Results 1 to 3 of 3
Thread: TOF mini Lidar
    Dec 2017
    15
    TOF mini Lidar
    We tested with Arduino it worked very well when i use with with teensy 3.5 ,it is not working sample codes.
    http://wiki.seeed.cc/Grove-TF_Mini_LiDAR/
    unsigned char dta[100];
    unsigned char len = 0;
    Serial1.begin(115200);
    while(Serial1.available()>=9)
    if((0x59 == Serial1.read()) && (0x59 == Serial1.read())) //Byte1 & Byte2
    unsigned int t1 = Serial1.read(); //Byte3
    unsigned int t2 = Serial1.read(); //Byte4
    t2 <<= 8;
    t2 += t1;
    Serial.print(t2);
    Serial.print('\t');
    t1 = Serial1.read(); //Byte5
    t2 = Serial1.read(); //Byte6
    t2 <<= 8;
    t2 += t1;
    Serial.println(t2);
    for(int i=0; i<3; i++)
    Serial1.read(); ////Byte7,8,9
    Anyone used before ?
    Feb 2014
    Colmar, France
    1,895
    "Doesn't work" is of no value, as long as you don't say what does not work. Do you get compiler warnings or errors? To which Teensy pins did you connect the LIDAR exactly ?
