset(0), arbdata(NULL)
      void frequency(float t_freq) {
        if (t_freq < 0.0) t_freq = 0.0;
        else if (t_freq > AUDIO_SAMPLE_RATE_EXACT / 2) t_freq = AUDIO_SAMPLE_RATE_EXACT / 2;
        // tone_incr = (t_freq * (0x80000000LL/AUDIO_SAMPLE_RATE_EXACT)) + 0.5;
        tone_incr = (t_freq * (0x100000000LL/AUDIO_SAMPLE_RATE_EXACT)) + 0.5; //neurofun fix freq & phase errors, 32bit phase acc
      void phase(float angle) {
        if (angle < 0.0) angle = 0.0;
        else if (angle > 360.0) {
          angle = angle - 360.0;
          if (angle >= 360.0) return;
        // tone_phase = angle * (2147483648.0 / 360.0);
        uint32_t phase = angle * (4294967296.0 / 360.0);  //neurofun add phase modulation, fix freq & phase errors, 32bit phase acc
        tone_phase += (phase -tone_phase_offset); //neurofun add phase modulation
        tone_phase_offset = phase; //neurofun add phase modulation
      void amplitude(float n) {        // 0 to 1.0
        if (n < 0) n = 0;
        else if (n > 1.0) n = 1.0;
        if ((tone_amp == 0) && n) {
          // reset the phase when the amplitude was zero
          // and has now been increased.
          tone_phase = 0;
        // set new magnitude
        tone_amp = n * 32767.0;
      void offset(float n) {
        if (n < -1.0) n = -1.0;
        tone_offset = n * 32767.0;
      void pulseWidth(float n) {          // 0.0 to 1.0
        if (n < 0) n = 0;
        tone_width = n * 0x7fffffffLL;
        // pulse width is stored as the equivalent phase
      void dutyCycle(float n) { //neurofun same as pulseWidth() but with full range
        if (n < 0) n = 0;
        tone_width = n * 0xffffffffLL;  //neurofun dutycycle 0% -> 100% instead of 0% -> 50%
      void begin(short t_type) {
    	// tone_phase = 0;
      tone_phase = tone_phase_offset; //neurofun add phase modulation
    	tone_type = t_type;
      void waveform(short t_type) { //neurofun switch waveforms without resetting the phase
    	tone_type = t_type;
      void begin(float t_amp, float t_freq, short t_type) {
    	amplitude(t_amp);
    	frequency(t_freq);
    	begin(t_type);
      void arbitraryWaveform(const int16_t *data, float maxFreq) {
    	arbdata = data;
      virtual void update(void);
    private:
      short    tone_amp;
      short    tone_freq;
      uint32_t tone_phase;
      uint32_t tone_phase_offset; //neurofun add phase modulation
      uint32_t tone_width;
      // sample for SAMPLE_HOLD
      short sample;
      // volatile prevents the compiler optimizing out the frequency function
      volatile uint32_t tone_incr;
      short    tone_type;
      int16_t  tone_offset;
      const int16_t *arbdata;
    synth_waveform.cpp
     * THE SOFTWARE.
