Cheap ICS-52000 Microphone Array Board for TDM evaluation
It this connection
Mic Pin 6 (SD_O) to Teensy Pin 9 SCLK (Output, 11.3 MHz, Checked)
Mic Pin 8 (SCK_I) to Teensy Pin 13 SDATA (Input, 11.3 Mbit/sec)
Mic Pin 10 (WS_I) to Teensy Pin 23 FS (Output, 44100 Hz, Checked
correct?
Close but no, see the schematic above (the picture) for the correct connections.
This is my schematic.
This is what it looks like (I know, it's a rats nest).
I have twisted a grounded wire around SD and SCK going from the teensy to each mic. and I put a 0.1uF cap as close to each mic as I could get. I also put a 100kOhm pull down resistor at the SD pin on the teensy side.
like Mr.Pedro said, I didn't change anything but commenting out --> sgtl5000_1.enable(); and I made AudioMemory(512); I think the extra memory allocation was needed. I just tested it now with this code:
// Record TDM input sound as raw data (16ch, Signed 24-bit little-endian PCM, 44.1kHz, little-endian) to a SD card.
// Note: Format is modified so that mics align their 24 bit data to 32 bit slots, half of the 16 bit
// channels end up being the 8 low bits, and 8 more zeros which are discarded.
// Hardware:
//   Mic Pin 6  (SD_O)  to Teensy Pin  9 SCLK  (Output, 11.3 MHz, Checked)
//   Mic Pin 8  (SCK_I) to Teensy Pin 13 SDATA (Input, 11.3 Mbit/sec)
//   Mic Pin 10 (WS_I)  to Teensy Pin 23 FS    (Output, 44100 Hz, Checked)
//   Mic GND Pins (1, 3, 5, 7 and 9) to Teensy GND
//   Mic VDD to Teensy 3.3V
//   At startup of the ICS-52000, the start of the frame sync (WS_I) signal should be delayed from the start of the serial clock (SCK_I) by at
//   least 10 ms. This enables the microphone’s internal circuits to completely initialize before starting the synchronization sequence
//   with other microphones in the TDM array. This delay can be implemented either by enabling the WS output (FS) on the clock master at
//   least 10 ms after the SCK_I is enabled, or by externally controlling the signals given to the ICS-52000s.
AudioInputTDM            tdm1;           //xy=359,317
//AudioRecordQueue         queue13;        //xy=620,615
//AudioRecordQueue         queue14;        //xy=620,649
//AudioRecordQueue         queue15;        //xy=620,682
//AudioRecordQueue         queue12;        //xy=621,581
//AudioRecordQueue         queue16;        //xy=622,716
//AudioRecordQueue         queue9;         //xy=623,480
//AudioRecordQueue         queue10;        //xy=623,514
//AudioRecordQueue         queue11;        //xy=623,547
//AudioRecordQueue         queue4;         //xy=624,315
//AudioRecordQueue         queue5;         //xy=624,348
//AudioRecordQueue         queue6;         //xy=624,381
//AudioRecordQueue         queue7;         //xy=624,414
//AudioRecordQueue         queue3;         //xy=625,281
//AudioRecordQueue         queue8;         //xy=625,447
AudioRecordQueue         queue2;         //xy=626,248
AudioRecordQueue         queue1;         //xy=627,214
AudioConnection          patchCord1(tdm1, 0, queue1, 0);
AudioConnection          patchCord2(tdm1, 1, queue2, 0);
//AudioConnection          patchCord3(tdm1, 2, queue3, 0);
//AudioConnection          patchCord4(tdm1, 3, queue4, 0);
//AudioConnection          patchCord5(tdm1, 4, queue5, 0);
//AudioConnection          patchCord6(tdm1, 5, queue6, 0);
//AudioConnection          patchCord7(tdm1, 6, queue7, 0);
//AudioConnection          patchCord8(tdm1, 7, queue8, 0);
//AudioConnection          patchCord9(tdm1, 8, queue9, 0);
//AudioConnection          patchCord10(tdm1, 9, queue10, 0);
//AudioConnection          patchCord11(tdm1, 10, queue11, 0);
//AudioConnection          patchCord12(tdm1, 11, queue12, 0);
//AudioConnection          patchCord13(tdm1, 12, queue13, 0);
//AudioConnection          patchCord14(tdm1, 13, queue14, 0);
//AudioConnection          patchCord15(tdm1, 14, queue15, 0);
//AudioConnection          patchCord16(tdm1, 15, queue16, 0);
//AudioControlSGTL5000     sgtl5000_1;     //xy=369,479
//#define SDCARD_CS_PIN    10
//#define SDCARD_MOSI_PIN  7
//#define SDCARD_SCK_PIN   14
#define SDCARD_CS_PIN    BUILTIN_SDCARD
#define SDCARD_MOSI_PIN  11  // not actually used
#define SDCARD_SCK_PIN   13  // not actually used
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN    4
//#define SDCARD_MOSI_PIN  11
//#define SDCARD_SCK_PIN   13
// Remember which mode we're doing
int mode = 0;  // 0=stopped, 1=recording
int choice = 0;
int sample_number = 0;
unsigned int tsamplemillis = 11000;
String typeofsound;
// The file where data is recorded
File frec;
  AudioMemory(512);
  // Initialize the SD card
  SPI.setMOSI(SDCARD_MOSI_PIN);
  SPI.setSCK(SDCARD_SCK_PIN);
    while (1) {
  while(!Serial);
  Serial.println("Welcome to the beta version of Viband's TDM sound recorder, 11 second clips are going to be recorded, be \ncareful introducing a new type of sound already introduced since previous samples will be overwritten.");
