Results 1 to 2 of 2
Thread: Dragonframe stop motion software with Teensy and Stepper Motors
    Junior Member winux's Avatar
    Nov 2017
    3
    Hello, i'm looking for a way to use the teensy 3.6 and 6 stepper drivers together with the Dragonframe Stop Motion Software.
    There is an old thread in the forums where ppl already tried to get it to work but there was no real success, at least not in the old thread.
    (old thread) https://forum.pjrc.com/threads/45078...tepper-Control
    Fortunatly there is a new sketch that comes bundled with the dragonframe 4 that is supporting Genuino 101 ( 32bit Intel Curie Chip )
    They are using the CurieTimerOne.h https://github.com/arduino/ArduinoCo...urieTimerOne.h
    lib for the timing logic on the Intel Curie Chip.
    After some googling i found https://github.com/PaulStoffregen/TimerOne from paul. now the question is it possible to swap the 2 libs to get it working.
    The call in the original sketch looks like this:
      #elif defined(BOARD_101)
        CurieTimerOne.start(25, &updateStepDirection);
    so will a (example, more code needed)
      #elif defined(BOARD_Teensy)
    with pauls lib work?
    thx for your time and help and i hope we can get it working =)
    DFMoco sketch from DF4:
    (also attached as file below)
    #define DFMOCO_VERSION 1
    #define DFMOCO_VERSION_STRING "1.3.0"
      DFMoco version 1.3.0
      Multi-axis motion control.
      For use with the Arc motion control system in Dragonframe 4.
      Generates step and direction signals, which can be sent to stepper motor drivers.
      Control up to four axes with an Uno, Duemilanove or 101 board.
      Control up to eight axes with a Mega or Mega 2560.
      Version History
      Version 1.3.0 Arduino 101 support. Remove non-Arduino support (chipKit, Maple).
      Version 1.2.7 Direction setup time.
      Version 1.2.6 Add PINOUT_VERSION option to use older pinout.
      Version 1.2.5 Fix jogging with low pulse rate.
      Version 1.2.4 Fix pin assignments
      Version 1.2.3 New Position command
      Version 1.2.2 Jog and Inch commands
      Version 1.2.1 Moved step/direction pins for motions 5-8.
                    Detects board type automatically.
      Version 1.2.0 Basic go-motion capabilities
      Version 1.1.2 Smooth transitions when changing direction
      Version 1.1.1 Save/restore motor position
      Version 1.1.0 Major rework
      Version 1.0.2 Moved pulses into interrupt handler
      Version 1.0.1 Added delay for pulse widths
      Version 1.0.0 Initial public release.
      Getting Started:
       1. Install IDE (Integrated Development Environment):
          Go to https://www.arduino.cc/en/Main/Software and download the Arduino Software for your OS.
       2. Run the IDE you installed.
       3. Open this file in the IDE.
       4. Go to the Tools menu of the IDE and choose the Board type you are using.
       5. Verify/Compile the sketch. (Command-R on Mac, Control-R on Windows.)
       6. After this finishes, Upload the code to the board. (Command-U on Mac, Control-U on Windows.)
      Pin configuration:
      channel 1
            PIN   4   step
            PIN   5   direction
      channel 2
            PIN   6   step
            PIN   7   direction
      channel 3
            PIN   8   step
            PIN   9   direction
      channel 4
            PIN  10   step
            PIN  11   direction
      channel 5
            PIN  28   step
            PIN  29   direction
      channel 6
            PIN  30   step
            PIN  31   direction
      channel 7
            PIN  32   step
            PIN  33   direction
      channel 8
            PIN  34   step
            PIN  35   direction
    // change this to 1 if you want original pinout for channels 5-8
    #define PINOUT_VERSION 2
      This is PINOUT_VERSION 1
      channel 5
            PIN  22   step
            PIN  23   direction
      channel 6
            PIN  24   step
            PIN  25   direction
      channel 7
            PIN  26   step
            PIN  27   direction
      channel 8
            PIN  28   step
            PIN  29   direction
    // detect board type
    #if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
      #define BOARD_MEGA 1
    #elif defined(__AVR_ATmega328P__) || defined(__AVR_ATmega328__)  || defined(__AVR_ATmega168__)
      #define BOARD_UNO 1
    #elif defined(ARDUINO_ARCH_ARC32) // Intel Curie/101
