The main motivation for this post is using the Audiolib in a synthesizer application.
The following modifications were done to the AudioSynthWaveform object in order to fix some errors and improve functionality and behaviour:
- fix frequency and phase errors
all waveforms have now the same period, and phase moves all the waveforms in the same direction.
all waveforms now use 32 bit phase accumulators and count up.
- invert WAVEFORM_PULSE and fix initialisation error for variable tone_width
- add new member dutyCycle()
allows to set the pulsewidth from 0% to 100% instead of 0% to 50% for pulseWidth()
- enable phase modulation
this was not possible before, since member phase() restarted the waveform at the absolute phase position
Phase(), now shifts the waveform from the current phase to the desired phase
for resetting or starting the waveform at specified phase use begin(), if phase() was set at 90deg before, begin() will restart the waveform at 90deg
- add new member waveform() for selecting waveforms without affecting the current phase
Here is the full code for AudioSynthWaveform with comments where I changed stuff, also attached a zip file with all comments removed.
synth_waveform.zip
synth_waveform.h
/* Audio Library for Teensy 3.X
* Copyright (c) 2014, Paul Stoffregen, paul@pjrc.com
* Development of this audio library was funded by PJRC.COM, LLC by sales of
* Teensy and Audio Adaptor boards. Please support PJRC's efforts to develop
* open source software by purchasing Teensy or other PJRC products.
* THE SOFTWARE.
#ifndef synth_waveform_h_
#define synth_waveform_h_
#include "Arduino.h"
#include "AudioStream.h"
#include "arm_math.h"
// waveforms.c
extern "C" {
extern const int16_t AudioWaveformSine[257];
#define AUDIO_SAMPLE_RATE_ROUNDED (44118)
#define DELAY_PASSTHRU -1
#define WAVEFORM_SINE 0
#define WAVEFORM_SAWTOOTH 1
#define WAVEFORM_SQUARE 2
#define WAVEFORM_TRIANGLE 3
#define WAVEFORM_ARBITRARY 4
#define WAVEFORM_PULSE 5
#define WAVEFORM_SAWTOOTH_REVERSE 6
#define WAVEFORM_SAMPLE_HOLD 7
// todo: remove these...
#define TONE_TYPE_SINE 0
#define TONE_TYPE_SAWTOOTH 1
#define TONE_TYPE_SQUARE 2
#define TONE_TYPE_TRIANGLE 3
class AudioSynthWaveform :
public AudioStream
public:
AudioSynthWaveform(void) :
AudioStream(0,NULL), tone_amp(0), tone_freq(0),
// tone_phase(0), tone_width(0.25), tone_incr(0), tone_type(0),
tone_phase(0), tone_phase_offset(0), tone_width(0x7fffffffLL), tone_incr(0), tone_type(0), //neurofun default pulseWidth 50%, add phase modulation
tone_offset(0), arbdata(NULL)
void frequency(float t_freq) {
if (t_freq < 0.0) t_freq = 0.0;
else if (t_freq > AUDIO_SAMPLE_RATE_EXACT / 2) t_freq = AUDIO_SAMPLE_RATE_EXACT / 2;
// tone_incr = (t_freq * (0x80000000LL/AUDIO_SAMPLE_RATE_EXACT)) + 0.5;
tone_incr = (t_freq * (0x100000000LL/AUDIO_SAMPLE_RATE_EXACT)) + 0.5; //neurofun fix freq & phase errors, 32bit phase acc
void phase(float angle) {
if (angle < 0.0) angle = 0.0;
else if (angle > 360.0) {
angle = angle - 360.0;
if (angle >= 360.0) return;
// tone_phase = angle * (2147483648.0 / 360.0);
uint32_t phase = angle * (4294967296.0 / 360.0); //neurofun add phase modulation, fix freq & phase errors, 32bit phase acc
tone_phase += (phase -tone_phase_offset); //neurofun add phase modulation
tone_phase_offset = phase; //neurofun add phase modulation
void amplitude(float n) { // 0 to 1.0
if (n < 0) n = 0;
else if (n > 1.0) n = 1.0;
if ((tone_amp == 0) && n) {
// reset the phase when the amplitude was zero
// and has now been increased.
