Results 1 to 2 of 2
Thread: AUDIO_INPUT_LINEIN Issues
    Mar 2014
    17
    Having a problem getting Line Inputs to work.
    iPhone>LineIn
    T3.1, building as USB Audio.
    Expecting to find a signal passed to the headphone jack.
    No output at all.
    Tried many examples, but this is an attempt to write a very simple sketch.
    AudioOutputI2S           i2s1;
    AudioControlSGTL5000     sgtl5000_1;
      AudioMemory(12);
      sgtl5000_1.enable();
      sgtl5000_1.volume(5);
      sgtl5000_1.inputSelect(AUDIO_INPUT_LINEIN);
      sgtl5000_1.lineInLevel(5);
    Seems there should be some routing code to patch the LI into other audio objects like the System Design Tool provides, but the method eludes me.
    What am I missing?
    Mar 2014
    17
    Okay,
    progress!
    Found dap_bass_enhance.ino which had the answer. New simple sketch:
    AudioInputI2S       lineIn;         // audio shield: mic or line-in
    AudioOutputI2S      headphoneOut;        // audio shield: headphones & line-out
    // Create Audio connections between the components
    AudioConnection c1(lineIn, 0, headphoneOut, 0); // left passing through
    AudioConnection c2(lineIn, 1, headphoneOut, 1); // right passing through
    AudioControlSGTL5000 Board;
      AudioMemory(12);
      Board.enable();
      Board.volume(5);
      Board.inputSelect(AUDIO_INPUT_LINEIN);
      Board.lineInLevel(5);