      #define BOARD_101 1
      #include "CurieTimerOne.h"
    #else
      #error Cannot identify board
    // USER: if you want a kill switch, uncomment out the next line by removing the // characters
    //#define KILL_SWITCH_INTERRUPT 0
    #define SERIAL_DEVICE Serial
    #if defined(BOARD_101)
      #define PIN_ON(port, pin)  { digitalWrite(pin, 1); }
      #define PIN_OFF(port, pin) { digitalWrite(pin, 0); }
    #else
      #define PIN_ON(port, pin)  { port |= pin; }
      #define PIN_OFF(port, pin) { port &= ~pin; }
    // Arduino Uno/Duemilanove  -> 4 MOTORS MAX
    // Arduino Mega 2560 / Mega -> 8 MOTORS MAX
    #if defined(BOARD_UNO) || defined(BOARD_101)
    #define MOTOR_COUNT 4
    #else
    #define MOTOR_COUNT 8
    #define TIME_CHUNK 50
    #define SEND_POSITION_COUNT 20000
    // update velocities 20 x second
    #define VELOCITY_UPDATE_RATE (50000 / TIME_CHUNK)
    #define VELOCITY_INC(maxrate) (max(1.0f, maxrate / 70.0f))
    #define VELOCITY_CONVERSION_FACTOR 0.30517578125f /* 20 / 65.536f */
    // setup step and direction pins
      #define MOTOR0_STEP_PORT 0
      #define MOTOR0_STEP_PIN  4
      #define MOTOR1_STEP_PORT 0
      #define MOTOR1_STEP_PIN  6
      #define MOTOR2_STEP_PORT 0
      #define MOTOR2_STEP_PIN  8
      #define MOTOR3_STEP_PORT 0
      #define MOTOR3_STEP_PIN  10
    #elif defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
      #define MOTOR0_STEP_PORT PORTG
      #define MOTOR0_STEP_PIN  B00100000
      #define MOTOR1_STEP_PORT PORTH
      #define MOTOR1_STEP_PIN  B00001000
      #define MOTOR2_STEP_PORT PORTH
      #define MOTOR2_STEP_PIN  B00100000
      #define MOTOR3_STEP_PORT PORTB
      #define MOTOR3_STEP_PIN  B00010000
      #if ( PINOUT_VERSION == 2 )
        #define MOTOR4_STEP_PORT PORTA
        #define MOTOR4_STEP_PIN  B01000000
        #define MOTOR5_STEP_PORT PORTC
        #define MOTOR5_STEP_PIN  B10000000
        #define MOTOR6_STEP_PORT PORTC
        #define MOTOR6_STEP_PIN  B00100000
        #define MOTOR7_STEP_PORT PORTC
        #define MOTOR7_STEP_PIN  B00001000
      #elif ( PINOUT_VERSION == 1 )
        #define MOTOR4_STEP_PIN  B00000001
        #define MOTOR5_STEP_PORT PORTA
        #define MOTOR5_STEP_PIN  B00000100
        #define MOTOR6_STEP_PORT PORTA
        #define MOTOR6_STEP_PIN  B00010000
        #define MOTOR7_STEP_PORT PORTA
        #define MOTOR7_STEP_PIN  B01000000
    #elif defined(BOARD_UNO)
      #define MOTOR0_STEP_PORT PORTD
      #define MOTOR0_STEP_PIN  B00010000
      #define MOTOR1_STEP_PORT PORTD
      #define MOTOR1_STEP_PIN  B01000000
      #define MOTOR2_STEP_PORT PORTB
      #define MOTOR2_STEP_PIN  B00000001
      #define MOTOR3_STEP_PIN  B00000100
     * Serial output specialization
    #if defined(UBRRH)
    #define TX_UCSRA UCSRA
    #define TX_UDRE  UDRE
    #define TX_UDR   UDR
    #else
    #define TX_UCSRA UCSR0A
    #define TX_UDRE  UDRE0
    #define TX_UDR   UDR0
    char txBuf[32];
    char *txBufPtr;
    #define TX_MSG_BUF_SIZE 16
    #define MSG_STATE_START 0
    #define MSG_STATE_CMD   1
    #define MSG_STATE_DATA  2
    #define MSG_STATE_ERR   3
    #define MSG_STATE_DONE  100
     * Command codes from user
    #define USER_CMD_ARGS 40
    #define CMD_NONE       0
    #define CMD_HI         10
    #define CMD_MS         30
    #define CMD_NP         31
    #define CMD_MM         40 // move motor
    #define CMD_PR         41 // pulse rate
    #define CMD_SM         42 // stop motor
    #define CMD_MP         43 // motor position
    #define CMD_ZM         44 // zero motor
    #define CMD_SA         50 // stop all (hard)
    #define CMD_BF         60 // blur frame
    #define CMD_GO         61 // go!
    #define CMD_JM         70 // jog motor
    #define CMD_IM         71 // inch motor
    #define MSG_HI 01
    #define MSG_MM 02
    #define MSG_MP 03
    #define MSG_MS 04
    #define MSG_PR 05
    #define MSG_SM 06
    #define MSG_SA 07
    #define MSG_BF 10
    #define MSG_GO 11
    #define MSG_JM 12
    #define MSG_IM 13
    struct UserCmd
      byte command;
      byte argCount;
      int32_t args[USER_CMD_ARGS];
     * Message state machine variables.
    byte lastUserData;
    int  msgState;
    int  msgNumberSign;
    UserCmd userCmd;
    struct txMsg
      byte msg;
      byte motor;
    struct TxMsgBuffer
      txMsg buffer[TX_MSG_BUF_SIZE];
      byte head;
      byte tail;
    TxMsgBuffer txMsgBuffer;
     Motor data.