    #include "synth_waveform.h"
    #include "utility/dspinst.h"
    // PAH 140415 - change sin to use Paul's interpolation which is much
    //				faster than arm's sin function
    // PAH 140316 - fix calculation of sample (amplitude error)
    // PAH 140314 - change t_hi from int to float
    void AudioSynthWaveform::update(void)
      audio_block_t *block;
      short *bp, *end;
      int32_t val1, val2, val3;
      uint32_t index, scale;
      // temporaries for TRIANGLE
      uint32_t mag;
      short tmp_amp;
      if(tone_amp == 0) return;
      block = allocate();
      if (block) {
        bp = block->data;
        switch(tone_type) {
        case WAVEFORM_SINE:
          for(int i = 0;i < AUDIO_BLOCK_SAMPLES;i++) {
          	// Calculate interpolated sin
    		// index = tone_phase >> 23;
        index = tone_phase >> 24; //neurofun fix freq & phase errors, 32bit phase acc
    		val1 = AudioWaveformSine[index];
    		val2 = AudioWaveformSine[index+1];
    		// scale = (tone_phase >> 7) & 0xFFFF;
        scale = (tone_phase >> 8) & 0xFFFF; //neurofun fix freq & phase errors, 32bit phase acc
    		val2 *= scale;
    		val1 *= 0xFFFF - scale;
    		val3 = (val1 + val2) >> 16;
    		*bp++ = (short)((val3 * tone_amp) >> 15);
            // phase and incr are both unsigned 32-bit fractions
            tone_phase += tone_incr;
            // If tone_phase has overflowed, truncate the top bit
            // if(tone_phase & 0x80000000)tone_phase &= 0x7fffffff; //neurofun fix freq & phase errors, 32bit phase acc
        case WAVEFORM_ARBITRARY:
          if (!arbdata) {
    		release(block);
    		return;
          // len = 256
          for (int i = 0; i < AUDIO_BLOCK_SAMPLES;i++) {
    		val1 = *(arbdata + index);
    		val2 = *(arbdata + ((index + 1) & 255));
    		val2 *= scale;
    		// tone_phase &= 0x7fffffff; //neurofun fix freq & phase errors, 32bit phase acc
        case WAVEFORM_SQUARE:
            // if(tone_phase & 0x40000000)*bp++ = -tone_amp;
            if(tone_phase & 0x80000000)*bp++ = -tone_amp; //neurofun fix freq & phase errors, 32bit phase acc
            else *bp++ = tone_amp;
        case WAVEFORM_SAWTOOTH:
            // *bp++ = ((short)(tone_phase>>15)*tone_amp) >> 15;
            *bp++ = ((short)(tone_phase>>16)*tone_amp) >> 15; //neurofun fix freq & phase errors, 32bit phase acc
        case WAVEFORM_SAWTOOTH_REVERSE:
            *bp++ = -((short)(tone_phase>>16)*tone_amp) >> 15; //neurofun fix freq & phase errors, 32bit phase acc
             // tone_phase -= tone_incr;
             tone_phase += tone_incr; //neurofun fix freq & phase errors, 32bit phase acc
        case WAVEFORM_TRIANGLE:
            if(tone_phase & 0x80000000) {
              // negative half-cycle
              tmp_amp = -tone_amp;
            else {
              // positive half-cycle
              tmp_amp = tone_amp;
            mag = tone_phase << 2;
            // Determine which quadrant
            if(tone_phase & 0x40000000) {
              // negate the magnitude
              mag = ~mag + 1;
            *bp++ = ((short)(mag>>17)*tmp_amp) >> 15;
            // tone_phase += 2*tone_incr;
        case WAVEFORM_PULSE:
            // if(tone_phase < tone_width)*bp++ = -tone_amp;
            // else *bp++ = tone_amp;
            if(tone_phase < tone_width)*bp++ = tone_amp;  //neurofun invert WAVEFORM_PULSE
            else *bp++ = -tone_amp;  //neurofun invert WAVEFORM_PULSE
        case WAVEFORM_SAMPLE_HOLD:
            if(tone_phase < tone_incr) {
              sample = random(-tone_amp, tone_amp);
            *bp++ = sample;
        if (tone_offset) {
    	bp = block->data;
    	end = bp + AUDIO_BLOCK_SAMPLES;
    	do {
    		val1 = *bp;
    		*bp++ = signed_saturate_rshift(val1 + tone_offset, 16, 0);
    	} while (bp < end);
        transmit(block,0);
        release(block);
    The following test program is meant to be used with an oscilloscope. It will show that all waveforms have same period and behave exactly the same way when changing the phase.
    Connect dac0 or left to channel 1 and dac1 or right to channel 2 of your scope and select channel 1 as source for the trigger.
    Channel1 gives you a 500hz reference square wave.
