Results 1 to 3 of 3
Thread: Best LCD to be used witn Teensy 3.2
    I would like some opinions and guidance for LCD's to be used with the Teensy. What are the easiest to implement, most versatile, etc.
    Currently I have hooked up a 128x64 LCD with only 4 pins, no resistors or pot required. Looks good, but may be a bit smaller than I want. it's only the .96 inch. But it works well.
    I have read that the 1602 can be used but requires some 1k resistors and a 10k pot to adjust the LCD.
    Any suggestions and/or links to read up are would be helpful.
    Thanks..
    Chris
    5,178
    Color or monochrome? SPI or i2c? PJRC carries a 2.2 and 2.8" TFT with TOUCH that is very well supported in 240x320 pixels.
    I used a 1.44" 128x128 ILI9163C from Ebay that was nice and fast
    Monochrome is fine, but something like cyan on black or white on black. I currently have one of these hooked up and it works well, very fast.
    HERE