    uint16_t           motorAccumulator0;
    uint16_t           motorAccumulator1;
    uint16_t           motorAccumulator2;
    uint16_t           motorAccumulator3;
    #if MOTOR_COUNT > 4
    uint16_t           motorAccumulator4;
    uint16_t           motorAccumulator5;
    uint16_t           motorAccumulator6;
    uint16_t           motorAccumulator7;
    uint16_t*          motorAccumulator[MOTOR_COUNT] =
      &motorAccumulator0, &motorAccumulator1, &motorAccumulator2, &motorAccumulator3,
    #if MOTOR_COUNT > 4
      &motorAccumulator4, &motorAccumulator5, &motorAccumulator6, &motorAccumulator7
    uint16_t           motorMoveSteps0;
    uint16_t           motorMoveSteps1;
    uint16_t           motorMoveSteps2;
    uint16_t           motorMoveSteps3;
    #if MOTOR_COUNT > 4
    uint16_t           motorMoveSteps4;
    uint16_t           motorMoveSteps5;
    uint16_t           motorMoveSteps6;
    uint16_t           motorMoveSteps7;
    uint16_t*          motorMoveSteps[MOTOR_COUNT] =
      &motorMoveSteps0, &motorMoveSteps1, &motorMoveSteps2, &motorMoveSteps3,
    #if MOTOR_COUNT > 4
      &motorMoveSteps4, &motorMoveSteps5, &motorMoveSteps6, &motorMoveSteps7
    uint16_t           motorMoveSpeed0;
    uint16_t           motorMoveSpeed1;
    uint16_t           motorMoveSpeed2;
    uint16_t           motorMoveSpeed3;
    #if MOTOR_COUNT > 4
    uint16_t           motorMoveSpeed4;
    uint16_t           motorMoveSpeed5;
    uint16_t           motorMoveSpeed6;
    uint16_t           motorMoveSpeed7;
    uint16_t         * motorMoveSpeed[MOTOR_COUNT] =
      &motorMoveSpeed0, &motorMoveSpeed1, &motorMoveSpeed2, &motorMoveSpeed3,
    #if MOTOR_COUNT > 4
      &motorMoveSpeed4, &motorMoveSpeed5, &motorMoveSpeed6, &motorMoveSpeed7
    volatile boolean nextMoveLoaded;
    unsigned int   velocityUpdateCounter;
    byte           sendPositionCounter;
    boolean        hardStopRequested;
    byte sendPosition = 0;
    byte motorMoving = 0;
    byte toggleStep = 0;
    #define P2P_MOVE_COUNT 7
    struct Motor
      byte   stepPin;
      byte   dirPin;
      // pre-computed move
      float   moveTime[P2P_MOVE_COUNT];
      int32_t movePosition[P2P_MOVE_COUNT];
      float   moveVelocity[P2P_MOVE_COUNT];
      float   moveAcceleration[P2P_MOVE_COUNT];
      float   gomoMoveTime[P2P_MOVE_COUNT];
      int32_t gomoMovePosition[P2P_MOVE_COUNT];
      float   gomoMoveVelocity[P2P_MOVE_COUNT];
      float   gomoMoveAcceleration[P2P_MOVE_COUNT];
      int       currentMove;
      float     currentMoveTime;
      volatile  boolean   dir;
      int32_t   position;
      int32_t   destination;
      float     maxVelocity;
      float     maxAcceleration;
      uint16_t  nextMotorMoveSteps;
      float     nextMotorMoveSpeed;
    boolean goMoReady;
    int     goMoDelayTime;
    Motor motors[MOTOR_COUNT];
    #ifdef KILL_SWITCH_INTERRUPT
    void killSwitch()
      hardStopRequested = true;
     * setup() gets called once, at the start of the program.
      goMoReady = false;
      lastUserData = 0;
      msgState = MSG_STATE_START;
      velocityUpdateCounter = 0;
      sendPositionCounter = 10;
      nextMoveLoaded = false;
      hardStopRequested = false;
      for (int i = 0; i < 32; i++)
        txBuf[i] = 0;
      txBufPtr = txBuf;
      attachInterrupt(KILL_SWITCH_INTERRUPT, killSwitch, CHANGE);
      // initialize motor structures
      for (int i = 0; i < MOTOR_COUNT; i++)
        // setup motor pins - you can customize/modify these after loop
        // default sets step/dir pairs together, with first four motors at 4/5, 6/7, 8/9, 10/11
        // then, for the Mega boards, it jumps to 28/29, 30/31, 32/33, 34/35
          motors[i].stepPin = (i * 2) + ( (i < 4) ? 4 : 20 );
          motors[i].stepPin = (i * 2) + ( (i < 4) ? 4 : 14 );
        motors[i].dirPin = motors[i].stepPin + 1;
        motors[i].dir = true; // forward
        motors[i].position = 0L;
        motors[i].destination = 0L;
        motors[i].nextMotorMoveSteps = 0;
        motors[i].nextMotorMoveSpeed = 0;
        setPulsesPerSecond(i, 5000);
      // set output pins
        pinMode(motors[i].stepPin, OUTPUT);
        pinMode(motors[i].dirPin, OUTPUT);
        // disable PWM
        switch (motors[i].stepPin)
          #if defined(TCCR3A) && defined(COM3B1)
          case 4:
            TCCR3A &= ~COM3B1;
          #if defined(TCCR4A) && defined(COM4A1)
          case 6:
            TCCR4A &= ~COM4A1;
          #if defined(TCCR4A) && defined(COM4C1)
          case 8:
            TCCR4A &= ~COM4C1;
          #if defined(TCCR2A) && defined(COM2A1)
          case 10:
            TCCR2A &= ~COM2A1;
    #else
          #if defined(TCCR1A) && defined(COM1B1)
          case 10:
            TCCR1A &= ~COM1B1;
      // set initial direction
        digitalWrite( motors[i].dirPin, motors[i].dir ? HIGH : LOW );