tone_phase = 0;
// set new magnitude
tone_amp = n * 32767.0;
void offset(float n) {
if (n < -1.0) n = -1.0;
tone_offset = n * 32767.0;
void pulseWidth(float n) { // 0.0 to 1.0
if (n < 0) n = 0;
tone_width = n * 0x7fffffffLL;
// pulse width is stored as the equivalent phase
void dutyCycle(float n) { //neurofun same as pulseWidth() but with full range
if (n < 0) n = 0;
tone_width = n * 0xffffffffLL; //neurofun dutycycle 0% -> 100% instead of 0% -> 50%
void begin(short t_type) {
// tone_phase = 0;
tone_phase = tone_phase_offset; //neurofun add phase modulation
tone_type = t_type;
void waveform(short t_type) { //neurofun switch waveforms without resetting the phase
tone_type = t_type;
void begin(float t_amp, float t_freq, short t_type) {
amplitude(t_amp);
frequency(t_freq);
begin(t_type);
void arbitraryWaveform(const int16_t *data, float maxFreq) {
arbdata = data;
virtual void update(void);
private:
short tone_amp;
short tone_freq;
uint32_t tone_phase;
uint32_t tone_phase_offset; //neurofun add phase modulation
uint32_t tone_width;
// sample for SAMPLE_HOLD
short sample;
// volatile prevents the compiler optimizing out the frequency function
volatile uint32_t tone_incr;
short tone_type;
int16_t tone_offset;
const int16_t *arbdata;
synth_waveform.cpp
* THE SOFTWARE.
#include "synth_waveform.h"
#include "utility/dspinst.h"
// PAH 140415 - change sin to use Paul's interpolation which is much
// faster than arm's sin function
// PAH 140316 - fix calculation of sample (amplitude error)
// PAH 140314 - change t_hi from int to float
void AudioSynthWaveform::update(void)
audio_block_t *block;
short *bp, *end;
int32_t val1, val2, val3;
uint32_t index, scale;
// temporaries for TRIANGLE
uint32_t mag;
short tmp_amp;
if(tone_amp == 0) return;
block = allocate();
if (block) {
bp = block->data;
switch(tone_type) {
case WAVEFORM_SINE:
for(int i = 0;i < AUDIO_BLOCK_SAMPLES;i++) {
// Calculate interpolated sin
// index = tone_phase >> 23;
index = tone_phase >> 24; //neurofun fix freq & phase errors, 32bit phase acc
val1 = AudioWaveformSine[index];
val2 = AudioWaveformSine[index+1];
// scale = (tone_phase >> 7) & 0xFFFF;
scale = (tone_phase >> 8) & 0xFFFF; //neurofun fix freq & phase errors, 32bit phase acc
val2 *= scale;
val1 *= 0xFFFF - scale;
val3 = (val1 + val2) >> 16;
*bp++ = (short)((val3 * tone_amp) >> 15);
// phase and incr are both unsigned 32-bit fractions
tone_phase += tone_incr;
// If tone_phase has overflowed, truncate the top bit
// if(tone_phase & 0x80000000)tone_phase &= 0x7fffffff; //neurofun fix freq & phase errors, 32bit phase acc
case WAVEFORM_ARBITRARY:
if (!arbdata) {
release(block);
return;
// len = 256
for (int i = 0; i < AUDIO_BLOCK_SAMPLES;i++) {
val1 = *(arbdata + index);
val2 = *(arbdata + ((index + 1) & 255));
val2 *= scale;
// tone_phase &= 0x7fffffff; //neurofun fix freq & phase errors, 32bit phase acc
case WAVEFORM_SQUARE:
// if(tone_phase & 0x40000000)*bp++ = -tone_amp;
if(tone_phase & 0x80000000)*bp++ = -tone_amp; //neurofun fix freq & phase errors, 32bit phase acc
else *bp++ = tone_amp;
case WAVEFORM_SAWTOOTH:
// *bp++ = ((short)(tone_phase>>15)*tone_amp) >> 15;
*bp++ = ((short)(tone_phase>>16)*tone_amp) >> 15; //neurofun fix freq & phase errors, 32bit phase acc
case WAVEFORM_SAWTOOTH_REVERSE:
*bp++ = -((short)(tone_phase>>16)*tone_amp) >> 15; //neurofun fix freq & phase errors, 32bit phase acc
