Results 1 to 4 of 4
Thread: Teensy 3.6 Upload Problems
    109
    I decided to try the 3.6's that Santa brought me for Christmas but I am getting the following errors when I try to upload the VideoDisplay file through Arduino:
    Arduino: 1.8.5 (Windows 10), TD: 1.40, Board: "Teensy 3.6, Serial, 180 MHz, Faster, US English"
    c:\program files (x86)\arduino\hardware\tools\arm\bin\../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ar.exe: unable to rename 'C:\Users\Jesse\AppData\Local\Temp\arduino_build_1 97275/core/core.a'; reason: File exists
    Error compiling for board Teensy 3.6.
    Does anybody know how to fix this?
    3,638
    Turn off McAfee real time scan. At least for the first build of each time you run arduino
    109
    For anybody else that is having this problem. I turned off ALL of the antivirus software and then did a fresh install of Teensyduino. Now it works but I found a different problem. Look forward to more threads!
    109
    Thanks @KurtE I just did that