      // setup serial connection
      Serial.begin(57600);
      sendMessage(MSG_HI, 0);
      // SET UP interrupt timer
      #if defined(BOARD_UNO) || defined(BOARD_MEGA)
        TCCR1A = 0;
        TCCR1B = _BV(WGM13);
        ICR1 = (F_CPU / 4000000) * TIME_CHUNK; // goes twice as often as time chunk, but every other event turns off pins
        TCCR1B &= ~(_BV(CS10) | _BV(CS11) | _BV(CS12));
        TIMSK1 = _BV(TOIE1);
        TCCR1B |= _BV(CS10);
    void updateStepDirection(void)
    #else
    ISR(TIMER1_OVF_vect)
      toggleStep = !toggleStep;
      if (toggleStep)
        // MOTOR 1
        if (motorMoveSteps0)
          uint16_t a = motorAccumulator0;
          motorAccumulator0 += motorMoveSpeed0;
          if (motorAccumulator0 < a)
            motorMoveSteps0--;
            PIN_ON(MOTOR0_STEP_PORT, MOTOR0_STEP_PIN);
        // MOTOR 2
        if (motorMoveSteps1)
          uint16_t a = motorAccumulator1;
          motorAccumulator1 += motorMoveSpeed1;
          if (motorAccumulator1 < a)
            motorMoveSteps1--;
            PIN_ON(MOTOR1_STEP_PORT, MOTOR1_STEP_PIN);
        // MOTOR 3
        if (motorMoveSteps2)
          uint16_t a = motorAccumulator2;
          motorAccumulator2 += motorMoveSpeed2;
          if (motorAccumulator2 < a)
            motorMoveSteps2--;
            PIN_ON(MOTOR2_STEP_PORT, MOTOR2_STEP_PIN);
        // MOTOR 4
        if (motorMoveSteps3)
          uint16_t a = motorAccumulator3;
          motorAccumulator3 += motorMoveSpeed3;
          if (motorAccumulator3 < a)
            motorMoveSteps3--;
            PIN_ON(MOTOR3_STEP_PORT, MOTOR3_STEP_PIN);
    #if MOTOR_COUNT > 4
        // MOTOR 5
        if (motorMoveSteps4)
          uint16_t a = motorAccumulator4;
          motorAccumulator4 += motorMoveSpeed4;
          if (motorAccumulator4 < a)
            motorMoveSteps4--;
            PIN_ON(MOTOR4_STEP_PORT, MOTOR4_STEP_PIN);
        // MOTOR 6
        if (motorMoveSteps5)
          uint16_t a = motorAccumulator5;
          motorAccumulator5 += motorMoveSpeed5;
          if (motorAccumulator5 < a)
            motorMoveSteps5--;
            PIN_ON(MOTOR5_STEP_PORT, MOTOR5_STEP_PIN);
        // MOTOR 7
        if (motorMoveSteps6)
          uint16_t a = motorAccumulator6;
          motorAccumulator6 += motorMoveSpeed6;
          if (motorAccumulator6 < a)
            motorMoveSteps6--;
            PIN_ON(MOTOR6_STEP_PORT, MOTOR6_STEP_PIN);
        // MOTOR 8
        if (motorMoveSteps7)
          uint16_t a = motorAccumulator7;
          motorAccumulator7 += motorMoveSpeed7;
          if (motorAccumulator7 < a)
            motorMoveSteps7--;
            PIN_ON(MOTOR7_STEP_PORT, MOTOR7_STEP_PIN);
        velocityUpdateCounter++;
        if (velocityUpdateCounter == VELOCITY_UPDATE_RATE)
          if (sendPositionCounter)
            sendPositionCounter--;
            if (*motorMoveSpeed[i] && !motors[i].nextMotorMoveSpeed)
              bitSet(sendPosition, i);
            *motorMoveSteps[i] = motors[i].nextMotorMoveSteps;
            *motorMoveSpeed[i] = motors[i].nextMotorMoveSpeed;
            digitalWrite(motors[i].dirPin, motors[i].dir);
            *motorAccumulator[i] = 65535;
          nextMoveLoaded = false; // ready for new move
        PIN_OFF(MOTOR0_STEP_PORT, MOTOR0_STEP_PIN);
        PIN_OFF(MOTOR1_STEP_PORT, MOTOR1_STEP_PIN);
        PIN_OFF(MOTOR2_STEP_PORT, MOTOR2_STEP_PIN);
        PIN_OFF(MOTOR3_STEP_PORT, MOTOR3_STEP_PIN);
        #if MOTOR_COUNT > 4
          PIN_OFF(MOTOR4_STEP_PORT, MOTOR4_STEP_PIN);
          PIN_OFF(MOTOR5_STEP_PORT, MOTOR5_STEP_PIN);
          PIN_OFF(MOTOR6_STEP_PORT, MOTOR6_STEP_PIN);
          PIN_OFF(MOTOR7_STEP_PORT, MOTOR7_STEP_PIN);
     * For stepper-motor timing, every clock cycle counts.
      int32_t *ramValues = (int32_t *)malloc(sizeof(int32_t) * MOTOR_COUNT);
      int32_t *ramNotValues = (int32_t *)malloc(sizeof(int32_t) * MOTOR_COUNT);
        if (ramValues[i] == ~ramNotValues[i])
          motors[i].position = motors[i].destination = ramValues[i];
      while (true)
        if (!nextMoveLoaded)
          updateMotorVelocities();
        processSerialCommand();
        // check if we have serial output
        if (*txBufPtr)
          if ((TX_UCSRA) & (1 << TX_UDRE))
            TX_UDR = *txBufPtr++;
            // we are done with this msg, get the next one
            if (!*txBufPtr)
              nextMessage();
        if (!sendPositionCounter)
          sendPositionCounter = 20;
          byte i;
          for (i = 0; i < MOTOR_COUNT; i++)
            if (bitRead(motorMoving, i) || bitRead(sendPosition, i))
              sendMessage(MSG_MP, i);
              ramValues[i] = motors[i].position;
              ramNotValues[i] = ~motors[i].position;
          sendPosition = 0;
     * Update velocities.
