Results 1 to 2 of 2
Thread: Possible to do delay longer than 425 ms with teensy 3.5?
    Aug 2017
    6
    The delay effect documentation says it has a max delay time of 425 ms, and delayExt uses an external chip for longer delay times. I was wondering if you can get longer delay times on teensy 3.5/3.6 without external memory since they have enough memory onboard to allot more audio memory.
    Is there anything in the code that prevents you from making the delay time longer than 425 ms if you give the sketch enough audio memory to handle it?
    18,701
    Yes, you can get longer delays on Teensy 3.5 and 3.6.
    I've updated the delay documentation with a table showing the max delay for each board.
Tags for this Thread
