kingforger
MuShoo, here's a working schematic and BOM for just the teensy portion (built and it works great). The three buttons that you see that are the same are wired incorrectly. Also, VIN-PRI/VUSB-TRI and VUSB_PRIMARY is just 5V. If you were putting together your own schematic, you probably just want to connect them together to VUSB in order to power the teensy from USB or a 5V source. If you have a battery that is separate from USB, then you should hopefully be able to figure that out yourself...
In the BOM, there's a bunch of extra stuff that you won't see on the schematic. That's because it's used elsewhere in places that I should not show you. The teensy part is fine to show you all, though. No secrets there.
Otherwise, Paul did not give the bill of materials, so I just chose things that seemed appropriate (like with the ferrites, for example). It's working well, so I apparently did fine.
http://imgur.com/Cwbe02r
http://imgur.com/5TtAQbH
