Results 1 to 9 of 9
Thread: Arduino tem file directory not found
    2,004
    I get recently not unfrequently an error like
    GetFileAttributesEx C:\Users\Walter\AppData\Local\Temp\arduino_build_9 71279: The system cannot find the file specified.
    Error compiling for board Teensy 3.6.
    In fact, checking the Temp folder a directory of this name does not exist. more, all build directories are gone.
    This on Win10, Arduino 1.8.2, TD 1.83b3
    This happens when I let Arduino IDE open for a couple of hours without doing anything.
    any idea on why this happens?
    If this is a clean-up feature, how do I reset Arduino without closing and re-opening the IDE?
    7,347
    Doing a major change in TOOLS will force a rebuild of CORE - change CPU SPEED or OPTIMIZE mode - then change it back if desired. I've left IDE open and it does seem like sometimes it does a longer build all when I'm expecting a 5 second rebuild - but not looked at that.
    You might be fighting the system protecting you? Check this thread? : https://forum.pjrc.com/threads/48368...McAfee-Problem
    2,004
    changing CPU speed did not create new directory.
    I was following the McAfee thread. But my observation seems different. I'm using Norton.
    3,809
    I have run into this once or twice, the only way I found at the time was to restart the Arduino IDE. I know at least one time it was after I forgot to turn the computer off and it stayed up all night.
    I was wondering if there might be some periodic background disk cleanup demon that may have run. I have not checked to see if there are any such apps installed.
    2,004
    my conclusion too, clean-up of temp directory could be by OS or Arduino.
    Now, I would like to know, who is doing it.
    18,967
    I'm pretty sure it's not the Arduino IDE. The files and folders are deleted when you quit, but as far as I can tell it will leave them intact as long as you keep the IDE running. At least on my Linux system, the build folders stay there for several days if I haven't restarted Arduino. I'm pretty sure the same Java code of the IDE runs and does the same on Windows.
    2,004
    So may be some 'disk-performance' operation that cleans temp directories? (Or, slow failure of SSD of my Win10 notebook?)
    Feb 2014
    Colmar, France
    2,114
    I wouldn’t suspect neither the SSD nor Windows, rather the IDE itself having a kind of automated garbage collector, but that’s a guess.
    7,347
    When I saw the unexpected full rebuild on my still open system I had a guess it was the way it came up with the TEMP folder name - resulting in dumping old and making new. But that was just untested conjecture because it was just an occasional rebuild out of the blue ...