// tone_phase -= tone_incr;
tone_phase += tone_incr; //neurofun fix freq & phase errors, 32bit phase acc
case WAVEFORM_TRIANGLE:
if(tone_phase & 0x80000000) {
// negative half-cycle
tmp_amp = -tone_amp;
else {
// positive half-cycle
tmp_amp = tone_amp;
mag = tone_phase << 2;
// Determine which quadrant
if(tone_phase & 0x40000000) {
// negate the magnitude
mag = ~mag + 1;
*bp++ = ((short)(mag>>17)*tmp_amp) >> 15;
// tone_phase += 2*tone_incr;
case WAVEFORM_PULSE:
// if(tone_phase < tone_width)*bp++ = -tone_amp;
// else *bp++ = tone_amp;
if(tone_phase < tone_width)*bp++ = tone_amp; //neurofun invert WAVEFORM_PULSE
else *bp++ = -tone_amp; //neurofun invert WAVEFORM_PULSE
case WAVEFORM_SAMPLE_HOLD:
if(tone_phase < tone_incr) {
sample = random(-tone_amp, tone_amp);
*bp++ = sample;
if (tone_offset) {
bp = block->data;
end = bp + AUDIO_BLOCK_SAMPLES;
do {
val1 = *bp;
*bp++ = signed_saturate_rshift(val1 + tone_offset, 16, 0);
} while (bp < end);
transmit(block,0);
release(block);
The following test program is meant to be used with an oscilloscope. It will show that all waveforms have same period and behave exactly the same way when changing the phase.
Connect dac0 or left to channel 1 and dac1 or right to channel 2 of your scope and select channel 1 as source for the trigger.
Channel1 gives you a 500hz reference square wave.
Channel2 will cycle through all the waveforms and sweep the phase in the following pattern,
0deg->360deg->90deg->180deg->0deg
AudioSynthWaveform waveform1;
AudioSynthWaveform waveform2;
AudioOutputI2S audioOutput;
AudioOutputAnalogStereo dacs1;
AudioConnection patchCord1(waveform1, 0, audioOutput, 0);
AudioConnection patchCord2(waveform2, 0, audioOutput, 1);
AudioConnection patchCord3(waveform1, 0, dacs1, 0);
AudioConnection patchCord4(waveform2, 0, dacs1, 1);
int wave_type[] = {
WAVEFORM_SINE,
WAVEFORM_TRIANGLE,
WAVEFORM_SAWTOOTH,
WAVEFORM_SAWTOOTH_REVERSE,
WAVEFORM_SQUARE,
WAVEFORM_PULSE,
WAVEFORM_SAMPLE_HOLD,
WAVEFORM_ARBITRARY,
String wave_name[] = {
"WAVEFORM_SINE",
"WAVEFORM_TRIANGLE",
"WAVEFORM_SAWTOOTH",
"WAVEFORM_SAWTOOTH_REVERSE",
"WAVEFORM_SQUARE",
"WAVEFORM_PULSE",
"WAVEFORM_SAMPLE_HOLD",
"WAVEFORM_ARBITRARY",
Serial.begin(250000);
AudioMemory(20);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
waveform1.amplitude(1);
waveform2.amplitude(1);
waveform1.pulseWidth(.5);
waveform2.pulseWidth(.5);
waveform1.arbitraryWaveform(AudioWaveformSine, 0);
waveform2.arbitraryWaveform(AudioWaveformSine, 0);
waveform1.frequency(500);
waveform2.frequency(500);
for (int j = 0; j < sizeof(wave_type) / sizeof(wave_type[0]); j++) {
Serial.println(wave_name[j]);
waveform1.begin(wave_type[4]);
waveform2.begin(wave_type[j]);
delay(2000);
for(float p = 0; p <= 360; p++){
AudioNoInterrupts();
waveform2.phase(p);
AudioInterrupts();
delay(5);
for(float p = 360; p >= 90; p--){
waveform2.phase(p);
AudioInterrupts();
delay(1);
for(float p = 90; p <= 180; p++){
waveform2.phase(p);
AudioInterrupts();
delay(2);
delay(2000);
for(float p = 180; p >= 0; p--){
waveform2.phase(p);
AudioInterrupts();
delay(5);
And here is a youtube video showing the output of the test program on a scope. First half of video is before the code update, second half is after the update:
https://youtu.be/VUCSt4CYFYQ
Any comments welcome.