    void updateMotorVelocities()
      // process hard stop interrupt request
      if (hardStopRequested)
        hardStopRequested = 0;
        hardStop();
      for (int m = 0; m < MOTOR_COUNT; m++)
        Motor *motor = &motors[m];
        motor->nextMotorMoveSteps = 0;
        motor->nextMotorMoveSpeed = 0;
        if (bitRead(motorMoving, m))
          int seg = motor->currentMove;
          if (motor->moveTime[seg] == 0)
            bitClear(motorMoving, m);
            float originalMoveTime = motor->currentMoveTime;
            int originalMove = motor->currentMove;
            motor->currentMoveTime += 0.05f;
            if (motor->currentMoveTime >= motor->moveTime[seg])
              motor->currentMoveTime -= motor->moveTime[seg];
              motor->currentMove++;
              seg++;
            float t = motor->currentMoveTime;
            int32_t xn = (int32_t)(motor->movePosition[seg] + motor->moveVelocity[seg] * t + motor->moveAcceleration[seg] * t * t); // accel was already multiplied * 0.5
            int32_t dx = abs(xn - motor->position);
            if (!dx) // don't change direction flag unless we are actually stepping in new direction
              continue;
            boolean forward = xn > motor->position;
            if (forward != motor->dir) // direction setup time 1/20th second should be plenty
              // revert everything except for dir flag
              motor->currentMoveTime = originalMoveTime;
              motor->currentMove = originalMove;
              motor->nextMotorMoveSpeed = max(1, min(65535, dx * 65.6f));
              motor->nextMotorMoveSteps = dx;
              motor->position = xn;
            motor->dir = forward;
      nextMoveLoaded = true;
     * Set up the axis for pulses per second (approximate)
    void setPulsesPerSecond(int motorIndex, uint16_t pulsesPerSecond)
      if (pulsesPerSecond > 20000)
        pulsesPerSecond = 20000;
      if (pulsesPerSecond < 100)
        pulsesPerSecond = 100;
      motors[motorIndex].maxVelocity = pulsesPerSecond;
      motors[motorIndex].maxAcceleration = pulsesPerSecond * 0.5f;
    void setupMotorMove(int motorIndex, int32_t destination)
      motors[motorIndex].destination = destination;
      if ( destination != motors[motorIndex].position )
        calculatePointToPoint(motorIndex, destination);
        bitSet(motorMoving, motorIndex);
    void hardStop()
      // set the destination to the current location, so they won't move any more
        stopMotor(i);
    void stopMotor(int motorIndex)
      int32_t delta = (motors[motorIndex].destination - motors[motorIndex].position);
      if (!delta)
        return;
      Motor *motor = &motors[motorIndex];
      int i;
      for (i = 0; i < P2P_MOVE_COUNT; i++)
        motor->moveTime[i] = 0;
        motor->moveVelocity[i] = 0;
        motor->movePosition[i] = 0;
      float v = VELOCITY_CONVERSION_FACTOR * motors[motorIndex].nextMotorMoveSpeed;
      float maxA = motor->maxAcceleration;
      float maxV = motor->maxVelocity;
      if (v > maxV)
        v = maxV;
      if (!motor->dir)
        v = -v;
      float t = fabs(v / maxA);
      motor->moveTime[0] = t;
      motor->movePosition[0] = motor->position;
      motor->moveVelocity[0] = v;
      motor->moveAcceleration[0] = (v > 0) ? -maxA : maxA;
      motor->moveTime[1] = 0;
      motor->movePosition[1] = (int32_t)(motor->movePosition[0] + motor->moveVelocity[0] * t + 0.5f * motor->moveAcceleration[0] * t * t);
      motor->moveVelocity[1] = 0;
      motor->moveAcceleration[1] = 0;
      motor->moveAcceleration[0] *= 0.5f;
      motor->destination = motor->movePosition[1];
      motor->currentMoveTime = 0;
      motor->currentMove = 0;
    boolean isValidMotor(int motorIndex)
      return (motorIndex >=0 && motorIndex < MOTOR_COUNT);
    void processGoPosition(int motorIndex, int32_t pos)
      if (motors[motorIndex].position != pos)
        setupMotorMove(motorIndex, pos);
        sendMessage(MSG_MM, motorIndex);
        sendMessage(MSG_MP, motorIndex);
    Command format
    ASCII
    [command two bytes]
    Version
    "hi"
    -> "hi 1"
    zero motor
    "zm 1"
    -> "z 1"
    move motor
    "mm 1 +1111111111
    motor position?
    mp 1
    MOTOR STATUS
    "ms"
    -> "ms [busy motor count]"
    SET PULSE PER SECOND
    pr 1 200
    STOP MOTOR
    sm 1
    STOP ALL
    sa
     * int processUserMessage(char data)
     * Read user data (from virtual com port), processing one byte at a time.
     * Implemented with a state machine to reduce memory overhead.
     * Returns command code for completed command.
    byte processUserMessage(char data)
      byte cmd = CMD_NONE;
      switch (msgState)
      case MSG_STATE_START:
        if (data != '\r' && data != '\n')
          msgState = MSG_STATE_CMD;
          msgNumberSign = 1;
          userCmd.command = CMD_NONE;
          userCmd.argCount = 0;
          userCmd.args[0] = 0;
      case MSG_STATE_CMD:
        if (lastUserData == 'h' && data == 'i')
          userCmd.command = CMD_HI;
          msgState = MSG_STATE_DONE;
        else if (lastUserData == 'm' && data == 's')
          userCmd.command = CMD_MS;
        else if (lastUserData == 's' && data == 'a')
          userCmd.command = CMD_SA;
        else if (lastUserData == 'm' && data == 'm')
          userCmd.command = CMD_MM;
          msgState = MSG_STATE_DATA;
        else if (lastUserData == 'n' && data == 'p')
          userCmd.command = CMD_NP;
        else if (lastUserData == 'm' && data == 'p')
          userCmd.command = CMD_MP;
        else if (lastUserData == 'z' && data == 'm')
          userCmd.command = CMD_ZM;
        else if (lastUserData == 's' && data == 'm')
          userCmd.command = CMD_SM;
        else if (lastUserData == 'p' && data == 'r')
          userCmd.command = CMD_PR;
        else if (lastUserData == 'b' && data == 'f')
          userCmd.command = CMD_BF;
        else if (lastUserData == 'g' && data == 'o')
          userCmd.command = CMD_GO;
        else if (lastUserData == 'j' && data == 'm') // jm [motor] [destination position]
          userCmd.command = CMD_JM;
        else if (lastUserData == 'i' && data == 'm') // im [motor] [destination position]
          userCmd.command = CMD_IM;
          // error msg? unknown command?
