Results 1 to 5 of 5
Thread: Reset Teensy 3.2 from another Arduino
    Dec 2017
    12
    I want to reset / reboot - without programming - a Teensy 3.2 from another Arduino (espacially Arduino Pro Mini).
    How to do this? Can I use the reset pin on the backside of the Teensy?
    If yes, is the reset pin per default low or high e.g. how to set the digitalWrite on output pin on the Arduino?
    May I have to use any pull-up or pull-down resitors?
    Feb 2014
    Colmar, France
    1,893
    The reset pin is high per default and must be pulled LOW to reset. Rebooting starts after the pin goes high again. A weak pull-up resistor is in place.
    I'm not sure if the RESET pin on the bottom is 5V tolerant - take care!
    18,346
    The reset pin is NOT 5 volt tolerant.
    If you use it from a 5V Arduino, do not drive the pin high. Only drive it low, and use pinMode() to release control of the pin. There's a pullup resistor in the chip on Teensy, so the pin will go back to 3.3V when you aren't driving it low.
    Dec 2017
    12
    Is the pull-up resistor of the reset pin set by default or must I do this manually? If yes, how is the number of the reset pin ( pinMode(xxx, INPUT_PULLUP) )?
    Feb 2014
    Colmar, France
    1,893
    The pull-up resistor is there by default.
