Results 1 to 8 of 8
Thread: collect2.exe: error: ld returned 5 exit status
    Dec 2013
    Tulsa, OK
    64
    Merry Christmas....
    Teensy 2.0 on XP computer trying to compile the sample code from the analog temperature monitor.
      Serial.begin(38400);
    float code;
    float celsius;
    float fahrenheit;
      code = analogRead(1);
      celsius = 25 + (code - 512) / 11.3;
      fahrenheit = celsius * 1.8 + 32;
      Serial.print("temperature: ");
      Serial.print(celsius);
      Serial.print(" Celsius, ");
      Serial.print(fahrenheit);
      Serial.println(" Fahrenheit");
    Sorry about not using the Code tag but for some reason the tag links are not showing up for me. Running FireFox and not sure why.
    This should compile just fine and I can get it to if I comment out the two SerialPrint celsius lines. I see nothing wrong, what am I missing?
    17,482
    Which version of Arduino & Teensyduino are you using? Click Help > About to check.
    It compiles without any error when I try on Linux 64 bit. I no longer have a Windows XP test machine set up, but I could try on Windows 10 if needed...
    17,482
    If you have Arduino older than 1.8.2, you might be seeing this problem (which Arduino fixed in 1.8.2).
    https://github.com/arduino/Arduino/issues/5845
    Dec 2013
    Tulsa, OK
    64
    Ya, 1.6.11, I'll update and see how it goes..I'm one of those that doesn't update software unless I have a problem that needs fixing. Too many times an update has caused me more grief than help
    Dec 2013
    Tulsa, OK
    64
    That fixed it.. I had previously downloaded the latest versions of Arduino and Teensy for another computer but never updated this one.
    Thanks a bunch...
    Now if I could just figure out why the formatting links are not showing on this forum in FireFox I would be good. Pretty sure I am running the latest version of FireFox.
    3,503
    Quote Originally Posted by BReeves View Post
    Works for me with Firefox. The Quick reply (as well as the full edit) has the # button in it which is for code tags.
    Of course you could do it the old fashion way as well:
    type in {code} ... {/code} but use the [] instead of {} I typed so they would show up...
    Dec 2013
    Tulsa, OK
    64
    Well durn,
    Downloaded and installed the latest version of FireFox and did a Refresh to set everything back to the default settings and still do not have the edit buttons. Only left is to try a restart with add in's disabled.
    Dec 2013
    Tulsa, OK
    64
    That didn't help.. Oh well now that I'm past the compile error on to my new project.