      case MSG_STATE_DATA:
        if (((data >= '0' && data <= '9') || data == '-') && lastUserData == ' ')
          userCmd.argCount++;
          if (userCmd.argCount >= USER_CMD_ARGS)
            SERIAL_DEVICE.print("error: too many args\r\n");
            msgState = MSG_STATE_ERR;
            userCmd.args[userCmd.argCount - 1] = 0;
            if (data == '-')
              msgNumberSign = -1;
              msgNumberSign = 1;
              userCmd.args[userCmd.argCount - 1] = (data - '0');
        else if (data >= '0' && data <= '9')
          userCmd.args[userCmd.argCount - 1] = userCmd.args[userCmd.argCount - 1] * 10 + (data - '0');
        else if (data == ' ' || data == '\r')
          if (lastUserData  >= '0' && lastUserData <= '9')
            if (userCmd.argCount > 0)
              userCmd.args[userCmd.argCount - 1] *= msgNumberSign;
          if (data == '\r')
      case MSG_STATE_ERR:
      case MSG_STATE_DONE:
        // wait for newline, then reset
        if (data == '\n' && lastUserData == '\r')
          cmd = userCmd.command;
          lastUserData = 0;
      default: // unknown state -> revert to begin
        lastUserData = 0;
      lastUserData = data;
      return cmd;
    void processSerialCommand()
      byte avail = SERIAL_DEVICE.available();
      byte motor;
      int m;
      for (int i = 0; i < avail; i++)
        int cmd = processUserMessage(SERIAL_DEVICE.read());
        if (cmd != CMD_NONE)
          boolean parseError = false;
          motor = userCmd.args[0] - 1;
          switch (cmd)
            case CMD_HI:
            case CMD_ZM:
              parseError = (userCmd.argCount != 1 || !isValidMotor(motor));
              if (!parseError)
                motors[motor].position = 0;
                setupMotorMove(motor, 0);
                processGoPosition(motor, 0);
                bitSet(sendPosition, motor);
            case CMD_MM:
              parseError = (userCmd.argCount != 2 || !isValidMotor(motor));
              if (!parseError)
                processGoPosition(motor, (int32_t)userCmd.args[1]);
            case CMD_NP:
              if (!parseError)
                motors[motor].position = userCmd.args[1];
                sendMessage(MSG_MP, motor);
            case CMD_MP:
              if (!parseError)
            case CMD_MS:
              parseError = (userCmd.argCount != 0);
              if (!parseError)
                sendMessage(MSG_MS, 0);
            case CMD_SM:
              if (!parseError)
                stopMotor(motor);
                sendMessage(MSG_SM, motor);
            case CMD_SA:
              if (!parseError)
                hardStop();
                sendMessage(MSG_SA, 0);
            case CMD_PR:
              if (!parseError)
                setPulsesPerSecond(motor, (uint16_t)userCmd.args[1]);
                sendMessage(MSG_PR, motor);
            case CMD_BF:
              parseError = motorMoving || userCmd.argCount < 5 || ((userCmd.argCount - 2) % 4) != 0;
              if (!parseError)
                goMoDelayTime = 1000;
                int motorCount = (userCmd.argCount - 2) / 4;
                for (m = 0; m < MOTOR_COUNT; m++)
                  motors[m].gomoMoveTime[0] = 0.0f;
                for (m = 0; m < motorCount; m++)
                  int offset = 2 + m * 4;
                  motor = userCmd.args[offset] - 1;
                  if (!isValidMotor(motor))
                    parseError = true;
                  setupBlur(motor, userCmd.args[0], userCmd.args[1], userCmd.args[offset + 1], userCmd.args[offset + 2], userCmd.args[offset + 3]);
                goMoReady = true;
                sendMessage(MSG_BF, 0);
            case CMD_GO:
              parseError = motorMoving || (userCmd.argCount > 0) || !goMoReady;
              if (!parseError)
                   if (motors[m].gomoMoveTime[0] != 0)
                     int j;
                     for (j = 0; j < P2P_MOVE_COUNT; j++)
                         motors[m].moveTime[j] = motors[m].gomoMoveTime[j];
                         motors[m].movePosition[j] = motors[m].gomoMovePosition[j];
                         motors[m].moveVelocity[j] = motors[m].gomoMoveVelocity[j];
                         motors[m].moveAcceleration[j] = motors[m].gomoMoveAcceleration[j];
                     motors[m].destination = motors[m].gomoMovePosition[4]; // TODO change this!
                     motors[m].currentMove = 0;
                     bitSet(motorMoving, m);
                noInterrupts();
                velocityUpdateCounter = VELOCITY_UPDATE_RATE - 1;
                interrupts();
                sendMessage(MSG_GO, 0);
            case CMD_JM:
              if (!parseError)
                int32_t destination = 0;
                if (jogMotor(motor, userCmd.args[1], &destination))
                  if (!bitRead(motorMoving, motor) || destination != motors[motor].destination)
                    setupMotorMove(motor, destination);
                sendMessage(MSG_JM, motor);
            case CMD_IM:
              if (!parseError)
                inchMotor(motor, userCmd.args[1]);
                sendMessage(MSG_IM, motor);
            default:
              parseError = true;
          if (parseError)
            SERIAL_DEVICE.print("parse error\r\n");
     * Serial transmission.
