RTC battery for T3.2
floating.
What are the recommended RTC batteries for the Teensy 3.2? CR2032? Something else?
How long would a CR2032 last? (I'm just looking for an approximate, ballpark figure)
Thanks, I got it. I think I'm not going to verify that figure ( :) ) but I have a feeling that with heat and self-discharge factored in, it's likely to be significantly less than 17 years.
But I guess I can probably expect a CR2032 last for about 5 years or so.
Of a possible other option, does anyone know how complicated or costly is a circuit that would charge a LIR2032?
Most CR2032s have a "shelf life" spec in the 5 to 10 year range. Usually those specs are worst case scenarios based on higher temperatures, so they may not be an issue if the battery is kept at room temperature or in a cold environment.
Then again, the self discharge may play a factor, for less than the 17 years you might expect from only the capacity rating.
Here's one graph that really explains the situation pretty well.