  Serial.println("\nNote: SD Library uses short 8.3 names (12 characters). Filename (i.e baby/baby24) can't be longer.");
  if(choice==0){
  Serial.println("\nIntroduce new type of sound (i.e baby): ");
  while(!Serial.available());
  typeofsound = Serial.readString();
  sample_number = 0;
  record(typeofsound,sample_number);
  } else if(choice==1){
    sample_number++;
    //Do nothing
  Serial.print("\nIntroduce 1 to take another sample or 0 to introduce a new type of sound: ");
  choice = Serial.readString().toInt();
  Serial.println(choice);
void record(String type, int number){
  Serial.println("Recording " + type + String(number) + "...");
  elapsedMillis recordingTime = 0;
  String sname = type + number + ".RAW";
  String path = type + "/" + type + number + ".RAW";
  startRecording(sname, path, type);
  while(recordingTime<tsamplemillis) continueRecording();
  stopRecording();
void startRecording(String sname, String path, String type) {
  int str_len = path.length()+1;
  char charpath[str_len];
  path.toCharArray(charpath,str_len);
  if (SD.exists(charpath)) {
    // The SD library writes new data to the end of the
    // file, so to start a new recording, the old file
    // must be deleted before new data is written.
    SD.remove(charpath);
  str_len = type.length()+1;
  char chartype[str_len];
  type.toCharArray(chartype,str_len);
  if(!SD.exists(chartype)){
    SD.mkdir(chartype);
  frec = SD.open(charpath, FILE_WRITE);
  if (frec) {
    Serial.println("File Open");
    queue1.begin();
    queue2.begin();
//    queue3.begin();
//    queue4.begin();
//    queue5.begin();
//    queue6.begin();
//    queue7.begin();
//    queue8.begin();
//    queue9.begin();
//    queue10.begin();
//    queue11.begin();
//    queue12.begin();
//    queue13.begin();
//    queue14.begin();
//    queue15.begin();
//    queue16.begin();
    mode = 1;
void continueRecording() {
  if (queue1.available() >= 2 && queue2.available() >=2) {
    uint16_t buffer1[128];
    uint16_t buffer2[128];
    memcpy(buffer1, queue1.readBuffer(), 256);
    memcpy(buffer2, queue2.readBuffer(), 256);
    queue1.freeBuffer();
    queue2.freeBuffer();
    for(int i = 0; i < 128; i ++){
        frec.write(highByte(buffer2[i])); // LSB
        frec.write(lowByte(buffer1[i])); // Middle Byte
        frec.write(highByte(buffer1[i])); // MSB
        //frec.write(lowByte(buffer2[i])); // Zeros
void stopRecording() {
  Serial.println("Finished recording.");
  queue1.end();
  queue2.end();
  queue1.clear();
  queue2.clear();
  frec.close();
  mode = 0;
and this is what it sounded like:
https://drive.google.com/file/d/1h697lgbRokRHw5ftTG4Rfx1jJFsg1zUz/view?usp=sharing
I imported the audio using --> import RAW, --> signed 24 bit PCM, little-endian, mono, 0 offset, 100% amount to import, 44100 Hz sample rate. and then I turned the channel gain to +36dB.
My impression would be to investigate the boards you and Mr.Pedro have in common, maybe there is a bad connection on it somewhere, if you have an oscilloscope it could help to look at the SD pin, triggered off of the WS pin, to even see if the mics are sending data (with the sketch I wrote they always send data when they are powered). there's also a sad chance that the process they used to solder the mics to the boards ruined the mics. Fortunately the mics are only 4 dollars each from digikey.
I hope this helped.
What is the time sequence you connecting the microphone pins and teensy? Is it like this
____________________________________________________________________________
As soon as the programm starts running, the microphone is enabled through Teensy 3.3V pin, and initialized through Teensy Pin 9 SCLK, any 10ms after
programming the Teensy 3.6 via USB or after opening the serial monitor I connect the Teensy pin 23 (WS) by hand. I checked Teensy Pin 9 SCLK signal using
the oscilloscope.
the oscilloscope.
I'm not sure what you are asking. Did you see a clock pulse on the oscilloscope? You should also be probing the SDO pin to see if the mics are sending any data. I'm not sure why you are connecting things in sequence by hand, just wire it all up and then power the teensy. I'm sorry if this is not very helpful.
HI Dreggory,
As far as I see, in the forum, you the only one who has successfully made the Teensy working with the ICS52000.:cool:
Could you share some detailed hardware connection and software code. :confused:
I closed many redundant ICS-52000 threads. Leaving this one and that other open.
Please keep all ICS-52000 on these 2 remaining open threads. Starting more threads only scatters the conversation to too much places, which makes search much more difficult for anyone in the future who wants to try using ICS-52000.