    void sendMessage(byte msg, byte motorIndex)
      int i = (unsigned int)(txMsgBuffer.head + 1) % TX_MSG_BUF_SIZE;
      if (i != txMsgBuffer.tail)
        txMsgBuffer.buffer[txMsgBuffer.head].msg = msg;
        txMsgBuffer.buffer[txMsgBuffer.head].motor = motorIndex;
        txMsgBuffer.head = i;
        if (!*txBufPtr)
          nextMessage();
    #else
      int i;
      switch (msg)
        case MSG_HI:
          SERIAL_DEVICE.print("hi ");
          SERIAL_DEVICE.print(DFMOCO_VERSION);
          SERIAL_DEVICE.print(" ");
          SERIAL_DEVICE.print(MOTOR_COUNT);
          SERIAL_DEVICE.print(DFMOCO_VERSION_STRING);
          SERIAL_DEVICE.print("\r\n");
        case MSG_MM:
          SERIAL_DEVICE.print("mm ");
          SERIAL_DEVICE.print(motorIndex + 1);
          SERIAL_DEVICE.print(motors[motorIndex].destination);
        case MSG_MP:
          SERIAL_DEVICE.print("mp ");
          SERIAL_DEVICE.print(motors[motorIndex].position);
        case MSG_MS:
          SERIAL_DEVICE.print("ms ");
            SERIAL_DEVICE.print(bitRead(motorMoving, i) ? '1' : '0');
        case MSG_PR:
          SERIAL_DEVICE.print("pr ");
          SERIAL_DEVICE.print((uint16_t)motors[motorIndex].maxVelocity);
        case MSG_SM:
          SERIAL_DEVICE.print("sm ");
        case MSG_SA:
          SERIAL_DEVICE.print("sa\r\n");
        case MSG_BF:
          SERIAL_DEVICE.print("bf ");
          SERIAL_DEVICE.print(goMoDelayTime);
        case MSG_GO:
          SERIAL_DEVICE.print("go\r\n");
        case MSG_JM:
          SERIAL_DEVICE.print("jm ");
        case MSG_IM:
          SERIAL_DEVICE.print("im ");
    void nextMessage()
      char *bufPtr;
      int i;
      if ((TX_MSG_BUF_SIZE + txMsgBuffer.head - txMsgBuffer.tail) % TX_MSG_BUF_SIZE)
        byte msg = txMsgBuffer.buffer[txMsgBuffer.tail].msg;
        byte motorIndex = txMsgBuffer.buffer[txMsgBuffer.tail].motor;
        txMsgBuffer.tail = (unsigned int)(txMsgBuffer.tail + 1) % TX_MSG_BUF_SIZE;
        switch (msg)
          case MSG_HI:
            sprintf(txBuf, "hi %d %d %s\r\n", DFMOCO_VERSION, MOTOR_COUNT, DFMOCO_VERSION_STRING);
          case MSG_MM:
            sprintf(txBuf, "mm %d %ld\r\n", motorIndex + 1, motors[motorIndex].destination);
          case MSG_MP:
            sprintf(txBuf, "mp %d %ld\r\n", motorIndex + 1, motors[motorIndex].position);
          case MSG_MS:
            sprintf(txBuf, "ms ");
            bufPtr = txBuf + 3;
              *bufPtr++ = bitRead(motorMoving, i) ? '1' : '0';
            *bufPtr++ = '\r';
            *bufPtr++ = '\n';
            *bufPtr = 0;
          case MSG_PR:
            sprintf(txBuf, "pr %d %u\r\n", motorIndex + 1, (uint16_t)motors[motorIndex].maxVelocity);
          case MSG_SM:
            sprintf(txBuf, "sm %d\r\n", motorIndex + 1);
          case MSG_SA:
            sprintf(txBuf, "sa\r\n");
          case MSG_BF:
            sprintf(txBuf, "bf %d\r\n", goMoDelayTime);
          case MSG_GO:
            sprintf(txBuf, "go\r\n");
          case MSG_JM:
            sprintf(txBuf, "jm %d\r\n", motorIndex + 1);
          case MSG_IM:
            sprintf(txBuf, "im %d\r\n", motorIndex + 1);
        txBufPtr = txBuf;
    boolean jogMotor(int motorIndex, int32_t target, int32_t * destination)
      // ideally send motor to distance where decel happens after 2 seconds
      float vi = (motor->dir ? 1 : -1) * VELOCITY_CONVERSION_FACTOR * motor->nextMotorMoveSpeed;
      int dir = (target > motor->position) ? 1 : -1;
      // if switching direction, just stop
      if (motor->nextMotorMoveSpeed && motor->dir * dir < 0)
        stopMotor(motorIndex);
        return false;
      if (target == motor->position)
        return false;
      float maxVelocity = motor->maxVelocity;
      float maxAcceleration = motor->maxAcceleration;
      // given current velocity vi
      // compute distance so that decel starts after 0.5 seconds
      // time to accel
      // time at maxvelocity
      // time to decel
      float accelTime = 0, atMaxVelocityTime = 0;
      if (fabs(vi) < maxVelocity)
        accelTime = (maxVelocity - fabs(vi)) / maxAcceleration;
        if (accelTime < 0.5f)
          atMaxVelocityTime = 0.5f - accelTime;
          accelTime = 0.5f;
        atMaxVelocityTime = 0.5f;
      float maxVelocityReached = fabs(vi) + maxAcceleration * accelTime;
      int32_t delta = fabs(vi) * accelTime + (0.5f * maxAcceleration * accelTime * accelTime);
      delta += atMaxVelocityTime * maxVelocityReached;
      delta += 0.5f * (maxVelocityReached * maxVelocityReached) / maxAcceleration; // = 0.5 * a * t^2 -> t = (v/a)