    Channel2 will cycle through all the waveforms and sweep the phase in the following pattern,
    0deg->360deg->90deg->180deg->0deg
    AudioControlSGTL5000     sgtl5000_1;
    AudioSynthWaveform       waveform1;
    AudioSynthWaveform       waveform2;
    AudioOutputI2S           audioOutput;
    AudioOutputAnalogStereo  dacs1;
    AudioConnection          patchCord1(waveform1, 0, audioOutput, 0);
    AudioConnection          patchCord2(waveform2, 0, audioOutput, 1);
    AudioConnection          patchCord3(waveform1, 0, dacs1, 0);
    AudioConnection          patchCord4(waveform2, 0, dacs1, 1);
    int wave_type[] = {
      WAVEFORM_SINE,
      WAVEFORM_TRIANGLE,
      WAVEFORM_SAWTOOTH,
      WAVEFORM_SAWTOOTH_REVERSE,
      WAVEFORM_SQUARE,
      WAVEFORM_PULSE,
      WAVEFORM_SAMPLE_HOLD,
      WAVEFORM_ARBITRARY,
    String wave_name[] = {
      "WAVEFORM_SINE",
      "WAVEFORM_TRIANGLE",
      "WAVEFORM_SAWTOOTH",
      "WAVEFORM_SAWTOOTH_REVERSE",
      "WAVEFORM_SQUARE",
      "WAVEFORM_PULSE",
      "WAVEFORM_SAMPLE_HOLD",
      "WAVEFORM_ARBITRARY",
      Serial.begin(250000);
      AudioMemory(20);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.5);
      waveform1.amplitude(1);
      waveform2.amplitude(1);
      waveform1.pulseWidth(.5);
      waveform2.pulseWidth(.5);
      waveform1.arbitraryWaveform(AudioWaveformSine, 0);
      waveform2.arbitraryWaveform(AudioWaveformSine, 0);
      waveform1.frequency(500);
      waveform2.frequency(500);
      for (int j = 0; j < sizeof(wave_type) / sizeof(wave_type[0]); j++) {
        Serial.println(wave_name[j]);
        waveform1.begin(wave_type[4]);
        waveform2.begin(wave_type[j]);
        delay(2000);
        for(float p = 0; p <= 360; p++){
          AudioNoInterrupts();
          waveform2.phase(p);
          AudioInterrupts();
          delay(5);
        for(float p = 360; p >= 90; p--){
          waveform2.phase(p);
          AudioInterrupts();
          delay(1);
        for(float p = 90; p <= 180; p++){
          waveform2.phase(p);
          AudioInterrupts();
          delay(2);
        delay(2000);
        for(float p = 180; p >= 0; p--){
          waveform2.phase(p);
          AudioInterrupts();
          delay(5);
    And here is a youtube video showing the output of the test program on a scope. First half of video is before the code update, second half is after the update:
    https://youtu.be/VUCSt4CYFYQ
    Any comments welcome.
    Nov 2017
    Belgium
    33
    Here is an example of a cool effect you can do with phase modulation.
    Some kind of mutant quadrature oscillator with 4 outputs, of which each phase is evenly distanced, modulating the freq of 4 sine waves.
    The only modulation happening in the code, is an up and down sweep of the phase.
    This is also an example on how to use arrays of audiolib objects, which can make life quite easy.
Name:	Screen Shot 2017-12-18 at 01.54.30.png
    //example for phase modulation
    // AudioSynthWaveform       waveform[0];      //xy=277,194
    // AudioSynthWaveform       waveform[1]; //xy=283,235
    // AudioSynthWaveform       waveform[2]; //xy=288,276
    // AudioSynthWaveform       waveform[3]; //xy=293,317
    // AudioSynthWaveformSineModulated sine_fm[0];       //xy=437,199
    // AudioSynthWaveformSineModulated sine_fm[1]; //xy=443,240
    // AudioSynthWaveformSineModulated sine_fm[2]; //xy=448,281
    // AudioSynthWaveformSineModulated sine_fm[3]; //xy=453,322
    AudioSynthWaveform*  waveform = new AudioSynthWaveform[4];  //not automatically generated code
    AudioSynthWaveformSineModulated*  sine_fm = new AudioSynthWaveformSineModulated[4];  //not automatically generated code
    AudioMixer4              mixer1;         //xy=630,252
    AudioOutputI2S           i2s1;           //xy=776,259
    AudioConnection          patchCord1(waveform[0], sine_fm[0]);
    AudioConnection          patchCord2(waveform[1], sine_fm[1]);
    AudioConnection          patchCord3(waveform[2], sine_fm[2]);
    AudioConnection          patchCord4(waveform[3], sine_fm[3]);