      int32_t dest = motor->position + dir * delta;
      // now clamp to target
      if ( (dir == 1 && dest > target) || (dir == -1 && dest < target) )
        dest = target;
      *destination = dest;
      return true;
    void inchMotor(int motorIndex, int32_t target)
      int dir = (target > motor->destination) ? 1 : -1;
      if (motor->nextMotorMoveSpeed)// && motor->dir * dir < 0)
        return;
      int32_t dest = motor->destination + dir * 2;
        dest = target;
      //setupMotorMove(motorIndex, dest);
      int i, moveCount;
      moveCount = 0;
        motor->moveAcceleration[i] = 0;
      motor->moveTime[0] = 0.01f;
      motor->movePosition[1] = motor->position + dir * 2;
      motor->destination = dest;
      if ( dest != motor->position )
    void calculatePointToPoint(int motorIndex, int32_t destination)
      int i, moveCount;
      moveCount = 0;
      float tmax = motor->maxVelocity / motor->maxAcceleration;
      float dmax = motor->maxVelocity * tmax;
      float dist = abs(destination - motor->position);
      int dir = destination > motor->position ? 1 : -1;
      if (motor->nextMotorMoveSpeed > 5) // we need to account for existing velocity
        float ti = fabs(vi / motor->maxAcceleration);
        float di = 0.5f * motor->maxAcceleration * ti * ti;
        if (vi * dir < 0) // switching directions
          motor->moveTime[moveCount] = ti;
          motor->moveAcceleration[moveCount] = dir * motor->maxAcceleration;
          motor->moveVelocity[moveCount] = vi;
          moveCount++;
          dist += di;
        else if (dist < di) // must decelerate and switch directions
          motor->moveAcceleration[moveCount] = -dir * motor->maxAcceleration;
          moveCount++;
          dist = (di - dist);
          dir = -dir;
        else // further on in same direction
          dist += di;
          motor->movePosition[0] -= dir * di;
          motor->currentMoveTime = ti;
      float t = tmax;
      if (dist <= dmax)
        t = sqrt(dist / motor->maxAcceleration);
      motor->moveTime[moveCount] = t;
      if (dist > dmax)
        moveCount++;
        dist -= dmax;
        float tconst = dist / motor->maxVelocity;
        motor->moveTime[moveCount] = tconst;
        motor->moveAcceleration[moveCount] = 0;
      moveCount++;
      motor->moveAcceleration[moveCount] = dir * -motor->maxAcceleration;
      for (i = 1; i <= moveCount; i++)
        float t = motor->moveTime[i - 1];
        motor->movePosition[i] = (int32_t)(motor->movePosition[i - 1] + motor->moveVelocity[i - 1] * t + 0.5f * motor->moveAcceleration[i - 1] * t * t);
        motor->moveVelocity[i] = motor->moveVelocity[i - 1] + motor->moveAcceleration[i - 1] * t;
      motor->movePosition[moveCount + 1] = destination;
      for (i = 0; i <= moveCount; i++)
        motor->moveAcceleration[i] *= 0.5f; // pre-multiply here for later position calculation
      return;
    void setupBlur(int motorIndex, int exposure, int blur, int32_t p0, int32_t p1, int32_t p2)
      int i;
      float b = blur * 0.001f;
      float expTime = exposure * 0.001f;
      p0 = p1 + b * (p0 - p1);
      p2 = p1 + b * (p2 - p1);
        motor->gomoMoveTime[i] = 0;
        motor->gomoMoveVelocity[i] = 0;
        motor->gomoMoveAcceleration[i] = 0;
      motor->gomoMovePosition[1] = p0;
      motor->gomoMoveTime[1] = expTime * 0.5f;
      motor->gomoMoveVelocity[1] = (float)(p1 - p0) / (expTime * 0.5f);
      motor->gomoMovePosition[2] = p1;
      motor->gomoMoveTime[2] = expTime * 0.5f;
      motor->gomoMoveVelocity[2] = (float)(p2 - p1) / (expTime * 0.5f);
      // v = a*t -> a = v / t
      float accelTime = 1.0f;
      float a = motor->gomoMoveVelocity[1] / accelTime;
      float dp = 0.5f * a * accelTime * accelTime;
      float sp = p0 - dp; // starting position
      motor->gomoMovePosition[0] = sp;
      motor->gomoMoveTime[0] = accelTime;
      motor->gomoMoveAcceleration[0] = 0.5f * a; // pre-multiplied
      a = motor->gomoMoveVelocity[2] / accelTime;
      float fp = p2 + dp;
      motor->gomoMovePosition[3] = p2;
      motor->gomoMoveTime[3] = accelTime;
      motor->gomoMoveVelocity[3] = motor->gomoMoveVelocity[2];
      motor->gomoMoveAcceleration[3] = -0.5f * a; // pre-multiplied
      motor->gomoMovePosition[4] = fp;
      setupMotorMove(motorIndex, sp);
    Attached Files Attached Files
    Administrator Paul's Avatar
    Oct 2012
    284
    Replied here with possible solution.
    https://forum.pjrc.com/threads/45078...l=1#post163522
    Closing this duplicate thread. Please reply on that other thread with the modified code.