    AudioConnection          patchCord5(sine_fm[0], 0, mixer1, 0);
    AudioConnection          patchCord6(sine_fm[1], 0, mixer1, 1);
    AudioConnection          patchCord7(sine_fm[2], 0, mixer1, 2);
    AudioConnection          patchCord8(sine_fm[3], 0, mixer1, 3);
    AudioConnection          patchCord9(mixer1, 0, i2s1, 0);
    AudioConnection          patchCord10(mixer1, 0, i2s1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=630,319
      AudioMemory(20);
      for(int i = 0; i < 4; i++) {
        mixer1.gain(i, 0.25);
      Serial.println("sirens in the city");
      phaseSweep(WAVEFORM_SINE, .1, 3, 1000, 0, 90, 0.05, 0.05); //sirens in the city
      Serial.println("red alert");
      phaseSweep(WAVEFORM_SAWTOOTH, 0.9, .75, 500, 0, 90, 0.05, 0.5); //red alert
      Serial.println("helicopter flyby");
      phaseSweep(WAVEFORM_SAWTOOTH_REVERSE, 0.9, 20, 200, 5, 50, 0.05, 0.05); //helicopter flyby
      Serial.println("etheral winds");
      phaseSweep(WAVEFORM_SINE, 1.0, 0.01, 300, 0, 90, 0.01, 0.05);  //etheral winds
    void phaseSweep(short t_type, float ampl_lfo, float freq_lfo, float freq_vco, float from_phase, float to_phase, float step_up, float step_down){
      //initialise lfo's & vco's
        waveform[i].amplitude(ampl_lfo);
        waveform[i].frequency(freq_lfo);
        waveform[i].begin(t_type);
        waveform[i].phase(from_phase);
        sine_fm[i].amplitude(1);
        sine_fm[i].frequency(freq_vco);
      waveform[0].phase(0); //phase of lfo0 always 0
      delay(2000);
      //sweep up phase of lfo's
      Serial.println("phase up");
      for(float p = from_phase; p <= to_phase; p+=step_up){
        for (int i = 1; i < 4; i++) {
          waveform[i].phase(p * i);
        AudioInterrupts();
        delay(10);
        Serial.print("phase up ");
        Serial.println(p);
      Serial.println("phase steady");
      delay(2000);
      //sweep down phase of lfo's
      Serial.println("phase down");
      for(float p = to_phase; p >= from_phase; p-=step_down){
        AudioInterrupts();
        delay(10);
        Serial.print("phase down ");
        Serial.println(p);
      delay(2000);
    Apr 2017
    7
    I take it that this is "use at your own risk"? I was wondering if anyone else has used this yet, as I'm currently working on an LFO module for eurorack, and just discovered the current functionality of pulseWidth. This could definitely solve my issue, as I was hoping to set up a range from 0.01 to 0.99 duty cycle. I'd like to hear from others, but I'm extremely tempted to try it.
    As a side note, i should mention for those wondering how I could use the Audio Shield for an LFO; I simply replaced the 2.2uF output caps with 0 ohm jumpers and am running the line out into summing op-amps where I level-shift the signal to be AC, works perfectly. It's coming along well, I'll try to post a new thread when I get closer to it being ready to go in my rack.
    Apr 2017
    7
    Oops, just realized Neurofun posted this today, so I'll ask him: how comfortable are you with others using this at this point? I get the impression from your posts that you've done a fair amount of testing.
    Nov 2017
    Belgium
    33
    I am fairly confident it will work and yes, I did a fair amount of testing but there is still the possibility that I overlooked something, so it would be nice for someone else to test it out and confirm it works as intended.
    As for "use at your own risk", worst case scenario is that it doesn't work as expected. In that case, just revert to the original code.
    As long as you don't use it to generate signals that control life critical applications, I don't see any problems.
    Apr 2017
    7
    Well, so far, so good! I substituted the library, and dutyCycle does exactly what i wanted. As I am using this as a CV for other modules, having the full range was critical. My application is fairly basic, so I'm sure this won't be the full workout you would like from others, but I'm excited that I can now get exactly what I need. Thanks for doing this.
